New X10P4 Touring Car From MLP
#1112
Shim it out and it will be fine ok.
it shouldn't be walking like that I didn't have a problem before hand I wounder what might be wrong there are bearing on each side and they do not move so how could it walk like that ? Oh I told him to tell you to adjust the rear belt I was putting it back together real fast so remove the upper bulk heads on the rear and life the bearing cam/holders and rotate them so there is some slack in the rear belt ok and make sure the center section is right and all the screws are all the way in ok. When you put the top plate back on do the front bulk head screws then the rear then the 4 posts and then the 2 in the motormount if you took them out and then the lower and after that Tighten them down in the same way once all the screws are in ok.
