Old 05-28-2006, 10:23 AM   #1
MK_Arbiter's Avatar
Default stripped screws
How do you guys deal with stripped screws? They really piss me off.
MK_Arbiter is offline   Reply With Quote
Old 05-28-2006, 10:44 AM   #2
Send a message via ICQ to rcnewb2004
1. Get good screw Drivers (i recommend hudy)
2. Get good screws (aluminum screws are soft.. so try not to use them if u are starting out)
3. Figure out how much tightening is good (that comes from experience.. but over tightening screws will strip them)
4. If a screw is stripped... u can try to re-grove ur screw... by repeated scoring the head of the screw....
5. If its an allen head... u can super glue a cheap allenhead driver onto ur screw.. wait for a bit.. and see if u can twist it off...
6. if the ways above doesn't work ... use the search function...
7. provide more information, pictures are always nice.
rcnewb2004 is offline   Reply With Quote
Old 05-28-2006, 10:45 AM   #3
Secret_weapon's Avatar
If there is a hope that even the srews are stripped but you think you might be able to turn them and you used a thread lock (lock tight), heat the screw with a light for 30 seconds and try to open it fast. Because the lighter melts the thread lock inside making it easy to unscrew.
If the screw is a philips screw type get a bigger tip of the screw driver and place. it on the stripped screw and hit it hard with a hammer few times to make a new thread and it will open.
If you are using hex screws. get a philips (-) screw and place it on the hex screw and do the same procedure.
Well.. that's what i do.( Be Cautious )
Secret_weapon is offline   Reply With Quote
Old 05-28-2006, 11:04 AM   #4
MK_Arbiter's Avatar
how much is a Hudy screw driver set?
Old 05-28-2006, 03:37 PM   #5
kerry's Avatar
all hudy tools are worth there weight in gold, hudy makes a few differnt combo sets. depends on what you need. they also have 2 different styles plastic handle and metal if you can affford it then go with the metal. check out their website www.hudy.net they are the snap on of r/c tools
kerry is offline   Reply With Quote
Old 05-28-2006, 04:11 PM   #6
stiltskin's Avatar
Trader Rating: 102 (100%+)
Use a grinding wheel in a Dremel tool and cut a slot in the head. Then use a straight slot screwdriver to turn it out.
Drill the head off, seperate the parts and then use vise grips to get the shank out. Be careful if its a countersunk screw, you might not have enough grip left after drilling the head off.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 05-28-2006, 08:46 PM   #7
MAD1's Avatar
I found a small screw extractor bit set at Sears. Works awsome, once you read the instructions. Believe it or not, I picked up a used chassis and had to exract all but 2 screws. A tool that actually worked.
MAD1 is offline   Reply With Quote
Old 05-28-2006, 09:33 PM   #8
MK_Arbiter's Avatar
how does it work? and how much was it?
Old 05-29-2006, 10:28 AM   #9
Jimmy Morris's Avatar
You get a small drill bit thats smaller then the screw shaft and drill down through the head. Then get the extractor and put it in the hole, give it a few taps, then then you can back the extractor out and hopefully the screw as well.
www.superiorhobbies.com
Jimmy Morris is offline   Reply With Quote
Stripped screws pinky2252s Nitro Off-Road 2 05-30-2008 01:30 PM
Help please with stripped screws Wing Chun Electric On-Road 8 08-26-2006 03:50 PM
stripped out screws onnetz Electric On-Road 9 02-18-2005 07:01 AM
Stripped screws ........ how do you take them off ? asw7576 Electric On-Road 11 10-31-2004 05:48 PM
Stripped Screws Horse Singapore R/C Racers 4 10-16-2002 08:28 PM
