Old 01-12-2003, 12:56 AM   #1
Suspended
maxboost's Avatar
Send a message via ICQ to maxboost
Default tire balancing
i just noticed that my wheels were shaking at throttle, especially on low speeds. is this the indication of unbalance wheels? i've check the CVDs for bends and they were fine. anyone have the same problem? im thinking of getting the trinity tire balancer what do u guys thing?
maxboost is offline   Reply With Quote
Old 01-12-2003, 10:08 AM   #2
Neil Rabara's Avatar
Describe the shaking. Does it wobble as it is rotating?
Neil Rabara is offline   Reply With Quote
Old 01-12-2003, 12:12 PM   #3
Default Tire Balancing
Sounds more like:
- Bent Wheel
- Tire not seated on rim
- Wheel not mounted on axle correctly
- Tire not trued (foam)
If you decide to balance your tires just get a prop balancer they're about 1/2 the price of the Trinity tire balancer and work just as well.
dalem is offline   Reply With Quote
Old 01-12-2003, 12:12 PM   #4
mab_man20's Avatar
Send a message via AIM to mab_man20
Dont bother with the trinity one, get a one of these. It becomes its own case, and the magnets work much better than any bearing.
mab_man20 is offline   Reply With Quote
Old 01-12-2003, 01:19 PM   #5
Suspended
maxboost's Avatar
yes. this is more noticeable at low speed. u can hardly see it at full throttle coz its spinning so fast.
Old 01-13-2003, 11:52 AM   #6
Suspended
maxboost's Avatar
wtf? only three replies? ok now i know non of yall race with a balance wheels.
Old 01-13-2003, 06:22 PM   #7
Suspended
maxboost's Avatar
does anyone balance their tires at all???!!
Old 01-14-2003, 05:51 PM   #8
Send a message via AIM to lilshortyc3
If it is doing the same at slow speeds, it's most likely not the tires that are unbalanced. I had the same problem but it was b/c I put threadlock on my pin and it created a pile of hard guck on the inside of the CVD's. So I would just rebuild the CVD's and see what happens next. Try scraping out the remains in the CVD's.
lilshortyc3 is offline   Reply With Quote
Old 01-15-2003, 09:33 AM   #9
I've balanced my tire for years. I just use a prop balancer and some lead foil. Started after having a twitchy 1/8 scale on-road car that wouldn't negotiate the turn at the end of a long straight away. I do it with all my cars now but I'm not sure how much it helps running stock electric... but I do it just in case.
Old 01-15-2003, 12:13 PM   #10
popsracer's Avatar
Default Tire/Wheel balancing
Considering the time and effort required to properly balance a set of 4 rims and tires. I really have to question if it is worth the effort and then after one hit the rim is tweeked anyways.
popsracer is offline   Reply With Quote
Old 01-16-2003, 09:06 PM   #11
pops shure its wurth all the time & effort. Attention to detail is what wins races and could give U that extra tenth U need per lap
.......Bubba
bubbaicm is offline   Reply With Quote
Old 01-16-2003, 09:50 PM   #12
TurnNBurn's Avatar
Mab_man: That balancer is Da Bomb!
Pops: Depending on how much glue you apply around the tire, the inserts, etc., some wheels could end up WAY out of balance. Every little effort counts, even if they're not balanced perfectly.
TurnNBurn is offline   Reply With Quote
Old 01-16-2003, 10:31 PM   #13
popsracer's Avatar
Default Attention to detail is what wins races
bubbaicm;
Attention to detail is what keeps me in the top 3 most of the time. I've tried balancing tire sets before and question the return on the investment. You can spend HOURS going over every little detail of your Car, but what gain is there.
EXAMPLE: I just spent HOURS removing the Seals/Shields on all of the bearings on my electric Car (per recommendations). If there was any gain, I sure didn't notice it and the extra maintenance more than outweighs it. Solution, Teflon sealed bearings, a good compromise.
There may well be some gain by balancing one's tires/wheels, but for me the time is better spent elsewhere on the car, like Motor tuning/testing. Besides I just gave myself a good lesson on armature balancing today, but discovered a new area to focus on in making more power.
Old 01-17-2003, 08:45 AM   #14
Default Re: Attention to detail is what wins races
Originally posted by popsracer
bubbaicm;
pops forget the shelds go ceramic 50% lighter and last longer less rotating mass saved 1ounce of weightwith this change. I ran 5x10 ceramic clutch bearings in my 7.5 kanai all season replaceing them with new ones after the ceramic balls cut through the metal races A WHOLE SEASON!
on a .21 Picco G1PRO Inever was able to do this before I changed to ceramic bearings. ACER Racing has these bearings cheep for ceramic bearings for all car kits. $119.00 just came off sale were $99.00 single bearings 7.99 ea. plus a lot of team drivers use them also........ Bubba
Old 01-17-2003, 11:39 AM   #15
popsracer's Avatar
Default bubbaicm;
I ended up ordering the Teflonsonic bearings from Acer bearing. I couldn't justify paying more for the bearings than I payed for the entire car.
Once I get my electric car working just the way I want it, then maybe I will look into balancing the wheels/tires and see if it helps.
For an 1/8 scale I can easily see the benefit of the ceramic bearings. I MAY purchase an 1/8 On-Road later this year, but I'm still undecided. Between my Sons and myself we own 7 cars/trucks already and I'm the mechanic (just like Pops Racer) for all of them.
Tire balancing cmain Electric Off-Road 4 01-31-2010 12:55 PM
Tire Balancing???? playboy Nitro Off-Road 5 04-09-2008 02:49 PM
tire balancing Offroadracer3 Monster Trucks 2 06-24-2007 06:30 PM
Balancing out a car with scales? Quinton Nitro On-Road 14 03-10-2006 12:55 PM
armature balancing losiboys Electric On-Road 6 10-13-2005 12:11 PM
