Old 06-11-2006, 07:16 AM   #1
Default What happen to super narrow tires?
For those of you have being around for a while. Remember back in '96, '97 Yokomo came out with super narrow 22mm tires? It was the way to go back then. Few other companies' pro level cars also came with the narrow tires. I didn't have a touring car back then, so I didn't try the tires. All I know is that they were faster during acceleration, and braking (think about the batteries and tires that they had to use back then). Anyone know the difference in the handling of the car?
I am sure that part of the reason that they went alway was because the rules, but what if the rules doesn't apply?
Regards
thegreatimpulse is offline   Reply With Quote
Old 06-11-2006, 08:07 AM   #2
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
Skiddish tires but where cool to run but with the weight and power we have now they wouldn't work well for most. I had lots of them took some skill to get them to work well.
Rod
ClemsonTigers
USVTA # 224
ERC
RKeasler is offline   Reply With Quote
Old 06-11-2006, 10:34 AM   #3
floodo1's Avatar
Send a message via ICQ to floodo1 Send a message via AIM to floodo1 Send a message via Yahoo to floodo1
super narrows are teh bomb for 4wd drifts
for racing they dont have enough contact patch.
floodo1 is offline   Reply With Quote
Old 06-11-2006, 12:20 PM   #4
OVA
OVA's Avatar
Trader Rating: 79 (100%+)
Rod
Are you sure Rethink pound per square inches buddy
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 06-11-2006, 12:21 PM   #5
OVA
OVA's Avatar
for racing they dont have enough contact patch.[/QUOTE]
Sorry bud I disagee how about the throttle control
Old 06-11-2006, 12:30 PM   #6
OVA
OVA's Avatar
Regards
I really like those yokomo super narrow tires..... NOW day they've really improve the rubber compound plus the belted .. can't remember I think the ROAR change the tires size back to 24mm
Old 06-11-2006, 08:24 PM   #7
RKeasler's Avatar
Am I sure about what As far as those tires go the margin between working well and breaking traction was well....more narrow.
Rod
ClemsonTigers
USVTA # 224
ERC
Old 06-11-2006, 10:45 PM   #8
POOKYT's Avatar
The "pounds per square inch" thing is sort of misleading. If this were the best way then our cars and full scale cars would run on O-ring size treads. In drag racing, this does work but you are really dealing with forward traction. In onroad or offroad you are dealing as much if not more with side bite or side traction. Try to tell a formula 1 driver he will do better with skinny tires!
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 06-11-2006, 11:12 PM   #9
josh69162's Avatar
Send a message via AIM to josh69162
I found some 22mm HPI slicks in my LHS's "clearence" box. I asked about them, and they told me just take 'em! They were pretty cool, and they were fun to drive on. HPI made 21mm X-Patterns at one time...
josh69162 is offline   Reply With Quote
Old 06-12-2006, 03:25 AM   #10
Narrow tires (22 mm) are tiny bit lighter which would aid acceleration. The difference is less with the 24 mm tires we use today, than with the 26 mm that everyone was using when the 22 mm were introduced. Roar (I think) allows both 24 and 26 mm tires yet every team driver I know of uses the narrow tire option.
There is a optimum contact patch size, especially on parking lots where there are lot of very small pebbles and dust.
Why do you think full size Rally cars don't use drag racing wide tires? Rally cars often use very narrow tires to achieve the perfect balance between grip, weight and "snappiness" of the moment when the tires lose grip. In Rally you want the car to gradually start to drift rather than snap out of control. I prefer the same thing with my RC car, even if it never leaves the asphalt.
andsetinn is offline   Reply With Quote
Old 06-12-2006, 05:10 AM   #11
fpart's Avatar
Trader Rating: 40 (100%+)
Send a message via Skype™ to fpart
The way I remember it was that the 22mm tires where much better at the time than 24 or 26 mm tires. This was most because at the time most people didn't have belted tires yet. If you think about it under normal load and rotation, a narrower tire like 22mm would not expand to a very narrow contact patch like a wider tire would do(24 or 26). Therefore you had more contact patch.
The real reasons they died out was:
1. Introduction of belted tires
2. Roar outlawed anything less than 24mm
3. Much better rubber compounds came out.
I still use a set of 22 mm x patterns on my rally(tc3) when we run on pavement(a little sand). part of the rules state that the tires have to be treaded(some kind). The tires are awesome. The last time I drove it, I was 2 laps up on the rest of the field.
teamTrinity.com Sweepracingusa.com
スクービーは私のヒーローです!
Why is Scooby so slow, you might ask?
fpart is offline   Reply With Quote
Old 06-12-2006, 06:09 AM   #12
RKeasler's Avatar
The HPI tires I had super-narrow were belted.
Rod
ClemsonTigers
USVTA # 224
ERC
Old 06-12-2006, 08:40 AM   #13
nagatahawk's Avatar
I ran them back in the day at Revelation, It is a nitro track with long straights and sweeping turns. The tires were very fast. and you had to use them here to keep up with everyone else.
I stopped racing for a couple of years and the tires were banned. When I came back I used them at a parking lot race. They were very fast on the straights but it was very edgy on the corners, it was very easy to get spun out.
nagatahawk is offline   Reply With Quote
Old 06-12-2006, 09:04 AM   #14
It was not because ROAR, don't forget the best rubber tyres(take off, pit shimisu, ride, etc) at that time,1999-2000,(still) were from Japan. At the beginning, only 26mm tyre existed, then someone thought more rubber on the track means more grip(=faster),those wide(30mm, mainly for rear) were actually slower. So they went to the opposite way to go narrow, 22-21mm. Those super narrow tyre were very fast, but wear out even faster. So JMRCA decided to took a balance , between 22mm(performance) & 26mm(low wear). There you have 24mm. Basicly, all tyre manufacturer stopped making 22mm super narrow, ROAR, EFRA only followed the trend for 24mm.
caveman is offline   Reply With Quote
Old 06-12-2006, 03:28 PM   #15
buzz06's Avatar
Send a message via MSN to buzz06
The current BRCA wet tyre is 21mm
buzz06 is offline   Reply With Quote
WTB Proline super narrow sedan wheels trjracing R/C Items: Wanted to Buy 8 01-03-2008 06:45 AM
WTB Proline super narrow sedan wheels trjracing R/C Items: Wanted to Buy 0 12-26-2007 06:15 PM
Tamiya Type A Tires 53433 Medium Narrow Reinforced Type Tires Type A tiggersz R/C Items: For Sale/Trade 2 07-13-2007 02:42 PM
Kawada racing LS-21 narrow tires and wheels brand new speedemall R/C Items: For Sale/Trade 0 04-25-2006 06:02 PM
HPI Super Nitro, NRS4 2, Trinity/Picco 15, Super Tires........... HikariRacing2 R/C Items: For Sale/Trade 2 07-15-2002 01:40 PM
