Old 06-03-2006, 12:18 PM   #1
Send a message via AIM to canto54
Default Tuning mod motors for Ib's
Here in France IB's has been allowed since the beginning of the year and in each race we can see many motors problems. The problem is that a solder break on one of the pole. We don't see that as often with GP cells so I'd like to know what to do with IB cells. Should I reduce the timing of my motors with the increase of voltage. Should I gear my motors differently?
I'm running 12*1 with CS silver brushes or with checkpoint infinity brushes.
Thanks by advance!
Robitronic Avid V2
Robitronic - Graupner - GM racing
JP Products
www.mrclongwy.fr
www.petitrc.com
canto54 is offline   Reply With Quote
Old 06-03-2006, 12:54 PM   #2
Set a current limiter on your ESC.
D_o_S is offline   Reply With Quote
Old 07-11-2006, 07:29 AM   #3
can somebody explain some tuning facts about checkpoint mod motors? especially the timing part. thanks
skamolly is offline   Reply With Quote
Old 07-11-2006, 08:15 AM   #4
vtl1180ny's Avatar
R/C Tech Charter Subscriber
That's some high heat if you are melting the solder off. I'd definitely try backing off some timing or maybe even dropping a tooth or too from the pinion.
I still lurk....
vtl1180ny is offline   Reply With Quote
Old 07-11-2006, 01:00 PM   #5
There really isn't anything to explain - they tune like any other motor. The difference is that you don't have to screw with the brush hoods to get them right, and you are limited to using their brushes. What motor do you have any what are you doing with it?
Corner Weight is offline   Reply With Quote
Old 07-11-2006, 01:19 PM   #6
Trader Rating: 24 (100%+)
seen that problem this past weekend with the v2 motors and ib3800's. only has the problem with the ib's, gp's no problem. and that was at a offroad race.
vic0280 is offline   Reply With Quote
Old 07-11-2006, 01:21 PM   #7
tbeardmore's Avatar
Over geared!
BMI DB10R, Corally RDX PHi, BMI 12R..!!
Need a "real" car... contact me at:
www.beardmorechevy.com -or- www.beardmoresubaru.com
tbeardmore is offline   Reply With Quote
Old 07-11-2006, 01:48 PM   #8
Nexus Racing's Avatar
Are you using any fans?
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 07-11-2006, 04:55 PM   #9
Matt Howard's Avatar
Originally Posted by tbeardmore
Over geared!
you would know
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 07-11-2006, 06:10 PM   #10
Sounds like a cold solder joint.
Was the battery properly assembled??
The battery poles ruffed-up and cleaned, same with the battery bars.
Soldered with quality solder with a Hot iron?? a little flux will help also.
M2Racing
M2Racing is offline   Reply With Quote
Old 07-11-2006, 06:24 PM   #11
Trader Rating: 59 (100%+)
Send a message via AIM to nitro kid
i had this happy to me at a on road race the motor got so hot that the solder came off and the comm did not look good you is just runing to much tuning it not the ib cell it the tuning go down some set it at 0 and go up as need it
nitro kid is offline   Reply With Quote
Old 07-11-2006, 06:27 PM   #12
by the way what you runing ??
Old 07-11-2006, 07:21 PM   #13
maxepower's Avatar
Exclamation Solder meltdown!!!
The pro drivers running V2's i.e. Rhienhard is using the new endbell config. I believe this was done just for that reason. He is also using two fans one on the endbell and one on the esc. Many of the pro drivers were having the solder melt because they push the motors to the extreme. This is the first I heard of that it is only happening with the IB's and not the GP's. There might be some truth to this only because more amps create more heat, so these high output batteries could be one of the factors in this occurance.!!! I don't think it's poor soldering or over timed motors. Just the nature of the beast!
Just my 2$
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Tuning electric motors D_o_S Electric On-Road 14 03-31-2006 03:48 AM
Tuning electric motors sonicfish Rookie Zone 0 01-08-2005 03:54 PM
Tuning Picco G1 XP 21 motors Illusion-Lighti Onroad Nitro Engine Zone 0 06-25-2004 11:14 PM
Tuning motors with brushes xray racer Electric On-Road 59 03-30-2004 09:24 PM
