Old 06-19-2006, 04:30 AM   #1
RocketRacer's Avatar
Default rollout and gearing
ok here is my situation. i know how to calculate gearing and rollout perfectly. my questions are:
1. How do i figure out what rollout to use for different types of motors??
2. how do i figure out what rollout to use with different types of tracks?
thanks in advance
RocketRacer
XRay T2'008/Nosram ISTC/Nosram 13.5T Spec
Futaba 3PKS with FASST
>>>Knowledge is Power<<<
RocketRacer is offline   Reply With Quote
Old 06-19-2006, 05:34 AM   #2
1fastdude's Avatar
Trader Rating: 15 (100%+)
To figure out rollout for different tracks, try starting at what you had at the last track you ran on. This is a good starting point. You can go up or down from there. Also you can ask someone that runs there and uses the same motor that you are using.
For different motors you can apply the same strategy!
★RCAmerica •Xray •Hudy •BSR/Jaco •Absolute Hobbyz •Gravity RC •PROTOform •Avid •TQ Racing Wire •C & M Motorsports ★
1fastdude is offline   Reply With Quote
Old 06-19-2006, 05:51 AM   #3
One way to use it for gearing is if you have a dyno and you know the rpm of both motors and you know your current rollout.SO lets say your rollout is 1.75
the motor you just ran was 16,000 rpm and you know the motor you want to put in is 14,500 it would look something like this 1.75X(16000/14500)=1.93 the 1.93 number that it outputs is where your car needs be with the new motor.
bill941 is offline   Reply With Quote
Old 06-19-2006, 07:42 AM   #4
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
the motor you just ran was 16,000 rpm and you know the motor you want to put in is 14,500 it would look something like this 1.75X(16000/14000)=1.93 the 1.93 number that it outputs is where your car needs be with the new motor.
simple enough
Old 06-19-2006, 05:44 PM   #5
no not really but I have been working on a excel sheet that all you do is type it in kind of like a end all sheet for gearing,rollout and so forth.
Old 06-19-2006, 05:48 PM   #6
Super Moderator
Marcos.J's Avatar
or just use this one!
http://www.gearchart.com/index.cfm?f...n=chart.create
thats what I did
Old 06-20-2006, 07:59 PM   #7
tdu verney's Avatar
Default Gearing
I was testing gear ratio's Saturday. 30/100 What are the effects of changing a spur gear? If I reduce total teeth or add teeth?
tdu verney is online now   Reply With Quote
Old 06-20-2006, 08:06 PM   #8
HarshGuy's Avatar
Go to www.gearchart.com and see what changes it makes, pretty easy, plug in your values, click the "Gear Ratio" button, then change the spur gear size and click "Gear Ratio" again, mess with the spur gear some more, just keep clicking "Gear Ratio" after each change.
http://www.arroyoc.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Rollout / Gearing? Drifter73 Electric On-Road 9 03-06-2009 06:00 AM
Gearing / Rollout? TheOtherNut Electric On-Road 3 02-19-2008 11:30 AM
GEARING/ROLLOUT QUESTION oldfart Electric On-Road 7 06-25-2007 11:42 AM
1:12 Scale Brushless Gearing or Rollout? Decathalon Electric On-Road 6 05-29-2006 04:48 AM
Rollout Figures For Gearing Calculations Steevo Electric On-Road 16 10-08-2002 05:05 AM
