Old 05-21-2006, 09:03 AM   #1
Default 190mm trans am?
I saw some 200mm trans am bodys but cant seem to find any 190mm bodys. its gonna go on a xray t1evo 2. any help would be appreciated! Thanks
RCkid16 is offline   Reply With Quote
Old 05-21-2006, 09:11 AM   #2
Try looking here. They carry most of the older car bodies.
http://www.parmapse.com
John Warner is offline   Reply With Quote
Old 05-21-2006, 07:09 PM   #3
Essnowyt's Avatar
Send a message via AIM to Essnowyt
HPI Makes the Trans Am. However they do not make it in 190mm.
Snowy.
Team XRay, RCAmerica, Motiv, Gravity RC, Schacht Design Works.
Drive it, Dont slide it!
Essnowyt is offline   Reply With Quote
Old 05-21-2006, 07:10 PM   #4
yeah i saw they had 200mm but i need a 190mm
Old 05-22-2006, 12:21 AM   #5
wagonman72's Avatar
Just get the HPI vintage series wheels and tires to go with the body. There are several different widths and offsets and they look great.
wagonman72 is offline   Reply With Quote
Old 05-22-2006, 03:13 PM   #6
TryHard's Avatar
could try here.
http://www.mcallisterracing.com/racing/page4.html
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 05-22-2006, 03:46 PM   #7
andyh's Avatar
Default 190-200mm
Use the HPI Vintage wheels which are 26mm front and 31mm rear. Or any other wheels that have a built in offset to them.
The difference between a 190 and 200mm body is actually very small (ie. only 5 mm wider on each side at most).
Use hex wheel spacers between the wheel and the hex hub, also use a thin wheel nut like the HPI thin wheel nut.
Kawahara also makes M4 wheel nuts (standard wheel nut size) that doesnt use a nylock element but has serrated flanges (ie.it's thinner and it actually tightens up as it tries to loosen itself up, the serrations dig in to the wheel etc)
The Kawahara one's are aluminum/anodized or you can get steel one's from http://www.vxrracingusa.com/prodM_acce_NFS-0004.htm
The vxr one's are just like the regular nut and bolt place one's but they will do the job. These are awesome for nitro cars, as you're wheels will never accidentally come off, I use them on the front wheels of my electric TC when I'm running a spool.
Note: I actually work at hpiracing usa, graphic designer etc. I make decals, logos boxes etc. I also paint and prepare a lot of our show bodies. And whenever we are short of 200mm display chassis, we use the afforementioned parts (spacers, thin wheel nuts, offset wheels) to build up our display chassis/body.
AH
andyh is offline   Reply With Quote
WTB RC4WD R2 TRANS jd267 R/C Items: Wanted to Buy 0 08-06-2008 07:16 PM
xxxt rtr trans vs mf2 trans CBRRIDER Electric Off-Road 9 09-06-2007 09:34 PM
trans. jts5555 R/C Items: Wanted to Buy 0 06-14-2007 04:20 PM
trans. jts5555 R/C Items: Wanted to Buy 0 06-12-2007 07:07 PM
bk2 with bk1 trans Jeremy Blair R/C Items: For Sale/Trade 7 05-01-2006 02:39 PM
