Old 06-15-2006, 09:29 AM   #1
BigDaddyT's Avatar
Send a message via MSN to BigDaddyT
Default AC to DC Power Conversion
This is a bit of an electrical engineering question - I was wondering if there is a formula for calculating how many AC amps an AC to DC power supply will draw? Usually, they are rated in DC amps, but it's hard to tell how much power you need to supply that with on the AC side.
I was thinking about it, and it seemed to me that it's definitely not a 1:1 match because of all sorts of losses in the process of converting the AC to DC and stepping it down and so forth. Also, I would imagine that the RMS of the AC power comes into play as opposed to peak voltage and so forth.
Or am I wrong?
T-Bang Hobby Technology Inc. - www.t-bang.ca
Extreme Performance RC Motors and Racing Supplies - Vancouver, Canada
Team Corally - Trinity - Dekelz.com
BigDaddyT is offline   Reply With Quote
Old 06-15-2006, 09:40 AM   #2
Iceracer's Avatar
Don't forget that the ac power in is typically at 110-120 volts. If the dc output is at say 12 volts, thats a roughly 10-1 transformer ratio. Its more likely to be a 16 volt ac output from a nominal 110 volts in, so around 6 to 1. In other words, if its transformer based, for every amp you put in at 110 volts, you get around 6 amps dc out.
Iceracer is offline   Reply With Quote
Old 06-15-2006, 01:01 PM   #3
Skiddins's Avatar
The transformers (by this I mean the actual electronic components) that 'step-up' or 'step-down' AC voltages have ratio's as mentioned. If you drop [email protected] down to 10V on a 10:1 transformer, you will have [email protected]
If the voltage is being reduced, the current will increase.
Of course this is theoretical and all transformers are not 100% efficient. On top of this you also have the circuits to create the DC voltage from the AC.
Computer PSU's I believe are about 75% efficient.
If someone out there has a 12V PSU for R/C racing where they can give us the ratings off the back we'll see what the losses are like.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 06-15-2006, 02:36 PM   #4
BigDaddyT's Avatar
Yes. That's a key thing I was missing in my original thinking. I forgot about the fact that the current would increase when the transformer steps down the voltage.
The reason I am wondering about all of this is that I have recently been seeing "Personal" generators popping up all over the place. They are small 2 stroke generators that put out 6.8A @ 120V AC, or 8.3A @ 12V DC.
I am confused though why the DC power output is so low, but ignoring that, I am trying to get a ballpark idea of what kind of AC amperage a 12v, 23A DC supply will draw.
Using the formulas above, it seems like you would expect something like:
23A * (12v / 120v) / Efficiency
Does that sound right to you guys?
Say we got 60% efficiency from the system, we would be looking at about 3.8 amps AC. You should still have room to run a few extra AC goodies on there in fact, which would be great.
Old 06-15-2006, 02:44 PM   #5
Conversion is always lossy because you're powering the conversion and regulation circuitry and of course the internal resistance of the wiring and components themselves.
Watts = Volts x Amps.
What is it you're trying to calculate?
Jon3 is offline   Reply With Quote
Old 06-15-2006, 02:59 PM   #6
BigDaddyT's Avatar
Here's what I'm trying to calculate:
On the 12V side:
Watts = 13.8v x 23A = 317.4w
When I connect that power supply to AC, how much loss is there in the process of generating those 317w of DC?
For example, am I actually using 400W of AC to generate 317W of DC including the loss? or is it more/less than that?
Old 06-15-2006, 04:06 PM   #7
timmay70's Avatar
I hate to take the massively simplistic approach... If you have the power supply, there should be a tag on it somewhere that will say what the max imput amp draw will be. If you don't have that, but know what manufacturer makes that supply, I'd look them up and ask. Most should have that info somewhere nearby. If all that is not possible, worst case add 5 - 10% to the required amp supply and go for it. If it were me, I'd want to add in a little more to that margin incase I need to run other appliances off the generator at the same time... like a blender, or a kegerator...
Speed Merchant Rev7, Tekin, TQ Racing (wire), Team Tamale
RC Excitement - Buy where you race, support your local tracks.
ROAR #105242
timmay70 is offline   Reply With Quote
Old 06-15-2006, 05:11 PM   #8
Just a thought.......
I'm assuming you want to charge batteries. Will you be close to your car? If so, skip the generator and power supply and simply hook the charger to your car battery.
Manning is offline   Reply With Quote
Old 06-15-2006, 06:27 PM   #9
Skiddins's Avatar
If anyone intends to use 12V from a battery, your better off buying a leisure battery, as these are better suited to our needs.
Skiddins
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 06-15-2006, 06:33 PM   #10
BigDaddyT's Avatar
Unfortunately, our parking area is nowhere near our track, so we have to look at alternate ways to power our charging equipment as well as our transponder system, PA, etc.
We're looking for the most economical way build up a system that can handle all that.
Old 06-15-2006, 06:42 PM   #11
On the 12V side:
I would go by what the power supply's wattage is listed as. If the power supply does say 400W, then at max, it would draw 3Amps.
If you want to really know what its drawing, grab a Kill A Watt by P3.
Old 06-16-2006, 03:51 AM   #12
Calculate the maximum wattage the PS can give out (Watt=Volt*Amp). Or find that info printed on the PS.
Add 20% to maximum watts.
Divide by 110 and you'll have maximum input amperes.
andsetinn is offline   Reply With Quote
losi 8 brushless conversion brand new. neu,mamba monster,flight power, rc prod design Jwag R/C Items: For Sale/Trade 14 10-19-2008 01:00 AM
Power supply conversion to 2 outputs? yellowpasta2000 Radio and Electronics 1 07-25-2008 01:56 AM
GS Storm conversion to electric power spartan805 Nitro Off-Road 0 04-17-2008 12:08 AM
Electric Conversion REVO, who makes the best conversion? rclab1 Monster Trucks 3 11-25-2007 12:27 PM
PC ATX power supply conversion Nickmind Electric On-Road 19 05-02-2007 01:22 AM
