Old 09-30-2007, 06:15 PM   #271
Jake S's Avatar
Trader Rating: 66 (92%+)
Send a message via AIM to Jake S Send a message via MSN to Jake S
Originally Posted by magm20001 View Post
recharge your aa batteries.
or u can run without the aa batteries altogether.
just dont run it with like 1% charge in the aa batts, it gets confused.
i just purchased new Duracell aa's from the store without using it, it only worked well for 2 cycles, then went back to doing it
VooDoo Racing Cells | Flying Farmer RC | Trackside Hobby | Prochko Paintz | RG1
Jake S is offline   Reply With Quote
Old 09-30-2007, 06:52 PM   #272
barber's Avatar
Originally Posted by barber View Post
ok i have tried everything nothing seems to work when i put my pack to discharge everything is fine durning the 30 amp cycle when it switches to the 1.5 cycle when the fans cut out all the rest of cells discharge and leave the no2 cell with about 1.20 still in the pack last night i had it on for 6 hrs still would not discharge the no2 cell i borrowed my friend same brand discharger
and his discharge the batt right out.
is there anyone i can email in this forum or at trinity
BARBER SHOP RACING.
Hara Cyclone Edition,MAMBA 7700KV,Spectrum,
Mazdaspeed 6 Painted By McGoo Creations,
JR Z1,Orion 4300Mah,Ib 4200Mah,Ice,Rp,Trinity.
Race Prepaired & Driven By TEAM DRIVER (BARBER)
barber is offline   Reply With Quote
Old 09-30-2007, 06:58 PM   #273
magm20001's Avatar
take out the aa batts, try run it without the aa batts. i wouldnt trust duracells that sit on the shelves for years.
magm20001 is offline   Reply With Quote
Old 09-30-2007, 07:12 PM   #274
barber's Avatar
can this discharger work without the aa batt.
BARBER SHOP RACING.
Old 09-30-2007, 07:22 PM   #275
magm20001's Avatar
yes, if there is no aa batts, it powers itself through the pack being discharged.
when you take the pack off, the DPD will turn off
Old 09-30-2007, 08:58 PM   #276
Jake S's Avatar
that back-light itself works with or without the aa batteries in, but the cell readings on the display are not readable (i can still use it using the "turn on" "mode" "mode" "mode" method to select liner, internal, .90v)
Old 09-30-2007, 09:16 PM   #277
coons88's Avatar
Send a message via MSN to coons88
Jake S: I think the screen problem is a reasonibly common problem. I think it has something to do with heat inside the unit, and when it cools down it works again. Mine had the same problem, I called Trinity and they where aware of some units having this problem, I sent it back and they sent me back a brand new one with new software. So contact Trinity they will sort you out.
Associated TC6.1 | Hobbywing V3 | LRP X12 | Spektrum | Futaba | Reedy
coons88 is offline   Reply With Quote
Old 09-30-2007, 10:08 PM   #278
Jake S's Avatar
i haven't used it since saturday, its been sitting for about 24 hours...it looks like its getting alittle better, maybe it just needs to sit for longer??
Old 10-01-2007, 10:02 AM   #279
barber's Avatar
is their any way to reset this discharger.
BARBER SHOP RACING.
Old 10-01-2007, 10:56 PM   #280
Trader Rating: 31 (100%+)
Hi Guys,
I got the chance to use both the DPD and CTX-D2 this past weekend and found them very comparable. Has anyone here used both as well? Could you share your experience and why you went with the DPD? I found the DPD gives more information, but it seems to take longer to discharge. Also, I didn't get to use the linear discharge feature. Does it stop discharging at 5 amps after one cell reaches .9v, like the 30 amp pulse does? Any help is appreciated. I'd really like to pick one of these up soon as I've already ruined two new packs by discharging on my Integy 30AMP discharger (stick pack type). Also, what's the deal with the black DPD vs. the Purple?
Thanks!!!!
ittjv is offline   Reply With Quote
Old 10-01-2007, 11:03 PM   #281
magm20001's Avatar
5amp linear works the same way.
black and pruple works exactly the same
the groove for the battery is a little deeper on the black version to fit the larger cells. but i never felt the need for it on the purple version
Old 10-02-2007, 07:23 AM   #282
Originally Posted by ittjv View Post
snip... Also, I didn't get to use the linear discharge feature. Does it stop discharging at 5 amps after one cell reaches .9v, like the 30 amp pulse does? Any help is appreciated. I'd really like to pick one of these up soon as I've already ruined two new packs by discharging on my Integy 30AMP discharger (stick pack type). Also, what's the deal with the black DPD vs. the Purple?
Thanks!!!!
I am not sure if I have read your question right but my DPD discharges all cells individually down to .9v on both linear and pulse modes. Ie it does not stop until job done!
yellowshark is offline   Reply With Quote
Old 10-02-2007, 07:38 AM   #283
Originally Posted by Island Losi View Post
how did u go about restorin these packs to good form?
I'm no expert but I have got some poor 4200 and 3800 packs back to IR in the 'teens by a few cycles of Pulse discharge and charging at 5.5 amps. There will probably be a particulalry bad cell in there. Keep an eye on it. Sometimes it shifts after 2 or 3 cycles; if not I guess that's when you decide the cell is duff.
Old 10-02-2007, 07:53 AM   #284
Island Losi's Avatar
thanks everyone
Yokomo|SpeedPassion|McgooCreative|TeamOrion|FusionPower|Futaba|Spektrum|RP|Trinity|Protoform
Island Losi is offline   Reply With Quote
Old 10-02-2007, 05:28 PM   #285
Trader Rating: 44 (100%+)
u can actually set it up to discharge all the way down to 0v ..
that's what i do with my GP3700s ..
but 0.9v cutoff is imperative for the current generation of IB4200s
YOKObori MOkei
wyl03 is offline   Reply With Quote
Re: FS Trinity Dyna-Pro Digital Discharger Benq R/C Items: For Sale/Trade 2 07-24-2008 05:50 AM
Trinity DPD Digital Discharger $90 barnacle R/C Items: For Sale/Trade 21 09-14-2007 07:47 AM
Trinity Digital Discharger $80.00! Like New chrisf608 R/C Items: For Sale/Trade 11 01-29-2007 08:52 PM
Trinity DPD digital pro discharger! Fabulous R/C Items: For Sale/Trade 9 11-11-2006 10:43 AM
