Old 06-18-2006, 09:29 AM   #1
Default Motor Lathe shims
I have been looking for shim material for my because it appears that it needs to re-shimed my question is where to get some either locally or on the net.Any suggestions?
bill941 is offline   Reply With Quote
Old 06-18-2006, 10:05 AM   #2
my local hobby stores have metals from K&S Metals. usually in the airplane or supplies area. tubing, solid stock, and flat 4x6inch sheets of brass and aluminum. they usually have a label showing the thickness of the sheets. you would have to cut them out with sheet metal cutters.
baih is offline   Reply With Quote
Old 06-18-2006, 11:20 AM   #3
Thanks bud I sent them a email since I don't know where in ohio that I can get it hopefully they can point me in the right direction
Old 06-18-2006, 12:35 PM   #4
burbs's Avatar
Send a message via AIM to burbs Send a message via Yahoo to burbs
Depending on how little or much, you can use anything thats the right thickness.. ive seen guys use a wrapper from a ciggatette pack to get .05 more out of the bit .. As long as you dont over crank, they shouldnt compress..
burbs is offline   Reply With Quote
Head shims to run 30% in a RB S5 motor. Mpowerz Nitro Off-Road 22 01-12-2008 06:49 PM
Motor Springs,shims etc.. for rebuildin stock motors TAMIYAMANUK R/C Items: Wanted to Buy 4 01-03-2007 07:07 AM
WTB teflon motor shims HenBeav R/C Items: Wanted to Buy 4 06-14-2006 07:11 PM
Tire Lathe, Motor Dyno, Comm Lathe For Sale 17Mark71 R/C Items: For Sale/Trade 8 06-05-2005 01:07 PM
motor shims..... SalvadoriRacing Electric On-Road 11 06-01-2004 06:58 PM
