Old 05-26-2006, 10:06 PM   #1
MK_Arbiter's Avatar
Default TA-05 drive belt.
I tried out my TA-05 out on a track today and my frond drive belt melted and wraped around the centre gear. Anyone got any solutions to fix that or any ideas of why it happened?
MK_Arbiter is offline   Reply With Quote
Old 05-27-2006, 02:08 AM   #2
sounds like you ran the belt with incorrect tension (to loose I think) and then something got stuck in the front diff.
DA_cookie_monst is offline   Reply With Quote
Old 05-28-2006, 07:59 AM   #3
MK_Arbiter's Avatar
What should the proper tension be?
Old 05-28-2006, 10:18 AM   #4
Trader Rating: 22 (100%+)
Send a message via AIM to 5thscaleracer
it should be as loose as can be with out the clicking. the best way is to stick a mod in the car like sa 12T or so... run it as loose as you think is ok, hit the throttle if you hear a click the belt is skipping tighten it up a bit. Keep tightening it up untill the click is gone. It should still ahve some loose tension but when the belt is too tight it will cause binding and you will be slow.
5thscaleracer is offline   Reply With Quote
Old 05-28-2006, 10:20 AM   #5
MK_Arbiter's Avatar
changing the belts and the tension on the TA-05 is so annoying!
Old 05-28-2006, 12:32 PM   #6
GreaseMonkey's Avatar
I've had a similar thing happen to my TA05. Something got stuck in the pulley, flipped the belt over and wore out the centre pulley. If I could find a centre pulley that was metal I'd get it as my local hobby shop can't get the centre pullies (NFI why, they can get part #51212 and #51214 but not 51213) so I had to order it online.
Oh, and if you think changing and adjusting the belts in a TA05 is annoying, try doing a TRF415. You'll soon learn to appreciate how easy the TA05 is.
GreaseMonkey is offline   Reply With Quote
Old 05-28-2006, 12:40 PM   #7
Send a message via MSN to TAMIYAMANUK
go to the TA05 thread the guys are very help full (as is everyone on rctech)
also about the belt if the belt has strenched really far just replace it i have had this happen to me once but the car just stopped dead in the track and didnt do any damage to the belt luckly lol
TAMIYAMANUK is offline   Reply With Quote
Old 05-30-2006, 03:49 PM   #8
Redwings's Avatar
Ok Guys,
This may be a stupid question, but i just got a TA05 and did not notice a belt tensoner on it . Where is it or how do you tighten both belts if needed.
Redwings is offline   Reply With Quote
Old 05-30-2006, 04:13 PM   #9
MK_Arbiter's Avatar
I had the same prob until i thuroughly read through the instructions. It's on the side of the diff. you know where you put that gear thing. im a bad describer.
Belt Drive vs shaft drive vic88my Nitro On-Road 16 11-10-2007 08:26 AM
shaft drive vs. belt drive plz help pH1L Rookie Zone 1 06-07-2007 05:32 AM
Belt Drive versus Shaft Drive SUNA Nitro On-Road 20 03-28-2006 09:04 PM
Belt drive versus shaft drive...pros and cons of each? AttackDonut Rookie Zone 21 01-02-2005 05:23 PM
Shaft Drive or Belt Drive? dino.tw Nitro On-Road 109 05-25-2004 11:04 PM
