Old 10-10-2007, 07:28 PM   #286
Does the dpd discharge all the cells at once or individually? Because if it does the info while discharging could be usefull if say u had a cell drop more quickly than the others then u would know u had a cell on the way out....If it doesnt is there away to freeze the screen at the end to be able to jot down the discharge results cause mine seems to go thru that very quickly or do you think my AA batts are goin dead or are dead?
NUCRPTRACER is offline   Reply With Quote
Old 10-10-2007, 08:24 PM   #287
Joel Lagace's Avatar
Thats is the whole point of this discharger is the data, yes you can id cells going bad or bad cells. I have cycled 30 or 40++ packs on it for friends to re-match there packs(re-sort is more realistic removing the poor cells and grouping the good cells)
Unfortunatly the data screen scrowls way to fast.. ITs the charger not the AAs. I sure wich there was a USB to hook up to the pc. I had have copy down the info by hand into excel sheets to regroup the cells.
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 10-11-2007, 06:33 PM   #288
I understand that but is the main screen while internal discharge is being used and your screen reads from cell 1 to cell 6 is the discharger just working from 1 to 6 or all 6 at the same time cause it seems strange that I have never had say cell 3 got out before 1 or 2 or 4 its always the same 123456 it would be more realistic if they were being discharged at once....If not what would be the difference than using the smart tray or a durtrax 20a tray and just see which lights go out first.....know what I mean....
Old 10-16-2007, 07:28 PM   #289
Grenade10's Avatar
Trader Rating: 37 (100%+)
Ok Guy's I need some help. I have a DPD discharger (black) that I purchased last year. I had a few issues with getting it to see a battery, but after a little sanding on the battery bars and solder, everything worked just fine. After going gas racing this summer, I have dug out my electric stuff, and I can not get it to see the battery. Keeps coming back with check connections.
Any thoughts??
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 10-16-2007, 07:37 PM   #290
adamge's Avatar
Check your cell voltages.
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
Old 10-16-2007, 07:57 PM   #291
YUP, check the voltages, chances are that since us neglected your pack all summer running that dirty noisy nitro stuff, that they gone and went into self discharge well bellow .9volts per cell... Could be a few enough to indicate no pack detected..
Slap the packs on the charger for 500seconds then hit the tray.
Let us know if thats what it was. If they where IB4200s im 99% thats your issue
www.rcottawa.com
Old 10-16-2007, 10:21 PM   #292
Grenade10's Avatar
I had already thought of that. I was able to measure 1.20+ volts on the pins that contact the cell with a DVM with the pack in the unit. On my packs I would put 1500mah into them every 3-4 weeks. Out of 9 packs, it looks like I have 3 cells that have gone to zero. Yep they are IB-4200 cells!
Old 11-30-2007, 10:46 PM   #293
BSchorr's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to BSchorr Send a message via Yahoo to BSchorr Send a message via Skype™ to BSchorr
Any known issues with the DPD at all? Just wondering between the DPD and teh CTX-D trays... for the money.
I got a question about using the DPD. When you put the pack and and clamp it in.. does it start immediately? I am wondering if i can just put it on and monitor the pack/cells while its charging?
Proline ~ Genesis R/C Products ~ First Premier Satellites
BSchorr is offline   Reply With Quote
Old 11-30-2007, 10:58 PM   #294
flameoutgarrett's Avatar
Send a message via MSN to flameoutgarrett
i would go with the ctx...
more money but way better imo
better features and way better quality
Team fun-Www.rc-trim.com-Team Speedmerchant-Team Orca-Team Br00d
flameoutgarrett is offline   Reply With Quote
Old 11-30-2007, 11:17 PM   #295
maxepower's Avatar
Angry ISSUES with DPD!
If the batteries aren't fairly close in voltage the cells will take a long time to discharge because once one cell gets to .9 volts it will only discharge the rest at 1 amp. This sucks! IMO
maxepower is offline   Reply With Quote
Old 11-30-2007, 11:18 PM   #296
BSchorr's Avatar
Ya.
Old 12-05-2007, 01:37 AM   #297
BSchorr's Avatar
I got a question about the DPD, Once the cells do reach the desired set cutoff voltage, does the DPD hold it there, or does it stop the cell from discharging and then that particular cell balances back out to its usual 1.2'ish voltage?
Old 12-05-2007, 04:38 AM   #298
TheCoolCanFanMan's Avatar
As far as I know, nope and nope
Malc The Cool Can Fan Man
TheCoolCanFanMan is offline   Reply With Quote
Old 01-22-2008, 01:46 PM   #299
Send a message via ICQ to MattW
Has anyone else had the issue where it seems to just "stop discharging" one cell. I see a post about it toward the bottom of teh page, but no sign of answer. Mine has been fine, but now just doesn't seem to like discharging the No1 cell. I have been using pulse mode, and then as it switched to individual, it seems to stop discharging cell 1.
MattW is offline   Reply With Quote
Old 01-22-2008, 02:57 PM   #300
mjm
mjm's Avatar
Yep this happeend all the time to mine. It was either cell 3 or 5. I could clean the contacts, clean the batteries and it would still stop.
It did not matter what pack it used it just seemed to be a random issue.
There is a very fine line between 'hobby' and 'mental illness.
mjm is offline   Reply With Quote
Re: FS Trinity Dyna-Pro Digital Discharger Benq R/C Items: For Sale/Trade 2 07-24-2008 05:50 AM
Trinity DPD Digital Discharger $90 barnacle R/C Items: For Sale/Trade 21 09-14-2007 07:47 AM
Trinity Digital Discharger $80.00! Like New chrisf608 R/C Items: For Sale/Trade 11 01-29-2007 08:52 PM
Trinity DPD digital pro discharger! Fabulous R/C Items: For Sale/Trade 9 11-11-2006 10:43 AM
