Interference
Interference
can anyone help... got major interference with my yokomo bd. glitching when it gets to further away distances even in my back yard. ive used my brushless and my robitronic speedo . 2 servos 2 recievers. had my handset sent away and check along with crystals. tried longer and shorter aeriels . put plastic antenna mount on instead of metal one. double amount of double sided tape . moved reciever away from speedo on top of servo. tried unplugging personal transponder and servo and fans and still yet it glitches. ive snapped 5 drives shafts due to this glitching across track into walls has any one got any idea what this could be. was thinking about spectrum but ive overspent trying to sus the problem as it is.
two things that I had happen in the past that coused glitching:
you didn't mention switching motors....I've had a bad endbell of a chameleon cause probs
Inside my handset a lead from the antenna was weirdly soldered and until I actually followed the wire from the antenna to the solder joint and yanked on it a few times did I find that an intermittent connection was happening at the solder joint. Just a visual check and everything looked fine.
Also...sounds stupid.....is the antenna on the handset completely screwed into the handset?
Super Moderator
All good points, & I might bring up a couple more questions, exactly which radio set & what wind of motor are you using? Some rados will just be more prone to interference than others, & some motors can put so much of a load on a car's system that the amp draw can start to cut into the juice that powers the receiver, & that can cause interference(because the receiver may not have enough available power to run properly)...
thanks for the sugestions.
using ko vantage
had the handset apart antena is fine nothing wrong there. apart from brushless i been using 12-7 turn motors. i was changing stuff from friends car today and then walking down yard. changed modules handsets ended up with least interference without the brushless but still get the occasional random glitch even when not touching throttle or steering. racing tomoz using my normal speedo see how it goes alough ive interfernce with this also.
using ko vantage
so whats the way around this may i ask?
