Old 05-24-2006, 11:44 AM   #1
Trader Rating: 38 (100%+)
Default Brushless Motor Temp
Im trying to gear my RDX for use with Novak 4300 brushless motor and a Sphere competition ESC. I was told by the local fast guy they run at a 1.2 rollout so I did that. Ran my car for about 3 min to check the temp of everything to make sure I wasnt over gearing it. The motor was around 120-130 and the ESC was about 95. Is that too high? I thought it was the ESCs that ran hot with brushless?
Thanks in advance.
or8ital is offline   Reply With Quote
Old 05-24-2006, 11:52 AM   #2
Ollie RDX's Avatar
Send a message via MSN to Ollie RDX
Thanks in advance.
I ran the Nosram Matrix (when you get this esc good he's better then the evo or competition version!) and he never comes hot! The 4Star Brushless motor of Nosram has somethin about 20-30C here! The 5 Star has the same temperature! But the novak brushless systems and motors are not good! They break allot!
Greetings Ollie
Ollie RDX is offline   Reply With Quote
Old 05-24-2006, 12:07 PM   #3
syndr0me's Avatar
Trader Rating: 32 (100%+)
Thanks in advance.
I roll mine out around 28.5-29MM in my RDX. We run on a small, tight carpet track. It comes off the track hot as hell, but it doesn't thermal. I'm not even running the fan on the ESC, it just doesn't get very hot with the 4300. I don't know exact temps though, sorry. :-(
syndr0me is offline   Reply With Quote
Old 05-24-2006, 12:21 PM   #4
Well thats a 1.15 rollout in inches so maybe I will back it off a tooth or two.
Would a thermal shutdown cause any lasting damage? I guess I could keep changing gears until it happens and then back off one tooth. I assume the Sphere Competition has thermal protection.
Old 05-24-2006, 12:36 PM   #5
Ollie RDX's Avatar
The end ratio of my brushless on a large track 6.0 to 6.5 and on a short and fast track something about 7.5 to 8.5
Greetings Ollie
Old 05-24-2006, 11:25 PM   #6
ottoman's Avatar
R/C Tech Charter Subscriber
With the 5.5 or 4.5 were shoot for motor temp of 140-160 degrees.
No, the thermo shutdown wont hurt the motor or speedo... thats what its for.. to protect you from overheating the unit.
When we ran the 5800 outdoors we put on a big fan on the ESC and geared it until it thermo'd and backed it off a tooth. They seem to run faster the more gear you throw at them.
ottoman is offline   Reply With Quote
Old 05-25-2006, 04:59 AM   #7
Send a message via AIM to RcCzarOfOld Send a message via MSN to RcCzarOfOld Send a message via Yahoo to RcCzarOfOld
If it's coming off the track at 120 to 130F, then go up a tooth. You've got another 50 degrees to play with before it thermals.
Ollie, I don't know how you can say that the Nosram/LRP stuff is BETTER than the Novaks. EVERY Reedy Star motor I've seen has blown the rotor apart inside the can. But on the Novak, I don't know anyone personally that has had any problem with them.
RcCzarOfOld is offline   Reply With Quote
Old 05-25-2006, 09:37 AM   #8
Trader Rating: 198 (100%+)
That does seem to be the ticket. Gear it until the motor thermals and then back it off a tooth. We did this with the 4300 motor for carpet.
I ran my 5800 in the Pro4 on the track and it was a blast and had great speed and rip. I am really starting to like the BL on a big outdoor track
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 05-25-2006, 09:43 AM   #9
Ollie RDX's Avatar
in Belgium the Novak motors and ECS burns like gasoline! Its not normal man its really crazy al the novak brushless systems i saw in Belgium started to get fire on the track really crazy shit!
Greetings Ollie
Brushless motor max temp GSM Storm Electric Off-Road 8 07-16-2011 07:35 PM
motor temp Flying Monkey Electric Off-Road 8 05-15-2008 08:35 AM
Motor temp? Racingfreak6 Electric On-Road 15 08-29-2006 10:22 PM
WTT: XTM 24.7 motor for temp gun nitro2go R/C Items: For Sale/Trade 0 04-18-2005 02:12 PM
