Old 06-21-2006, 07:12 AM   #1
BrainTeased's Avatar
Default flux removal on battery cells
hi guys i was wondering how do you remove the old flux that has dried on the cells ? as solder wont stick on the cells that i need to re-assemble.
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 06-21-2006, 07:19 AM   #2
drew85's Avatar
sand paper
drew85 is offline   Reply With Quote
Old 06-21-2006, 07:29 AM   #3
Originally Posted by drew85
sand paper
thanks drew
if i do that will the solder re-stick as i've once sanded down my iron tip and now the solder wont stick on the tip.
also what roughness would you recommend me using for the sandpaper?
Old 06-21-2006, 07:30 AM   #4
a dremel works well too
jtrcing is offline   Reply With Quote
Old 06-21-2006, 07:31 AM   #5
drew85's Avatar
Just get it off till the soder sticks, it does not all have to come off. Even a excato will work. just try it and see if it holds.
Old 06-21-2006, 07:49 AM   #6
after you disassemble the pack. hold the cell upright and heat the bottom of the cell till the solder drips off onto the soldering iron. then just flick the solder off the iron onto the cement. the solder wont stick to the cement.
watch out for your feet !!!! then use a dremel with a fine sanding drum.
baih is offline   Reply With Quote
Old 06-21-2006, 07:50 AM   #7
Iceracer's Avatar
You need to re-tin your soldering iron tip. Get it clean, up to temperature and melt fresh resin core solder onto the tip to fully coat it with solder. You can wipe off contamination and excess solder with a quick swipe across a damp sponge.
Originally Posted by BrainTeased
thanks drew
Iceracer is offline   Reply With Quote
Old 06-21-2006, 02:08 PM   #8
Soviet's Avatar
90% Isopropyl Alcohol on a shop rag removes flux in a jiffy, while cleaning your pack up. I've been using it for years with great results.
You can buy it at Walmart...it's in the self-care section with the red label. NOT the blue / purple label (Thats the 70% stuff.)
"You don't get hurt racing little cars..."
-Me
Soviet is offline   Reply With Quote
Old 06-21-2006, 02:41 PM   #9
Motor spray.
Tony Vega is offline   Reply With Quote
Old 06-21-2006, 03:12 PM   #10
AdrianM's Avatar
Radio shack sells a flux remover spray. Its little and it dosent last long. I just leave the flux there. If its electronics grade rosin it does nothing harmful.
If it's acid core...
Adrian Martinez
Old 06-21-2006, 11:22 PM   #11
ProudSavageOwnr's Avatar
Send a message via MSN to ProudSavageOwnr Send a message via Yahoo to ProudSavageOwnr
thanks drew
wen u sand down the tip of your iron sand it so all the old solder comes off and it looks nice n new and then plug it in and keep the solder on the tip untill it starts to melt and then coat the whole thing quickly,you only get around a few minutes to coat it untill it gets out of the temp range and the tip goes all gold and solder wont stick......
and for removing flux just use some sandpaper
FG leopard comp w/Trevor Simpson 28.5 bzm crank
HIP Baja 5sct
AE tc5 3.5t speed monster,Futaba 4pks
Raptor G4 ,Raptor e550,Gaui x5,Mini titan v2,Precision aerobatics bandit 4s monster,Carbon z scimitar Jr 11x
ProudSavageOwnr is offline   Reply With Quote
Old 06-22-2006, 01:00 AM   #12
sbs
sbs's Avatar
This is the way to clean up flux from a soldering point, that is the way we do it in the Airline’s
Sand paper & Dremel
Motor spray
Soren B. Sorensen
Team-manager
Empty Pocket RC-Team
Serpent S411 / Powered by EPRCT Motor Management
sbs is offline   Reply With Quote
Old 06-22-2006, 02:33 AM   #13
Patriiick's Avatar
Trichloretylene (TCE), a common de-greaser, is excellent for cleaning up flux..it also gives solder a nice shiny effect.
Careful, this is very potent stuff so please use protection and keep out of reach of children..
Patriiick is offline   Reply With Quote
Old 06-22-2006, 06:27 AM   #14
thanks guys!
i will try the sand paper method and some brake cleaner or some turps see how i go. sounds like there are 2 major methods , sand paper / dremel with tool tip and chemicals!
cheers for the info guys! will let you all know how i go and what works best and fastest
Old 06-22-2006, 11:03 PM   #15
Rob Phillips's Avatar
I use vinergar to remove flux off my packs. Works great, althought I hate the smell of the stuff, it doesn't have any lasting arroma.
Team Durango | TrakPower | DE Racing | Futaba | Restricted Paint Worx
Velocity R/C Magazine - vrcmag.com
Rob Phillips is offline   Reply With Quote
Anyone have the HPI E-Firestorm Flux brushless RTR truck? pgeldz Electric Off-Road 9 10-29-2008 08:52 AM
HPI E-Firestorm 10T Flux RTR DSX-2 Brushless Cain Electric Off-Road 0 05-11-2008 11:24 AM
33 Promatch 3300 NIMH battery cells and Battery Case nitro468 R/C Items: For Sale/Trade 10 08-06-2007 05:21 PM
Soldering Flux wingswest328 Electric On-Road 13 12-30-2006 11:39 PM
rev 4 battery removal buffalobill989 Electric On-Road 6 12-19-2006 11:58 AM
