Old 10-27-2001, 07:27 PM   #1
Aurra Sing's Avatar
Default Timing
I was told to buy a 9x3, so i did. I guess they didn't know I only had Nuclear Power 2400's.. so they dumped at 4:00 minutes exactly. I asked a good helpful person how to change my timing for more run time before the mains, and that made my run time 4:30 in the mains (would have finished second, but they passed me on the last laps before the packs dumped.. finished 3rd. in Expert Mod)
Is it okay to change my timing all the way down to the dimple or below? Or will i experience excessive comm wear, short motor life, etc. I will eventually buy a 11t or 12t soon (don't want to buy new batteries) but i want to use this in the mean time.
Aurra Sing is offline   Reply With Quote
Old 10-27-2001, 07:32 PM   #2
Manticore's Avatar
R/C Tech Charter Subscriber
Default Re: Timing
you better buy a higher turn motor rather then twist it on the timing as this wont help much on run time.
Manticore is offline   Reply With Quote
Old 10-27-2001, 09:16 PM   #3
Trader Rating: 69 (100%+)
you can put the timing back to zero. just dont dial it to negative timing. i think negative timing will wear down the comm and brushes much faster.
marvi is offline   Reply With Quote
Old 10-27-2001, 09:20 PM   #4
Manticore's Avatar
negative timing is for running the motor in reverse direction of rotation!
Old 10-27-2001, 09:35 PM   #5
yup. for rc's that use reverse rotation (ie. the rear motor of a clodbuster), you can use negative timing. but youll also have to reverse the polarity of the motor to make it move forward. you can either switch the + and - wires or turn the endbell 180 degrees.
Old 10-27-2001, 11:21 PM   #6
Rog
What gearing are you running? Try to run a smaller pinion. Start with at least 2 teeth smaller. THis should buy you some time. If you're running on a large flowing track, you're probably gonna have to get a motor with more winds. I run 2400s with my Reedy Ti 11x2 on a med-sized, fairly technical track and can get at least 6 or 7 minutes.
Rog is offline   Reply With Quote
Old 10-28-2001, 06:48 AM   #7
Aurra Sing's Avatar
I use 128/30 on my TA04R. I plan to get an 11x2 or 11x3 soon, but I want to change the timing just for now.
Lap Timing Systems yyhayyim Electric On-Road 113 07-25-2014 01:08 AM
timing racing_jason Electric On-Road 1 08-31-2008 06:04 PM
Difference b/tween ESC timing and timing on motor? Loverc Electric On-Road 8 04-11-2008 05:45 PM
timing dozer1160 Electric Off-Road 5 04-22-2007 08:57 PM
AMB Lap Timing AJunkie_02 Malaysian R/C Racers 10 09-02-2003 03:23 AM
