Old 05-30-2006, 02:29 AM   #1
gizmo360's Avatar
Default Much-More Cell Master Or Robitronic Overloader
i have both of thease chargers and would like to know which one is going to give me the best results ? i may sell one so need to know which one to sell !
i need to know what charger is going to give me the best charge and power and general all round results for the newer cells.
i run Mod / Tc / 6cells.
help and thanks
gizmo360 is offline   Reply With Quote
Old 05-30-2006, 02:34 AM   #2
Keep the Cell Master, sell the Robitronic.
D_o_S is offline   Reply With Quote
Old 05-30-2006, 02:36 AM   #3
Nicadrauspro4's Avatar
Cellmaster for sure!
works1200.weebly.com
nicadraus-lamborghini.weebly.com
Nicadrauspro4 is offline   Reply With Quote
Old 05-30-2006, 02:52 AM   #4
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Robitronic or Supernova is one up against a cell master. Its definitely more superior on all angles.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 05-30-2006, 03:03 AM   #5
gizmo360's Avatar
Default reasons
what are your reasons for the CELL MASTER ?
Old 05-30-2006, 03:13 AM   #6
nino_pohan's Avatar
sell cell master
nino_pohan is offline   Reply With Quote
Old 05-30-2006, 03:19 AM   #7
gizmo360's Avatar
bit of a split vote here !!!!!
Old 05-30-2006, 03:32 AM   #8
I have both too, and i tend to use the cell master more, i seem to find that when charging with the overloader it seems to get the cells really hot! is this normal? what settings are you guys using on your overloaders, i run 27t stock here in the UK
Smartypants is offline   Reply With Quote
Old 05-30-2006, 03:34 AM   #9
nino_pohan's Avatar
I have cell master but now i sell it and go to LRP Pulsar2. I think cell master delta peak is too sensitive.
Old 05-30-2006, 03:56 AM   #10
TeamMuchMore's Avatar
Cell master dealta peak is accurate, not sensitive. your battery should not false peak when you use it with LLO function.
I would think Hara, Marc and karn would not use them if it is too much trouble charging the battery.
james
TeamMuchMore is offline   Reply With Quote
Old 05-30-2006, 03:58 AM   #11
gizmo360's Avatar
LLO function ! is that for when the packs are fully discharged for the start of the charge !
Old 05-30-2006, 04:01 AM   #12
battery pack being hot has a lot to do with current fluctuation. if you like to find out more about that here is very good article
http://nexusracing.net/newsdesk_info...newsdesk_id=29
Old 05-30-2006, 04:29 AM   #13
danjoy25's Avatar
james
I think even with a 50 dollar ebay cheapo charger all the above will still kick my ass
Old 05-30-2006, 04:50 AM   #14
double post
agower is offline   Reply With Quote
Old 05-30-2006, 04:50 AM   #15
ive had both and the cell master is about 10 times better. the only half decent thing on the robitronic is the 20amp discharge. The motor run in is pointless as its only 10amp which just isnt enough. the cell master is alot more accurate and easy to use.
so sell the robitronic
Robitronic Overloader charger Grindog001 Electric On-Road 17 05-28-2006 04:04 PM
Robitronic Overloader Charger Tony Rivas Electric On-Road 23 05-27-2006 02:15 AM
Robitronic Dyno - Pro Master II Canuck R/C Items: For Sale/Trade 4 01-23-2006 04:21 PM
Charging GP1100 with robitronic overloader al1_be Electric On-Road 1 09-30-2005 08:20 PM
ROBITRONIC Pro-Master II jeepnyy Electric On-Road 12 08-02-2004 10:24 AM
