Old 05-24-2006, 06:11 PM   #1
Default HELP! Rear toe-in
What is the major difference on a 2 Degree and 3 Degree rear toe-in? specially, how does the car perform at the corner under these two settings?
Miu Miu is offline   Reply With Quote
Old 05-24-2006, 06:23 PM   #2
geeunit1014's Avatar
with 2*, the car will have more steering, but teh rear end will come around more (loose) with 3*, the rear end in more planted, but the car has less steering (tight)
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 05-24-2006, 06:44 PM   #3
AngryAsian's Avatar
Add to that that, more toe in increase initial steering. More toe stabilises car by making the rear end want to steer out of a slide.
Also, the more toe you run, the more drag on a car down the straight as the tires are scrubbing inwards. Changing the toe can increase your speed to a noticeable degree. Try changing it in small increments. Usually half a degree..
Use as little as you can get away with.
And er.. why do you call yourself "Miu Miu"? LoL!!.. i assume you're a guy. (isn't everyone a guy here?)....Should it be "Gor gor"?
AngryAsian is offline   Reply With Quote
Old 05-25-2006, 11:23 AM   #4
i guess u r asian..right? miu miu is my dog's name....thanks for your info. let me try the diff. rear toe. my car is lack of steering after the apex
Old 05-25-2006, 01:32 PM   #5
Rick Worth's Avatar
Taking away front droop will help with on-power steering.
Rick Worth is offline   Reply With Quote
Team Losi 8ight Front and Rear Chassis Braces and KingHeadz Rear Toe meon99 R/C Items: For Sale/Trade 14 07-23-2008 09:24 PM
Assocaited B3 Rear Rims, T3 Rear Chassis Plate, Front Chassis Brace Hawk6 R/C Items: For Sale/Trade 5 09-04-2007 07:34 AM
3 xxx-nt rear a-arms and a rear shock tower f/s xxx-ntad2 racer R/C Items: For Sale/Trade 2 11-22-2006 03:45 PM
Urgent, Need Rear MBX5 rear shock body Izze-Racing R/C Items: Wanted to Buy 0 04-16-2006 03:48 PM
japanese trend, rear body posts in front of rear wheels? floodo1 Electric On-Road 13 11-19-2005 07:20 AM
