Old 07-25-2006, 07:16 AM   #91
Trader Rating: 38 (100%+)
Originally Posted by or8ital
AdrianM, can you ask your friend if he needed to make any changes to get it to work on the RDX? I posted the problem on the RDX thread and others confirmed the rims hit the A-Arms when turning. It is just very slight but enough to send your car spinning-out on a tight turn.
Hey AdrianM did you ever ask your friend what he needed to do to run the take off tires on his RDX? They definately dont fit on the front when your turn. It rubs against the A-Arm.
or8ital is offline   Reply With Quote
Old 08-07-2006, 10:15 PM   #92
RacingStorm's Avatar
AdrianM, hate to ask but what tire would you recommend for the Tamiya track in the September time frame (KO Race). I'm leaning to Sorex 36Rs but am curious about the RP36s. Medium/Firm insert on either one. Sound about right?
RacingStorm is offline   Reply With Quote
Old 10-03-2006, 08:08 AM   #93
maximebeauvais's Avatar
Trader Rating: 6 (88%+)
ING tire? are they good?
someone told me that it was good and pretty cheap price.....
however I can't find them
maximebeauvais is offline   Reply With Quote
Old 10-30-2006, 03:14 AM   #94
Thraex's Avatar
I have a small question about the tire wear of the RP30 tires.
I normally run the CS27 tire and they are long lasting (I can drive the whole winterseason on 2 to 3 sets), But I'd like to try the RP30's.
I know they are more designed for racing so they won't last as long as a CS27, but can someone tell me how long they last on carpet (couldn't find an answer on the board)?
It should be more than on asphalt (4 to 8 runs).
Thijs van M[HPI/HB]
Thraex is offline   Reply With Quote
Old 11-03-2006, 01:15 PM   #95
RaceAce701's Avatar
Trader Rating: 86 (99%+)
Hi im looking at getting some sorex tires to run on my local Carpet track
it is ozite with medim to hight traction
what tire compound will provide the best grip with the longest life 24,28,32
and what about insert soft, med, firm - super thin, thin, thick ???
Im new to rubber
any direction would b great thanks
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 12-21-2006, 02:19 PM   #96
Just found this thread.
Great info on CS / RP tires.
Thanks Adrian
Itchy is offline   Reply With Quote
Old 12-21-2006, 06:51 PM   #97
losi guy's Avatar
Send a message via ICQ to losi guy
Im new to rubber
I run sorex tires and for med-high traction i would use 28r and i use the red hpi inserts. 24's wear to quick but work good for low traction with same insert.
Spektrum | Avid | DE Racing | Tekno
losi guy is offline   Reply With Quote
Old 12-21-2006, 07:53 PM   #98
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
Originally Posted by AdrianM
The nylon rims are also more flexible (thats why they are faster).
why does a flexible rim make it faster? does a flexible rim generally generate more traction than a stiff one? thats the area i am not a 100% sure on ... all things being equal (tire, insert), will a more flexy rim give more traction vs a rigid one? and will one type generate more tire heat? where would you use one type of rim vs the other?
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 12-21-2006, 08:04 PM   #99
lem2's Avatar
another thing to add or ask. . . . . .
if the nylon rims are flexible. . . . .
Will it will loose it's "true" / "balance" after several runs????
thereby causing a wobbling in the wheel later on???
lem2 is offline   Reply With Quote
NEED help with rubber tire ? spy Electric On-Road 2 05-23-2008 11:59 AM
Rubber tire car - 008 EU or an MI3 RBLove R/C Items: Wanted to Buy 0 04-28-2008 05:42 PM
Rubber Tire Lot, new and used dmayhew25 R/C Items: For Sale/Trade 11 11-04-2005 12:40 PM
TOP 1/10 Rubber Tire topgluer Electric On-Road 9 10-15-2005 04:07 PM
Rubber Tire vs. Foam Tire on Carpet dizzy1 Electric On-Road 34 06-07-2005 02:51 PM
