Old 05-29-2006, 10:30 AM   #1
SlamMan's Avatar
Default Features to Look for in an ESC?
Looking to buy my first ESC. What features should I be looking for? How do I go about picking the right one for me.
A little background. I'm a total newb and I'll be racing stock at first. I would like an ESC that I will be able to move up with though.
SlamMan is offline   Reply With Quote
Old 05-29-2006, 10:45 AM   #2
pinggoy's Avatar
Trader Rating: 24 (96%+)
Send a message via Yahoo to pinggoy
look for a lightweight esc..with programable setting.. if your racing stock you dont have to buy those "no motor limit" esc which is a little more expensive... some offers a waterproof esc... but to be sure...buy it from a well know manufacturer. that has good warranty program...cause esc can burn anytime due to carelessness..
TAMIYA TRF415 MRE l NOSRAM SPX l BALLISTIC 17.5
TAMIYA TRF416X
www.noicewatches.bigcartel.com
pinggoy is offline   Reply With Quote
Old 05-29-2006, 01:22 PM   #3
SlamMan's Avatar
What does programable mean? Can I get one that I can use one a brushed now and a brushless later or would I be better just buying a new one when I go to a brushless motor?
Old 05-29-2006, 01:38 PM   #4
rz_xternal's Avatar
There are some ESCs that can run both brushed and brushless (for example, Novak GTB, LRP Sphere/Sphere Competition). Those are quite expensive though I'd get a simpler brushed one for cheap, learn all the stuff, then move up later..
Programable means you can configure throttle settings, braking options, some other stuff. I'm still learning as well..
rz_xternal is offline   Reply With Quote
Old 05-29-2006, 02:01 PM   #5
The most important thing is getting a speedo with a 6V BEC to power the receiver and servo. Then you won't have to upgrade your speedo when you get a 6V FET servo (not if you get one, because a fast servo is a must eventually!)
THancock is offline   Reply With Quote
Old 05-29-2006, 03:50 PM   #6
Skiddins's Avatar
Ignoring the price issue, you want an ESC that is either programmable or has presets that are specifically for Stock racing, which will mean you get optimal performance from which ever motor you use.
You also want a low 'on' resistance which is normally given in the spec sheets.
You might also want to consider the level of service that the manufacturer can provide, as these expensive items can be a nightmare when they go wrong and some of the companies don't seem to care about after sales service!
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 05-29-2006, 04:22 PM   #7
thedudeaturdoor's Avatar
Send a message via AIM to thedudeaturdoor
make sure that it has all GOLD conectors,
my esc connectors are metal, and my controler is going into thermal shutdown with 3300's and a 27t, its gay
thedudeaturdoor is offline   Reply With Quote
Old 05-29-2006, 05:49 PM   #8
King-G's Avatar
Send a message via ICQ to King-G
Good smoke retention.
King-G is offline   Reply With Quote
Old 05-29-2006, 08:20 PM   #9
Jochim_18's Avatar
If your in a market for an Good ESC and on a budget get the Novak GTS cost around $80. And novak have the best customer service I've been in the hobby for six years now and never had use any other ESC than novak.
But if you looking for high end ESC I have Novak GT7 for sale for $75
Old 05-29-2006, 08:54 PM   #10
quantum's Avatar
one of the most important specs of a good esc is a low "on-resistance".
a lower on-resistance means the esc consumes less of the battery power...which translates into higher voltage being passed on to the motor, more runtime, and less heat.
the novak gtx has rating of .00034ohms, and funny thing, the novak gtb when in brushed mode has an even lower rating of .00013ohms!
quantum is offline   Reply With Quote
What advanced programming features do you use? ESWLFSE Radio and Electronics 8 12-19-2007 09:55 PM
New Features, Upgrades, and More futureal R/C Tech Site Forum 37 01-05-2005 02:52 PM
LRP vs Novak features Mr-s413bt Electric Off-Road 9 05-10-2004 09:51 PM
What features on a radio help the new driver? imjonah Rookie Zone 5 04-22-2004 12:59 AM
New 710 features and pics Here serpentracer1 Nitro On-Road 40 11-07-2003 04:12 PM
