Old 11-21-2006, 11:24 PM   #196
Originally Posted by BlueR1
i think it will be very hard to match based on "runtime" using the DPD. just because the way it discharges.
Since it discharges at 30 amps in series, untill 1 cell reaches 0.9v, then it reverts to discharging independently (equilizing) at about 1amp.
the runtime here will vary depending on how long it is discharging at 30amp.
example, if you discharge a cell at 1amp straight you will be able to extract alot more mah out of it than at 30amp straight, because the voltage will stay above 0.9v alot longer.
anyway Dasupacat, tell us your results once u rematch....
That's why the DPD is cheaper than the muchmore CTX-D. A DPD is just only the Dyna Pulse with automatic equilizer. If something can select a matching mode like CTX-D and a pack mode like DPD, it'll be the best discharger I think.
xtaiji is offline   Reply With Quote
Old 11-22-2006, 03:06 AM   #197
TheCoolCanFanMan's Avatar
This has prob been asked before, so bare with me on this one, whats the dif between the blue and the black other than its colour
Cheers Malc
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 11-22-2006, 02:12 PM   #198
RoachRacing's Avatar
Send a message via ICQ to RoachRacing Send a message via AIM to RoachRacing Send a message via Yahoo to RoachRacing
Cheers Malc
Nothing different besides the color. The black was made for team drivers at first.
RoachRacing is offline   Reply With Quote
Old 11-22-2006, 04:39 PM   #199
Old 11-22-2006, 04:52 PM   #200
Location: Coming Soon " The Further adventures of NeedleDick Nicholas"
Default blue vs black
The Black version has recesses molded into they tray so packs with the solder tabs facing down will fit better.
Coming Soon...........
The Further Adventures of "NeedleDick Nicholas"
Sponsored by Grey Goose Vodka
Allendale Bar
Special Thanks to Upscaleescorts.net
"Where the RC big dog's go"
Now with delivery service and rates for Florida
"When you screw up, You find out who yours real friends are"
If having a letter that cost you $9000.00 gets you into Harvard, I'm in too
Sarquis is offline   Reply With Quote
Old 11-22-2006, 05:39 PM   #201
Trader Rating: 44 (100%+)
wow .. didn't realise that ..
btw .. i use the DPD "pulse discharge" function all the time.
after the discharge & equalising stop, i notice that my batteries are consistently warm to touch.
not hot but just warm.
is this the same for everyone else?
very curious bcos when i was using my spintec to discharge the batts, the batts were *never* warm.
perhaps some differences in pulse discharge algorithm.
YOKObori MOkei
wyl03 is offline   Reply With Quote
Old 11-22-2006, 06:36 PM   #202
Dasupacat1's Avatar
Trader Rating: 25 (96%+)
Send a message via MSN to Dasupacat1
My batts get warm too. No biggie. compared to a string of bulbs, they would get hot.
Dasupacat1 is offline   Reply With Quote
Old 11-28-2006, 03:26 AM   #203
BlueR1's Avatar
anyone tried 5 cell internal yet?
BlueR1 is offline   Reply With Quote
Old 11-28-2006, 03:46 AM   #204
cannon's Avatar
Trader Rating: 35 (100%+)
Dont think you can do 5 cell internal... only 4 or 6 cell. Can only do 5 cell external
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 11-28-2006, 04:11 AM   #205
Haven't tried yet, but should be possible atleast using a dummy cell with a battery bar. Don't think it would work with only 5 cells.
I got mine last week and have only used it few times. Great piece of equipment.
Finnitro is offline   Reply With Quote
Old 11-28-2006, 04:25 AM   #206
Joel Lagace's Avatar
No it doesnt do 5 cell or 6 individual loose cells either..
To get 5 cell or in my case i wanted to dump 6 loose cells i had to lay battery bars across the appropriate terminals to get it to turn on, unfortunately the IR goes through the roof doing that so ignore your numbers if you do this
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 11-28-2006, 07:30 AM   #207
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
you only have to bridge across the empty slot though ? yes /no??
thus that empty slot where the 6th cell went ,which is where you bridge the gap with bar only the 5th cell goes through the roof ??(with me here ??) re IR
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 11-28-2006, 08:16 AM   #208
BlueR1's Avatar
the problem i see with using dummy cell is that dummy cell will need to be charged, otherwise the DPD will go straight into the 1amp equilizing mode...
damm. i hope they come out with a 5 cell version....
also one that can discharge with the +ve on the bottom left in cell#1
Old 11-28-2006, 03:28 PM   #209
James35's Avatar
I have 2 questions. It's apparent that this does 2 stage discharging. From what I'm reading, the second stage does do individual discharging to the desired cutoff. Does the DPD take this second stage individual discharging into account and adds the results to stage one, giving you the proper math?
Secondly, I use Trinity's R-Minus bullet connectors.
Can this accomodate for the large connectors and still establish good connections with the other cells?
James35 is offline   Reply With Quote
Old 11-28-2006, 04:15 PM   #210
BlueR1's Avatar
yes it adds stage2 onto stage1. when stage 1 is finished, and you can tell when its done, the fans stops spinning, and if u take off the pack, the runtime/mah are all the same
i use them bulltet plugs aswell, however i use a L-bar and then put the female tube on top. Its just much easier to hold the cell in place, and get better readings
Re: FS Trinity Dyna-Pro Digital Discharger Benq R/C Items: For Sale/Trade 2 07-24-2008 05:50 AM
Trinity DPD Digital Discharger $90 barnacle R/C Items: For Sale/Trade 21 09-14-2007 07:47 AM
Trinity Digital Discharger $80.00! Like New chrisf608 R/C Items: For Sale/Trade 11 01-29-2007 08:52 PM
Trinity DPD digital pro discharger! Fabulous R/C Items: For Sale/Trade 9 11-11-2006 10:43 AM
