Old 06-13-2006, 08:17 PM   #1
noline's Avatar
Default Cycling IB 3800's on a Competition Electronics GFX
I have a question, I have some IB 3800's I've had them since September and they are running flat a few friends of mine suggested I cycle them on my GFX to bring them to life.
Now the question I have how many cycles per day and week should I do cycle the battery To bring some life back to them I just did one cycle and here are the numbers how can I tell by the numbers if is a good pack or a bad pack and what do all the numbers mean?
1st Pack
Peak Volts 9.15
RIR 141
Air 17
DCG Time 330
Dcg Ave Volts 6.95
Dcg Ave V1V 6.99
MAHR 3208
MWHR 22318
7amp charge
.03 Peak Detect
35 amp discharge
Second Pack
Peak Volts 9.33
RIR 136
Air 15.8
Dcg Time 366
Dcg Ave Volt 7.06
Dcg Ave V1V 7.10
MAHR 3558
MWHR 25147
7 Amp Charge
.03 Peak Detect
35 Amp Discharge
Any Help would be greatly appreciated
noline is offline   Reply With Quote
Old 06-13-2006, 08:30 PM   #2
XrayFK's Avatar
It's not really recommended that you cycle packs anymore, at least with the newest cells. Have you been equalizing the packs? I don't know how many runs are on your packs, but the runtime seems a little low for 3800s. Also, lower your charge rate to 6A. Also, how hot are they when they peak? You might want to lower the detect down to .02v as well.
XrayFK is offline   Reply With Quote
Old 06-13-2006, 08:42 PM   #3
Looks like it is time to replace them.
Mike Dobbs
barnacle is offline   Reply With Quote
Old 06-14-2006, 12:58 AM   #4
cycling wont give benefits. It'l just give you info about your batts.
anyway, after a charge discharge them at 35amps to 6v as a pack.. and then equalize them in your tray to 0.09v per/cell 5.4v as a pack. then leave them a day or two (longest storage would be 3-4days, this will lower the resistance of your packs and will accept more charge)
lastly, tray them again to 0.9v per/cell... and then CHARGE, 6.0amps .02v peak detect
I HOPE those 3800ib's will still accept 3800mah of charge.
skamolly is offline   Reply With Quote
Old 06-14-2006, 09:13 AM   #5
Yeti35's Avatar
I got IB's that I had since last year that are still takin on anywhere from 4100 to 4300 mah's. I do have a routine that I follow and maybe that is why my packs are doing so well. I don't run mod either so that could be another factor as well. I discharge after I run, equalize and put in the box till next time. I then equalize again then charge them. If sitting for longer then a week I will run them on my Spintec and Dyna Pulse before charging.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 06-14-2006, 11:50 AM   #6
All good advice, but I would refrain from discharging @ 35A. If you're looking to see how the #'s compare to the labels, discharge at whatever it says. I never discharge above 20A strictly to keep temperature down.
Stampede is offline   Reply With Quote
Old 06-14-2006, 11:57 AM   #7
Yeti35's Avatar
I discharge at 30 as per the lable on my cells. So that could be why my numbers are staying pretty good that and I am not abusin them by running mod. I never repeak them either for I was told that it is not good for them and not needed. I get my cells from the site in my sig.
22 3.0SR
Competition Electronics GFX imprsme R/C Items: For Sale/Trade 9 08-19-2007 07:43 PM
Competition Electronics GFX RBLove R/C Items: For Sale/Trade 0 05-06-2007 10:33 PM
Custom Painted Competition Electronics Turbo 35BL, Hurricane 3800's Justin Zorc R/C Items: For Sale/Trade 2 05-05-2006 12:43 PM
Competition Electronics T-35 GFX stegger Electric On-Road 23 09-30-2005 12:11 PM
Competition Electronics help with GFX ahsikes Electric On-Road 5 08-12-2005 08:02 PM
