Old 11-06-2006, 04:28 AM   #151
Joel Lagace's Avatar
No you cannot, because once its collecting data its initiated the discharging loads. Hooking up a charger and charging at the same time would result in the pack having a constant load. And your charger would could get damaged from the discharging load..
Good idea if only it could. IF it logged data while just being powered on that could be an option but the data logging only happens when its discharging.. Sounds like your in the market for a SPINTEC charger
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 11-06-2006, 04:32 AM   #152
Hey Joel thanks for getting back to me. I know you can do this with the ctx from Much more.
cyrrus is offline   Reply With Quote
Old 11-06-2006, 06:55 AM   #153
kcrunchone's Avatar
Thumbs up
MHA
thanks for the advice I am a bit more aware of the batt. status now and will do the charts with the new cells that I am getting and keep 2 of the best of the 3300 packs for practice.
For me the DPD is a huge success and a break through even for a new comer to electric like myself. Not bad at all.
Rick Hill
"Failure Is Not An Option"
kcrunchone is offline   Reply With Quote
Old 11-06-2006, 12:35 PM   #154
Looks like a good unit, but you guys in Europe and other countries going to 5 cells might want to make sure it can discharge 5 cells in the tray.
Instructions only say 4 or 6.
Can anyone confirm?
Keyz is offline   Reply With Quote
Old 11-06-2006, 01:10 PM   #155
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
Is the NEW black one any different form the blue one ??
answer is not the colour either ,so no be funny
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 11-08-2006, 07:32 AM   #156
When do you guys discharge your NIMH packs?
I plan to use my packs once a week 2 or 3 times a day.
Would you discharge / equalize at the end of each run or at the end of the race day..
I've been reading and told that you dont need to discharge after each run?
mcgmark is offline   Reply With Quote
Old 11-08-2006, 08:50 AM   #157
"Spanky's Avatar
You should discharge the pack after every run. The plates in the battery will build up crystals causing higher internal resistance. I highly recommend the TEAM MUCHMORE CTX-D2. Visit their website at www.teammuchmore.com
and check it out. By ensuring you batterys are all equally discharged
and keeping the internal resistance down to a minimum will allow for better
charging (meaning maximum amount of current storage and higher voltage levels) I didn't think there would be much of a difference until I tried it for myself and found 3800 packs peaking out at 9.64volts with over 4000mah. If anyone thinks otherwise you can use OHMS LAW and you will see that higher resistance means less current available for your motor.
Brendan a.k.a. "Spanky"
TEAM LOSI 22SCT ..... 22T 2.0 ..... 22 2.0
Orion----Promatch Racing----Spektrum---Proline---Island Raceway
"Gone But Not Forgotten" --- RC10T, RC10T3, RCTc4, XRay007, XXT, XXTcrGraphitePlus, XXXT, XXXTMF, XXXTMF2----
"Spanky is offline   Reply With Quote
Old 11-08-2006, 09:06 AM   #158
XrayFK's Avatar
I don't know if you are implying whether 9.64 is a relatively low or high voltage, but you actually want a lower peak voltage when charging, that means lower IR. My 4200WC packs peak at around 9.1v
XrayFK is offline   Reply With Quote
Old 11-08-2006, 09:17 AM   #159
"Spanky's Avatar
Again I repeat, anyone who disagrees can use ohms law to find out for themselves. If you run a motor at 2 volts and then at 12 volts, when does it spin faster????????????????????? And what is your ma reading?????????????????
Old 11-08-2006, 09:37 AM   #160
Suspended
Trader Rating: 28 (100%+)
I am not claiming to know why its better but FK is correct.The lower your battery voltage peaks{not false peaks} at the better the battery.9.6 sounds like your battery maybe on its way out.
racenut123 is offline   Reply With Quote
Old 11-08-2006, 10:35 AM   #161
"Spanky's Avatar
Old 11-08-2006, 10:36 AM   #162
Dasupacat1's Avatar
Trader Rating: 25 (96%+)
Send a message via MSN to Dasupacat1
I thought I read somewhere on the Promatch site where they said not to discharge after every heat if you plan on using 2 or 3 times a day. Just chargem back up after they cool back down. Something about less strain on a battery. Do you know something they don't?
Dasupacat1 is offline   Reply With Quote
Old 11-08-2006, 11:55 AM   #163
Trader Rating: 40 (100%+)
Send a message via AIM to brians11
Yes, the theory of V=IR (Ohms Law) is correct...
charge current (I) is a constant, so for voltage to be higher, the resistance of the cells must be higher as well...
Team Tekin | Superiorhobbies.com
brians11 is offline   Reply With Quote
Old 11-08-2006, 12:31 PM   #164
XrayFK's Avatar
I love being right
Old 11-08-2006, 12:51 PM   #165
"Spanky's Avatar
this is hilarious, do me a favor and charge your batteries and take a piece of wire with no resistance and place it across the battery terminals hahahaha. I need to delete this forum so I don't feel so stupid from reading these replys.
NO MATTER HOW MUCH RESISTANCE IS IN A CIRCUIT, VOLTAGE REMAINS THE SAME. Go to this website and put in the voltage then raise the resistance and see what happens, ohhhhhhhh wowwwww look at that!!! the more resistance the less current meaning less power for your motor http://micro.magnet.fsu.edu/electromag/java/ohmslaw/
Re: FS Trinity Dyna-Pro Digital Discharger Benq R/C Items: For Sale/Trade 2 07-24-2008 05:50 AM
Trinity DPD Digital Discharger $90 barnacle R/C Items: For Sale/Trade 21 09-14-2007 07:47 AM
Trinity Digital Discharger $80.00! Like New chrisf608 R/C Items: For Sale/Trade 11 01-29-2007 08:52 PM
Trinity DPD digital pro discharger! Fabulous R/C Items: For Sale/Trade 9 11-11-2006 10:43 AM
