Old 06-11-2006, 07:08 PM   #1
thedudeaturdoor's Avatar
Send a message via AIM to thedudeaturdoor
Default 4wd/2wd F1 Chasis's?
what choices are out there?
and if you could show me some links thaT would be nice...
thedudeaturdoor is offline   Reply With Quote
Old 06-11-2006, 08:31 PM   #2
Super Moderator
Funkymojo's Avatar
Location: Singapore ̡͌ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡V
Trader Rating: 75 (100%+)
Good thread....so which class is more popular 4wd or 2wd??
WANKING - Extreme agitation and arousal - usually south of Nanking and short of Farking.
I'm neither a Mod nor a Rocker. I'm a Mocker.
Viper R/C Solutions | Atomic Carbon CR2 LWB | Darth Tray | Losi 8IGHT 2.0-E | Tamiya TRF801X-E
Funkymojo is offline   Reply With Quote
Old 06-11-2006, 08:45 PM   #3
i dono, but i want to know whats out there to race, not wich is better
Old 06-11-2006, 09:11 PM   #4
ChadRacing's Avatar
you got the tamiya f201 thats out now and also theres a company called MLP motorsports that makes chassis upgrades and a 2wd version of the car heres the link
http://mlpmotorsports.net/
i run a f201 and im getting a chassis from them
ReVtech / Trinity / EAMotorsports
HotShot RC / Nexus Racing
Xray T2 '009 w/Exotek Chassis, BMI DB12rr, Tamiya F104X1
Team Durango DEX210
ChadRacing is offline   Reply With Quote
Old 06-11-2006, 09:46 PM   #5
Super Moderator
Funkymojo's Avatar
Yup MLP Motorsports rocks...Marty makes the best looking F1 cars around...
Old 06-12-2006, 01:53 AM   #6
MLP#1's Avatar
If you really want to race, and your track doesn't use TCS rules,
MLP R/C Motorsports INT is the way to go! We have the fastest F201's out there, and every one is hand made to perfection! Our customer/tech support is 24/7, unlike any company out there.
MLP#1 is offline   Reply With Quote
Old 06-12-2006, 03:54 PM   #7
yeah, but i dont want to start with a pro level ride, i want something i can hop-up, not come all pimped out...
Old 06-12-2006, 04:34 PM   #8
AWK
AWK's Avatar
Go buy a Tamiya F201(4wd) or Tamiya F103(2wd). F103s can be found cheap on ebay, but parts are getting harder to find. The F201 is 4wd and I just picked one up for myself, but haven't run it yet. The thing is just so cool with the way the suspension is setup and seems to be the favorite choice among F1 r/c racers.
AWK is offline   Reply With Quote
Old 06-12-2006, 05:11 PM   #9
ford_racing's Avatar
Send a message via MSN to ford_racing
If you want to hop it up, get yourself a kit F201 and then gradually turn it into either a 3racing (if you can find the chassis) or a MLP F201.
From stock the F201's have a lot of options which you are able to use to make it peform better
ARC R11
Yokomo YRF001
AE B5m
ford_racing is offline   Reply With Quote
Old 06-12-2006, 05:44 PM   #10
will the 4wd one be able to hold up to a 12t motor
(from tamiya)
and what about part avalibilty?
Old 06-12-2006, 07:16 PM   #11
Super Moderator
Funkymojo's Avatar
If the MLP F201 could be converted into a touring car..now that would rock!!!
Old 06-12-2006, 07:26 PM   #12
hpipro321's Avatar
(from tamiya)
NO!! if you do that think about buying a new car, cause the gears are all plastic and it will burn your gears, diffs, outdrives, hubs and im betting much more (this is for tcs legal cars, for modded cars i guess but you would have to change a bunch of stuff)
d[-.-]b d[-.-]b
d[-.-]b d[-.-]b can you feel the bass? d[-.-]b d[-.-]b
d[-.-]b d[-.-]b
hpipro321 is offline   Reply With Quote
Old 06-12-2006, 11:13 PM   #13
Marty Peterson's Avatar
R/C Tech Charter Subscriber
I have run a 12T in my cars and Jonn has used a Brushless in unlimited class F1 racing and took 1st 27sec's over a 3Racing Chassis Brushless car!
and that is all I will say ask Jonn for pictures and details ok link below!
Here for the fun of it!
Selling HPI F10 Front Knuckles and Complete Rear Axles W/Diffs Ball and Gear.
W/12mm TC Hubs & W/14mm F1 Hubs Good for std bearing Pans cars. STD Bearings!
eBay item number: 200947192161,200947193175,200947187493
Marty Peterson is offline   Reply With Quote
Old 06-13-2006, 04:56 AM   #14
MLP#1's Avatar
Basically, if you want to run high power setups, or simply run the fastest laps, it comes down to power application/handling. The Tamiya F201 is a good car, but it has lots of flex, certain parts break easily, and you really have to upgrade it to make it capable. The MLP F201 is not about having the nicest looking car (although it is! ), but it is about having everything designed to a certain tolerance. The victory Marty is referring to, I was running an MLP F201 SCF-PRO, with an Aon Electric 5800kv brushless motor, Castle Creations Mamba Max ESC, and Thunder Power 11.v 3-cell li-po batteries. If you put that setup in a stock F201, it would blow up !
Anyways, with all the money you'll spend hopping up your F201, you might as well buy an MLP F201 and save yourself all the trouble.
Old 06-13-2006, 08:25 AM   #15
Send a message via MSN to ickvanovs
so MLP will perform better than tamiya?
how about in term of price?
ickvanovs is offline   Reply With Quote
