Old 06-01-2006, 06:04 PM   #1
AWK
AWK's Avatar
Default What power supply???
I am looking to get a comm lathe which requires a power supply. I have never used a power supply in my racing because I haven't had the need. My question is whats a good brand, how does it get setup, and how does it all work????
AWK is offline   Reply With Quote
Old 06-01-2006, 06:41 PM   #2
LRP has a nice one 14Amp, 17Amp peak... street price is 110$
The lathe has to be a 12V unit to work with power supply directly...
cvt01 is offline   Reply With Quote
Old 06-01-2006, 06:41 PM   #3
Trader Rating: 38 (100%+)
This is an excellent power supply for the money. Have used it for a year with no problems. Had an Integy power supply and it blew up within a week.
http://www.nesail.com/detail.php?pro...6530ec2967a237...
or8ital is offline   Reply With Quote
Old 06-01-2006, 07:25 PM   #4
Joel Lagace's Avatar
http://www.buyreliant.com/psupplies/psv200.htm
Best value hands down! 20amps!
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 06-01-2006, 07:29 PM   #5
Jimmy Morris's Avatar
Word!
www.superiorhobbies.com
Jimmy Morris is offline   Reply With Quote
Old 06-01-2006, 07:51 PM   #6
BeetleBailey's Avatar
I think the point was missed here. He needs a PS for a Lathe. Thus he either nedds an adjustable output or a very low output.JMO
BeetleBailey is offline   Reply With Quote
Old 06-01-2006, 08:17 PM   #7
Super Moderator
Grizzbob's Avatar
Not neccessarily, there are specialized lathe motors that are meant to run on higher voltage, one of those could work at 12 volts(possiby)...
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 06-01-2006, 08:18 PM   #8
to power a lathe you have a few choices;
4 cell battery pack
12 volt motor and 12 volt power supply.
power supply with adjustable voltage.
new charger that has the option for motor break in. usually requires a 12 volt power supply.
Yokomo motor mate.
motor dyno ( motor monitor) you can usually run a lathe off these and it will help you tune a motor.
the 12 volt motor that Hudy uses spins too fast for me.
i use a 12 volt motor from a electronics store. this will hook up to my 12 volt power supply
if you are going to work on your motors at home, for the time being just get a 12 volt motor and hook it up to your car battery. you can use 12 guage speaker wire to make a lead long enough to go to your workbench from the car. i would only make it 10 to 12 feet
baih is offline   Reply With Quote
Old 06-01-2006, 08:27 PM   #9
AWK
AWK's Avatar
I am looking at the Trinity of Team Orion lathe, so a power supply for one/both of those.
Is there one lathe better than another? I when hooking up the lathe to the power supply, it is like wiring a motor to an esc correct? Solder the wires onto the motor of the lathe and then attatch to the power supply?
As a new member, I am really impressed with the amount of good replies I get on this forum, I really appreciate the help.
Old 06-01-2006, 08:51 PM   #10
trinity and orion are two different lathes.
the cobra at stormer hobbies use to be the best buy. it came with a diamond bit. you will have to look up the price. are you racing at socal ? look in the pits and see what most people are using.
Old 06-01-2006, 08:53 PM   #11
AWK
AWK's Avatar
No I race down at the Tamiya track in Aliso. Not many people use lathes on the Saturday practices, so I don't know what people are using.
Old 06-01-2006, 09:37 PM   #12
this is the lathe i was talking about.
https://www.ssl-stormerhobbies.com/c...ns&pn=COB200WD
i personally use a hudy at home and a integy for my track lathe.
the cobra comes with the diamond bit and is the best price.
the other lathes, diamond bit is extra.
decide on which lathe you are going to get and we could help you further.
Old 06-01-2006, 10:50 PM   #13
Tsquare's Avatar
I just ordered an Orion Lathe myself, came highly recommended. If you have never used a lathe before, it is ok to get a diamond bit, but I would suggest you also get a carbide bit and practice using the lathe with the carbide bit for a while, then when you feel your abilty with the lathe has reached a high enough point, put in the diamond bit. Once you damage a diamond bit it is finished, and costly to replace. Carbide bits are $4.00 dollars, ok to make your mistakes on. Good Luck!
Tsquare is offline   Reply With Quote
Old 06-02-2006, 12:34 AM   #14
AWK
AWK's Avatar
Do you like your Integy lathe? I am running no higher than a 19T motor at TCS, but mainly running 27T stock. Does it matter? I noticed the Orion is $20 more, has a 19T drive motor, and requires a 4.8V power source (versus 55T and 7.2 - 12V Integy). I would say it is between those two right now.
Old 06-02-2006, 06:17 AM   #15
i use a CRC 12v slave motor on my hudy. Works great. And doesnt require a charged battery pack or take up time on my charger while at the track. Thats the great thing about going 12v to the power supply its there when you need it and leaves your chargers free to do what they do charge batteries.
www.rcottawa.com
Computer power supply used for charger power supply? 66Racer Radio and Electronics 7 05-25-2008 12:52 AM
RC BLOW OUT !!!! Ice chargers,novak discharger,power supply,power bridge,integy setup shrum1340 R/C Items: For Sale/Trade 20 07-23-2007 05:37 AM
>>> TEAM NOVAK N-POWER POWER SUPPLY GREAT CONDITION $50 <<<< mach51 R/C Items: For Sale/Trade 3 02-06-2007 10:53 PM
turning pc power supply into a rc power supply andy_666 Electric On-Road 20 01-16-2006 05:20 PM
SEC Power Supply vs. Hobbico Power Supply? F1Junkie Electric On-Road 1 06-05-2004 08:52 AM
