Old 01-02-2007, 01:44 AM   #241
BSchorr's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to BSchorr Send a message via Yahoo to BSchorr Send a message via Skype™ to BSchorr
TTT!
Proline ~ Genesis R/C Products ~ First Premier Satellites
BSchorr is offline   Reply With Quote
Old 01-12-2007, 12:51 AM   #242
coons88's Avatar
Send a message via MSN to coons88
I did a quick search and couldn't find an anwser, and it doesn't say in the instructions.
How do you know when the AA's are flat? Is there a warning or something? or do they just die on you
Associated TC6.1 | Hobbywing V3 | LRP X12 | Spektrum | Futaba | Reedy
coons88 is offline   Reply With Quote
Old 01-12-2007, 02:27 AM   #243
loopedeloop's Avatar
coons, mine said "system battery low" the other day.
This didnt happen until after it had cut out mid-cycle a few times though.
loopedeloop is offline   Reply With Quote
Old 01-15-2007, 08:38 PM   #244
nino_pohan's Avatar
I want to know if i use saddle pack this discharge with pulse mode will discharger each cell or pack?
nino_pohan is offline   Reply With Quote
Old 01-15-2007, 08:43 PM   #245
MikeXray's Avatar
Trader Rating: 73 (100%+)
As long as you can get a good connection on each cell in the tray you can use the internal setting, the external pack setting is for when you hook up a pack via the aligator clips.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 01-15-2007, 10:44 PM   #246
nino_pohan's Avatar
Pulse mode with intenal setting, if 6 cell batteries, 1,3,4 have 0.9v cutoff but other cell dont reach .9v is 1,3,4 cell still on .9v (Cell hold voltage)?
Old 02-17-2007, 03:01 PM   #247
Ericjooopuntnl's Avatar
I know in the US everybody drives still 6 cells but are there any European drivers who already have solved the 5 cell-problem with de DPD? Just external discharging i can also with my Team Orion charger.....
Anyone??
Eric
Ericjooopuntnl is offline   Reply With Quote
Old 02-18-2007, 12:07 AM   #248
Works perfect.
vassago is offline   Reply With Quote
Old 02-19-2007, 12:55 PM   #249
mha
I can't believe that vassagos solution really works. The DPD discharges in 2 stages. Remember? 1st stage is the full pack 5A linear or 30A pulsed that discharges the whole pack until the first cell hits the selected cut off voltage. Then it reverts to the 2nd stage which is a single cell discharge at approx. 1.5 Amps.
Vassagos solution is equivalent to a 6 cell pack with cell 1 being dead (0 Volts, internal short). So what I reckon is going to happen is that as soon as the discharge is started cell 1 jumps to "done!" as it is always below the cut off. Then stage 2 individually discharges the other 5 cells, but only at 1,5 Amps.
@vassago: Please do a litte experiment: take an empty 5 cell pack and exactly charge it to let's say 2000mAh (5A charge current, 24 minutes charge time). Then put it on the DPD and measure the time until the first cell in the pack says "done!". Then measure the time it takes for all cell (i.e. the last one) that says "done!". Please report the times here. Thanks a lot.
MHA
mha is offline   Reply With Quote
Old 02-21-2007, 04:31 AM   #250
No need to test this, internally it only does linear discharge for 5 cells of course.
If you want the pulse discharge you need to do that externally.
Old 02-27-2007, 08:51 AM   #251
James35's Avatar
Overall, I like my DPD with the one exception, it's pretty slow. One day, 30 minutes into equalizing, I accidentally hit one of the levers and had to restart. 47 minutes later, it was done.
James35 is offline   Reply With Quote
Old 09-28-2007, 07:04 PM   #252
barber's Avatar
my discharger is taking over 2 hrs sometimes more to discharge a pack and
no2 cell is stayin at 1.2v all the rest go to .09 any one else have this prob.
BARBER SHOP RACING.
Hara Cyclone Edition,MAMBA 7700KV,Spectrum,
Mazdaspeed 6 Painted By McGoo Creations,
JR Z1,Orion 4300Mah,Ib 4200Mah,Ice,Rp,Trinity.
Race Prepaired & Driven By TEAM DRIVER (BARBER)
barber is offline   Reply With Quote
Old 09-28-2007, 07:26 PM   #253
Trader Rating: 16 (94%+)
2hrs is about right for a fully charged pack. The Pulse discharge features runs in cycles, meaning discharge, wait (cool-off), discharge, wait, etc.... until the cells reach the set Voltage Limit.
The Linear discharge is a lower amperage, but might discharge slightly faster under some circumstances.
kn7671 is offline   Reply With Quote
Old 09-28-2007, 07:51 PM   #254
Joel Lagace's Avatar
Replace your AA batteries. I find if things are out of wack such as supper long discarge time its the AAs dying
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 09-28-2007, 10:22 PM   #255
Trader Rating: 44 (100%+)
also .. keep track of your batteries.
if your #2 cell is consistently out of whack as compared to your other cells, you might want to replace it. after all, the strength of the pack is limited by the weakest cell.
YOKObori MOkei
wyl03 is offline   Reply With Quote
Re: FS Trinity Dyna-Pro Digital Discharger Benq R/C Items: For Sale/Trade 2 07-24-2008 05:50 AM
Trinity DPD Digital Discharger $90 barnacle R/C Items: For Sale/Trade 21 09-14-2007 07:47 AM
Trinity Digital Discharger $80.00! Like New chrisf608 R/C Items: For Sale/Trade 11 01-29-2007 08:52 PM
Trinity DPD digital pro discharger! Fabulous R/C Items: For Sale/Trade 9 11-11-2006 10:43 AM
