Old 05-31-2006, 08:16 AM   #1
nikkiesteban's Avatar
Send a message via Yahoo to nikkiesteban
Default inputs eagle cdc v6.0/b
is this normal for eagle cdc v6.0/b that the packs are charged sooo hot... i even changed it into very low thermal cut off like 3mv..
post your comments here positive and negative...
nikkiesteban is offline   Reply With Quote
Old 05-31-2006, 08:28 AM   #2
sosidge's Avatar
Unfortunately, yes, it does get the packs hot. This is the main reason I got rid of mine six months ago in favour of the Much-More Cell Master.
The Eagle was a good choice two or three years ago, but has been surpassed by many other chargers now.
Old 05-31-2006, 08:37 AM   #3
thanks for that.. any inputs are welcome.. pos or neg..
Old 05-31-2006, 09:34 AM   #4
rc-zombies's Avatar
yes..it runs hot.
I place my cells on top of a fan to keep them cool..
hopefully when the new 16x512 3step charger gets released
it will charge cooler.
Old 09-15-2006, 04:06 PM   #5
does this charger usually the backlit goes out??? because i just plugged in my friends cdc 6/b2 then after a few seconds the backlit went out..
Old 09-15-2006, 08:51 PM   #6
Trader Rating: 68 (100%+)
my backlight did go out on occassion, but it goes back on after a while. i notice that this happens when i use the 20amp discharge and not put a fan on the charger.
after more than a year of use, my cdc went dead and i had it sent back to HK (i think) for repair. when i got it, the backlight issue never returned. i guess they upgraded it or something
marvi is offline   Reply With Quote
Old 09-15-2006, 10:57 PM   #7
thanx bro.. im from philippines to.. hehehe
how much the shipping costs?? who will be the one to shoulder the shipping when the charger will be going back to you??
Old 09-16-2006, 12:16 AM   #8
For charging with CDC , u need some fan to reduce temp of batt.
khunballz is offline   Reply With Quote
Old 09-16-2006, 04:43 AM   #9
rayman's Avatar
Pre, i have this charger ac/dc version. It chargers a little hotter than my ce pitbull but nothing to worry about. I'm not sure if its ok to put a fan on your batts while charging. The internal temp is high but the outside is cool. Some peeps in this forum said dont do it.
backlit is still fine after this long but the ac is dead so its a big piece of "portable" ac dc charger.
rayman is offline   Reply With Quote
Old 09-16-2006, 08:11 AM   #10
how about the D2 charger of eagle racing??? any news??? how does it charge the packs??
Old 09-16-2006, 09:36 AM   #11
i paid P2,000.00+ for everything (parts/labor/shipping), but a big chunk of that amount was shipping. i got it in about a month or less. a friend of mine had the older version (non backlit) and we had ours sent to HK at the same time. he also paid about the same amount (his charger's problem was just shut down)
Old 09-16-2006, 04:21 PM   #12
oh ok sir. thanx...
Old 09-17-2006, 08:57 AM   #13
before i forgot.,., do any of you already used the EAGLE D2 chargeR?
Futaba Fasst Receiver inputs Brad S. Radio and Electronics 1 06-22-2008 03:37 PM
Any inputs on the Spectrum DX2 set ? nikkor Singapore R/C Racers 8 10-26-2006 02:00 AM
we need your inputs V1R Oval, Larger Scales and More 0 06-06-2006 04:24 AM
Carpet Racing - Need your inputs pls. badboy Rookie Zone 8 08-04-2005 01:04 AM
Eagle CDC 6.0/B Mossie Australian Racing 4 02-03-2004 05:09 PM
