Old 05-29-2006, 02:18 PM   #1
thedudeaturdoor's Avatar
Send a message via AIM to thedudeaturdoor
Default NOOB set-up 101
i want to know it all, like what does a hard sway bar on the rear do, a soft one in the rear, what is anit squat, what is pro squat, what do hard springs do, what do soft spring do, what if u run softer springs in the front than in the rear, and vise versa, so on and so fouth, it would be cool if some people could explain EVERYTHING to do with set-up for noobs (like me)
thedudeaturdoor is offline   Reply With Quote
Old 05-29-2006, 02:51 PM   #2
sosidge's Avatar
http://users.pandora.be/elvo/
Old 05-29-2006, 03:53 PM   #3
Send a message via ICQ to elvo
Beat me to it...
Originally Posted by sosidge
elvo is offline   Reply With Quote
Old 05-29-2006, 05:29 PM   #4
kerry's Avatar
http://www.teamxray.com/teamxray/pro...13&kategoria=0
download there setup book, the perfect info to have with you at the track
kerry is offline   Reply With Quote
Old 05-29-2006, 09:36 PM   #5
Why don`t ya just try and learn for yur self ????
duhh is offline   Reply With Quote
Old 05-29-2006, 09:54 PM   #6
Send a message via MSN to ickvanovs
but we need somekind of guide to help us know what we are doing
ickvanovs is offline   Reply With Quote
Old 05-29-2006, 11:59 PM   #7
Drewdc90's Avatar
Have a read of the XXX main setup book, it explains what things do in really simple text.
-Xray--Nosram--Orion--Trak Power--Duratrax--Spektrum--Futaba-
Sunshine Coast QLD AUSTRALIA
"If you stand still long enough you'll go backwards"
Drewdc90 is offline   Reply With Quote
Old 05-30-2006, 05:51 AM   #8
buzz06's Avatar
Send a message via MSN to buzz06
Like these guys are saying you need to read guides and try and learn for yourself. I find the best way is to just ask around at your local track (Which is what I did when I first started and still do now )
I will give you one tip though, softer springs on the rear give you more rear end grip
Good Luck
buzz06 is offline   Reply With Quote
Old 05-30-2006, 06:42 AM   #9
415racer is offline   Reply With Quote
Old 05-30-2006, 09:55 AM   #10
Tsquare's Avatar
The responses given to you so far are correct. Get the XXX Main book, go to the Xray website and download their Guide and goto the website listed as "pandora". These are all very good reference materials to start your learning process on setting up a chassis.properly But the most important information will come from your practice and experience from using the these setup guides and experiencing first hand what effect one change can have on your chassis. Good Luck - spend the time at the track practicing with these guides.
Tsquare is offline   Reply With Quote
Old 05-30-2006, 10:38 AM   #11
buzz06's Avatar
Originally Posted by 415racer
That isnt proper advice!!! Softer springs do not always give you more grip.... it depends on the track, tyres or ur set up at the moment!!! Get a proper book like XXX Main and don't listen to duff advice!!
hehehehe, thats true! dont listen to me :P
it does depend on the track and tyres and so on...
Old 05-30-2006, 04:36 PM   #12
im too lazy, not to add that there no track around here
Old 05-31-2006, 05:27 AM   #13
If you`re that lazy BUY A COUCH and stay on it
noob to r/c.. mad_man Monster Trucks 10 05-26-2008 02:34 PM
WTA...noob here... Susaiput Malaysian R/C Racers 4 04-27-2008 07:16 AM
noob needs some help g_spot24v Electric Off-Road 5 11-15-2006 02:19 PM
Help a noob?? hinchrin Monster Trucks 3 06-22-2005 07:45 AM
noob .... hibiki Malaysian R/C Racers 55 02-14-2005 10:35 PM
