Old 05-29-2006, 09:17 AM   #1
Default wich 19 and 12 turns motor and why
hey guys in the weekend i ran a 19 turns v2 motor and i really liked running 19 turns so i am switching to that from 27 turns. but what motor would you recomend what are good and bad things about the different motors´. price and the way they aré builded dosnt matter to me.
but i am also interrested in starting running 12 turns but wich one should i get a orion ore a team ceckpoint from teambrood and shoul di get a 12x1, 12x2 ore 12x3 and i why i am running outdoor
Rasmus
Last edited by Rasmus TbEvo IV; 05-29-2006 at 12:01 PM. Reason: need info on another motor to
Rasmus TbEvo IV is offline   Reply With Quote
Old 05-29-2006, 09:22 AM   #2
i was thinking about the team brood v2 but i have been told that the high velocity tuned camilion and the team checkpoint should be better maybe a team brood tuned checkpoint
RASMUS
Old 05-29-2006, 09:44 AM   #3
RASMUS
I'd probably go for the Checkpoint Money 19T, if mod then Pro Cobalt.
D_o_S is offline   Reply With Quote
Old 05-29-2006, 10:07 AM   #4
how about the handwound quad magnet from teambrood
Old 05-29-2006, 11:15 AM   #5
PitCrew's Avatar
The new Komodo Dragon 19t motor seems to be at least as good or better than anything out there right now.
I personally have had great results with the Reedy Quad mag 19t.
Either from team Br00d is a great choice.
Let them know what style of racing you are doing, and they will tune to motor specifically to that application.
PitCrew is offline   Reply With Quote
Old 05-29-2006, 01:50 PM   #6
buzz06's Avatar
Send a message via MSN to buzz06
At the end of the day they are all the same, it is just down to ur brush and spring setup
buzz06 is offline   Reply With Quote
Old 05-29-2006, 02:00 PM   #7
Drew_Cat's Avatar
don't forget the gearing !
Items for sale:
TURBO GFX>>>> http://www.rctech.net/forum/showthread.php?p=4329165#post4329165
Tekin Battery Nurse >>>> http://www.rctech.net/forum/showthread.php?p=4329173#post4329173
Thanks for looking
Drew_Cat is offline   Reply With Quote
Old 05-29-2006, 02:13 PM   #8
thedudeaturdoor's Avatar
Send a message via AIM to thedudeaturdoor
the trinity 9teen is baddd, in a good way
thedudeaturdoor is offline   Reply With Quote
Old 05-29-2006, 02:21 PM   #9
It also depends on where you are racing and what applications. If your track follows ROAR rules then you probably wouldnt want to buy the quad magnet or the new Checkpoint...neither are ROAR legal.
If you are just racing in unorganized racing with no rules then I think any of the 19T motors will be fine for you.
We personally feel "if you follow the ROAR guidelines" our new Komodo is the best 19T out there.
Good Luck
Ernie
ErnieP is offline   Reply With Quote
Old 05-29-2006, 10:37 PM   #10
Grenade10's Avatar
Trader Rating: 37 (100%+)
I've raced 19 turn 4 cell 1/12 scale for the last year. I have also tunned motors for a lot of racers in this area (100+), which has given me a good reading on the motors as I have dyno'd them before and after working on them.
Most can be made to work well based on the brushes, springs that can be changed. Out of the package, the Checkpoint is good, but so far the Komodo Dragon has been better. The only down side to the checkpoint is the lack of brushes and springs.
As to the Reedy Quad Magnet - get the Fantom motor, these have been great. I have also gotten the Atlas based motor to work as well as the Komodo. For a true Modified, I have several Epics that are balistic.
So Roar approved - Komodo, For true modified Epic. IMO
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 05-30-2006, 05:43 AM   #11
buzz06's Avatar
True!
Old 05-30-2006, 10:11 AM   #12
Tsquare's Avatar
Rasmus
I have been running the Checkpoint 19T motor recently, it is very fast. I purchased it because I like the idea of the lower maintence (with the Infinity brushes I get between 25 to 30 runs without cutting the comm), what I have found out is with the Atlas brushes installed the motor is faster than the Infinity brush (only for 2-3 runs though). So I will practice with the infinity brushes, and race time I will run the atlas brushes. I have had no problem with being pulled down the straight by other cars. I have used the Quad Mag and the C2 and like the Checkpoint much better. I have not tried the Komodo yet, will have to give that one a try also. Good Luck.
Tsquare is offline   Reply With Quote
Old 05-30-2006, 10:15 AM   #13
Default Tsquare
I am sure the Checkpoint is a great motor but all 19T are not the same. If one group of manufacturer's are building to the limitations of the ROAR rules and one is not...I think it is very difficult to compare 19T'ers. You are comparing apples to oranges...
I guess what I am saying is the only fair way to compare would be ROAR approved 19T and outlaw 19T
Guess just depends what rules your club runs under.
Old 05-30-2006, 10:26 AM   #14
Anthony.L's Avatar
Trader Rating: 36 (100%+)
I've got one of all of the 19t motors and the Komodo is by far the fastest out of all of them. At least at my track, your mileage may vary.
Anthony.L is offline   Reply With Quote
Old 05-30-2006, 10:30 AM   #15
BeetleBailey's Avatar
I would'nt trade for my Cobalts. No way no how. Where I run we don't observe the ROAR rule so they are legal. If your track dosen't then they're worth their weight in gold. JM.02
BeetleBailey is offline   Reply With Quote
Brushed motor turns to Brushless Motor turns raedat Australian Racing 15 10-25-2007 09:06 PM
wich one of theese lathes are complete with motor en bite Rasmus TbEvo IV Electric On-Road 5 03-23-2006 08:17 AM
Motor Turns jpollnow Electric Off-Road 1 02-20-2006 10:09 PM
Wich motor is better for XXX-T ? Snikkari Electric Off-Road 4 09-08-2004 04:33 PM
8 turns motor rcsabah Malaysian R/C Racers 75 10-02-2002 06:55 AM
