Old 05-31-2006, 08:53 PM   #1
Default ft tc4 gearing
ok i am new to rc racing and i don't know what pinion to put with my factory spur gear(i think that is is a 48P 72T spur) i have heard different opinions, so i don't know what to believe so i will ask some people that will know, i have a checkpoint 15X2 motor that we run on a medium length track with foams. can someone point me in the right direction. someone said that i should lose the 48p 72T spur and get another pitch so that it will be smoother, is this true?
andy_b22 is offline   Reply With Quote
Old 05-31-2006, 09:01 PM   #2
tc4wally's Avatar
don't know about the pitch issue, but i found that the graph at the back of the manual was almost spot on in relation to a starting point.
Just a matter of starting there and moving up or down depending on what you need and the conditions.
tc4wally is offline   Reply With Quote
Old 06-01-2006, 09:19 AM   #3
justin lessard's Avatar
Send a message via AIM to justin lessard
or you can go to gearchart.com
justin lessard is offline   Reply With Quote
Old 06-01-2006, 11:01 AM   #4
Don't worry about the pitch, 48dp is absolutely fine and changing wouldn't benefit you much. It depends a lot on your individual track, motor etc as to exactly what pinion you run. On a medium length track, probably something between 24-28t would be a good starting point.
Ask other drivers at your club what gear ratio they use. You can work out your tc4 ratio by doing: (teeth on spur/teeth on pinion)*2.5. The 2.5 bit is the 'internal ratio' on the tc4 that is created by the different sized gears in the transmission cases. A smaller pinion will give you a higher number gear ratio, and will increase the cars acceleration, but lower the top speed.
HTH,
Ralph
ralph_c is offline   Reply With Quote
Old 06-01-2006, 04:59 PM   #5
RcRacing4Ever's Avatar
Cool opion on pinon
i run like a 28,29 depending on track size ? 48p is fine, takes more of a beating.... lmao
RcRacing4Ever is offline   Reply With Quote
Old 06-01-2006, 05:46 PM   #6
it is a medium track, but it changes everyweek from a medium to short then shot to medium track, any brands suggested?
Old 06-02-2006, 03:05 AM   #7
If you mean pinions, they're all pretty similar. You wont notice the difference between a cheap and expensive 48dp pinion, any weight difference is minimal.
Gearing lickashotblaow Electric On-Road 0 07-29-2007 05:47 PM
NeeD Help with gearing please daver1 Electric On-Road 4 07-20-2007 09:12 AM
Gearing for TT-01 tl-01-jhb Rookie Zone 0 11-10-2004 05:35 AM
Need help gearing a TC3 fasda1 Electric On-Road 10 11-06-2004 11:51 AM
Gearing??? mike m Monster Trucks 3 01-24-2004 07:54 PM
