Old 05-25-2006, 07:46 AM   #1
SlamMan's Avatar
Default Racing Class Breakdown? (eg. Stock, Mod, ect.)
What differentiates the classes of on road racing?
Is there a newbie faq on RC somewhere?
SlamMan is offline   Reply With Quote
Old 05-25-2006, 07:48 AM   #2
sosidge's Avatar
Best thing to do is to get down to your local track and see what they run there.
In electric touring, the main difference in classes is the motors used. Chassis and other electronics tend be to the same. But you may find that your local track has it's own special rules.
Old 05-25-2006, 07:54 AM   #3
SlamMan's Avatar
So it's usualy just motor differences? I'm lost on the different types of motors. I keep reading about 19 turn, brushed, brushless and I have no idea what this stuff is. Is there a breakdown or faq on motors somewhere. What makes a motor stock or mod?
Old 05-25-2006, 07:58 AM   #4
tallyrc's Avatar
i'll do some searching, if i can't find anything, i'll write one up myself later tonight... check back later.. unless someone beats me to it..
WWW.STORMERHOBBIES.COM helping keep pan cars alive!
Turns out not where, but who your with that really matters... DMB
tallyrc is offline   Reply With Quote
Old 05-25-2006, 08:10 AM   #5
Still Bill's Avatar
If you intend to race, you might want to go to the ROAR website for their list of approved motors.
In general, 1) "stock" motors have 27 turns of wire on each segment of the armature and fixed timing; 2) 19 turn motors have 19 turns of wiring and fixed timing; and, 3) "modified" motors have fewer turns of wire with variable timing.
For racing, you want to start with stock and progress to the other motors as you advance your skills.
But, do check with your local race track for what motors may/may not be approved for racing. It varies as well as the batteries allowed sometimes.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 05-25-2006, 08:23 AM   #6
burbs's Avatar
Send a message via AIM to burbs Send a message via Yahoo to burbs
Stock motors are your basic motors.. They have bushings instead of bearings and are the slowest.. Stock class ranges from etry level racers up to pro's..
19 turn is a little faster then stock.. it is kind of the middle ground between stock and mod..
Modified is where all the top level guys tend to race.. This is the fastest class, and generally the hardest.. These guys are wicked fast.
Brushless is the same sspeeds listed above, depending on your motor choice,.. A brushless is just that.. it is a motor with nu brushes,.. standard motors require more maintinance, and parts need to be replaced alot more often..
burbs is offline   Reply With Quote
Old 05-25-2006, 08:49 AM   #7
SlamMan's Avatar
I'm not totally clear on the part about brushless motors in your post, Mike. Can I get a brushless motor in stock or just in mod? I like the idea of low maintenance.
Old 05-25-2006, 05:56 PM   #8
tallyrc's Avatar
brushless motors come in several flavors, some as fast as modifieds, some as slow as stocks... brushless are extremely low maintenance, but are not legal in many racing venues unfortunately.. regular brushed motors require regular maintenace to run efficiently, and fairly diligent maintenance to be ideal.
Old 05-25-2006, 06:46 PM   #9
Send a message via MSN to ickvanovs
i understand about number of turn in the armature but i got no idea about timing. can someone explain it a bit more?
thx
ickvanovs is offline   Reply With Quote
Old 05-25-2006, 11:09 PM   #10
Super Moderator
Grizzbob's Avatar
No, if you want to run a brushless motor, then you'll pretty much have to run in mod. Even though there is a brushless motor that's not far off in power from a stocker, it's still NOTICABLY more powerful(& most DEFINITELY has more torque) than any good ROAR-legal stock, so for the most part, all tracks I know of only allow brushless in mod class....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 05-26-2006, 10:37 AM   #11
SlamMan's Avatar
Ok, thanks, Grizz. I'd be interested in ickvanovs' timing question too if anyone has some input.
ROAR stock class winner out of stock for 5 years... or8ital Electric On-Road 188 01-23-2008 08:58 AM
What stock for truck class?. Badmuthatrucker Electric Off-Road 11 05-07-2007 04:44 PM
stock class racing b-man777 Electric On-Road 5 03-13-2007 11:29 AM
Brushless vs Brushed stock class racing Poweredbysbc Northwest Racers 212 09-13-2006 04:25 PM
BRUSHLESS STOCK in STOCK CLASS. charlie_b Electric On-Road 208 01-22-2004 12:30 AM
