High quality, low drag bearings
#61
This should be better
#62
Just took them both apart and cleaned out the grease. The polymide ones are a little more free. They also don't use a snap ring to hold the seal in, its like a hard plastic that just snaps in which I think is really cool. With or without the seals there is hardly any difference in how free they are so I am going to run them with the seals in after putting in a few drops of oil.
#63
Spongebob,
Where did you order those bearings from ?
I would like to get some for my 12th scale.
Casey
Casey
#64
#65
dexter helloo!!!
yea u SMSed me .....
hm ...i am in Johor Bahru way down south .... maybe i will call u if i am up in KL ...
well yes the SKF bearings i am still cnsidering to get them or not ... maybe i will once the ones i have KOed ...
btw .... i called the local SKF branch here and asked them about beraing part no MIL STD DxdxBx (from schumacher)
and they quoted me a price of rm 9 per piece .... but did not mention about importing etc etc .....
maybe u should try giving them a call ??
#66
Im after some of those coloured polymide bearings from accer for my mission, anyone know the bearing width, as it doesnt state on the order form, the mission bearings for the hubs are 5 x 10 x 4.
they have them listed as 5 x 10, but not specifically to order for the mission..
what measurement is the 4?...inner diameter or width?
cheers
cheers
#67
usually quoted as d x D x B
d is bore (inner diameter)
D is outer diameter
B is breadth
they need shooting if they dont' list the B but usually its 3mm.
I disagree wiht the majority of people on here, yes if you clean the grease out it makes the bearing roll for longer but it does nacker it out way quicker. a good bearing is silent and pretty smooth. not one that rolls forever.
just my 2 penceworth
sanj
D is outer diameter
B is breadth
sanj
#68
I have to agree with schumacher that de-greasing the bearings can shorten their life BUT for ME, the increase in speed and acceleration is worth it, all i usually do is pull all the bearings out after EVERY race weekend and clean them out and LIGHTLY oil them and i'll get USUALLY about a season out of them
#69
Originally posted by imataquito
dexter helloo!!!
dexter helloo!!!
well... maybe you can send me the part number of those bearings... I'll try to call them again..
#70
Thanks schumacher...
for everyones info....accer have the bearings to fit the Mission..
5x10x4 in the polyamide coloured seals
and also in the teflon seals for the layshafts.
Im ordering today!
Im ordering today!
#71
should i add diff oil to make it smooth and have a longer run time ?
#72
Guys;
I ran my Pro-3 this weekend with my new Acer Teflasonic bearings. I installed them without degreasing. I have to say that if there was any difference between the un-shielded bearings that I ran and the new Teflasonics, I really didn't see it.
#75
also how long they last,
ceramic bearings should be cleaned as per the manufacturers guidelines.
in most cases this means not greasing but does involve flushing them out with WD-40 once in a while. (I do it every 6 months). racing twice a week once outside once on carpet
sanj
sanj
