Old 05-25-2007, 03:29 AM   #601
Originally Posted by SWTour
Most software would not put two of the same transponder numbers in the same heat...if the two numbers showed up at the track 'on the same day' and 'in the same class', I'd agree...the original TRANSPONDER from AMB should have first right. But what would be the difference in this verses a guy who has had 3 or 4 clones made...and loans a couple of them out on race day...and OPPS two or 3 end up in the main...NOW YOUR Up a Creek...but there's probably a bigger chance of that happening, than the other.
It also seems in this day and age... almost every race I go to, guys have 3 or 4 different transponders w/ different numbers...so if too many showed with the same number, I'd bet within 2 minutes...someone could borrow one and resolve the problem quickly.
Yes common sense resolves most problems quickly
Terry_S is offline   Reply With Quote
Old 05-29-2007, 01:38 AM   #602
asw7576's Avatar
Originally Posted by Terry_S
Thanks Colin
We do what we can to improve things by developing new and better products, it's what we do best. You're right Colin we're not a big company but we do try and look after our customers the best we can, good service = happy customers!!!
Guys please read the i-PT tech specs on my first post it will answer a lot of your questions. If you compare the specs with the AMB PT you will see we've made a few improvements!
Apologies for taking a while to reply to you guys who have sent PM's and emails, I'm replying as fast as I can!
My home track(s) has AMB-RC and AMB-RC3 counting system ( newer one ? ).
Is this clone work for both systems ( RC & RC3 ) ?? ......, because the original transponder works on both systems flawlessly.
If I buy the clone, what information do you need ? do you need just numbers from my AMB or I have to send the original AMB transponder to you in UK ?
How do I buy from you ?
Old 05-30-2007, 01:44 PM   #603
Hi asw7576, the i-PT will work the same as the original PT if it works on the rc and rc3 the clone transponder will work ok too.
You need to send your original AMB PT to us in the UK, it's not possible to make a clone just from the ID number. Once we have your number it's possible to re-order more clones without sending your PT.
If you want to order the details we need are on the form at www.rclaps.com you should send the form to us along with your original AMB PT. The turn around is about 10 days with us plus the shipping time back to you.
Old 05-30-2007, 02:31 PM   #604
asw7576's Avatar
Are you going to crack open my original AMB for cloning ?
Old 05-30-2007, 03:15 PM   #605
Ed Anderson's Avatar
Trader Rating: 26 (100%+)
NO
They apply power to them, and read the digital number off of them. You will get your PT back the same way you sent it to them.
Ed Anderson is offline   Reply With Quote
Old 08-04-2007, 08:27 PM   #606
first off terry your i-pt's are awsome good to see some compitition (sorry spelled wrong) anyways now that i have looked at this thread i will pick up a broken amb one send it to you and get a awsome new and better i-pt one this is a great product i am gona reccomend it to everyone i know.
kevin097 is offline   Reply With Quote
Old 08-04-2007, 09:34 PM   #607
You do realize it has to be a working transponder.
Old 08-04-2007, 10:43 PM   #608
Gus S's Avatar
got my answer by reading back a few pages
Gus S is offline   Reply With Quote
Old 08-05-2007, 12:10 AM   #609
JSA
JSA's Avatar
Originally Posted by Terry_S View Post
Thanks Jeff The i-PT has proved to be a popular RC product!
Our new PTX personal transponder is similar to the 'number selectable' T1-10 concept but for the AMBrc and AMBrc3 systems.
We've also got more planned for our AMB20 product line
terry_s
The PTX you mentioned is that for use with AMBrc, how many units in a set?
I'm looking for some I-Pt which can allow us to rent out. cos there are many new racers who haven't got a pt yet...
38 years in R/C.......Tel: 013-3032185......Merlin Fuel(Spain), Mielke Pipe(German), Anderson RC Bike & Mini 1/18(Taiwan), Ming Yang Products(Taiwan), HongNor GT, Panther Tires(USA), SH Engines(Taiwan), Force Engine(Taiwan), Buku CLutch, SP Racing Tyres, KM Racing. Slot Car: Ninco, Slot.it, NSR, FLY
ONLINE SHOP - www.racerhobby.com
JSA is offline   Reply With Quote
Old 08-05-2007, 03:04 AM   #610
More info here.
http://www.rctech.net/forum/showthread.php?t=164588
Old 08-05-2007, 03:06 AM   #611
V12
V12's Avatar
JSA
Yes the PTX is working with AMBrc. I think there are no sets but there are different IDs in each transponder and you could select them by pressing a button.
More on the PTX at this thread http://rctech.net/forum/showthread.php?t=164588
V12 is offline   Reply With Quote
Old 08-05-2007, 11:08 AM   #612
If you need a replacement or spare personal transponders the new i-PT has advantages over existing PT's. The i-PT is a 'cloned' version on your current ID number. If you have a damaged or broken AMB personal (broken lead etc) an i-PT replacement is now an option.
Specifications:
MRT i-PT Direct Powered Transponder
Overall dimensions: 26 x 22 x 7 mm
Case size: 22 x 22 x 7mm
Weight: 6g (without power lead)
Power feed: from a free rx channel or 'batt'
(user replaceable power lead)
Connection plug: standard servo plug
Operating voltage: 1.5V - 30V DC
Power consumption: approx 20mA @ 6V DC
(same as existing AMBrc PT @ 6V DC)
Power Booster: Yes, maintains 6V output signal
(can operate for 30+ secs if power feed fails)
Reset time: instantaneous (AMBrc PT is approx 1 sec)
Case colour: optional (various colours available)
Display LED: Blue (standard)
"You do realize it has to be a working transponder."
it states that it can be a broken transponder
Old 08-05-2007, 08:45 PM   #613
(broken lead etc)
It still has to function. (or it has to work if power is applied to it)
I'm sure Terry will answer.
Old 08-06-2007, 10:43 AM   #614
Trader Rating: 8 (90%+)
Terry,
I have been having problems with my I-PT working for a whole race. I run it in 12th 4 cell Stock and sometimes it just doesnt count and other times it does. I have checked the lead for any damage and for any cold solder joints. Thanks.
Johnny Carey is offline   Reply With Quote
Old 08-07-2007, 05:33 AM   #615
Skiddins's Avatar
Hi Terry,
I sent my PT to you for cloning, which should arrive today.
I think I put my home address onthe form, if the PT will be sent back recorded delivery I might need to PM you work address so there is someone to sign for it.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
WTB AMB Personal Transponder beaverltd Australia Wanted to Buy 3 06-08-2009 09:13 PM
personal transponder NOOB-SMOKE Australia For Sale/Trade 4 05-21-2007 12:00 AM
Looking for Personal Transponder goat27 R/C Items: Wanted to Buy 1 03-14-2007 06:47 PM
Personal Transponder southernford246 Electric On-Road 8 03-06-2007 05:48 PM
AMB Personal Transponder Slotrc R/C Items: For Sale/Trade 9 06-16-2005 07:51 AM
