Old 05-21-2006, 08:05 AM   #1
Excessive vibration on yokomo BD
Excessive vibration
Any ideas what would cause excessive vibration on a Yokomo BD when turning left or right?
yoko is offline   Reply With Quote
Old 05-21-2006, 08:18 AM   #2
kylehirano's Avatar
Trader Rating: 14 (100%+)
Turn down your left and right steering endpoints. Having your steering set to sharp will cause the cvds to make a bad vibration, this happened to me on my Yokomo SD, just decrease the amount of steering throw from left to right.
kylehirano is offline   Reply With Quote
Old 05-21-2006, 08:18 AM   #3
X2
X2's Avatar
Turn your Steering throw down, when the front wheels turn and bend the front CVD's they get to a certain point where they loose there effeciency and cause vibration. Turn down your EPA, its common on all cars.
X2 is offline   Reply With Quote
Old 05-21-2006, 08:33 AM   #4
if i turn it down to the point that the vibration stops i have very little steering.
any ideas?
Old 05-21-2006, 09:10 AM   #5
X2
X2's Avatar
A little vibration is normal and i wouldnt worry about it. I dont have a BD so cant comment on how much steering you should have.
Old 05-21-2006, 11:26 AM   #6
JayL's Avatar
if you are running a spool that will cause it and no fix..
JayL is offline   Reply With Quote
Old 05-21-2006, 01:24 PM   #7
yes i am running a spool, so does that mean turning steering rate down wont help?
will the vibration cause any problems?
Old 05-21-2006, 03:46 PM   #8
kylehirano's Avatar
You should check your steering hub, look to see if they are cracked or broken, they crack pretty easily, this will cause a vibration as well, I recommend the composite steering hubs, also if your running a spool you should run steel drive bones and universals up front the aluminum bones will not hold up to the stress a spool puts on your drivetrain. Also make sure you have your tires mounted nice and snug to the hex mount. Check your tires as well for proper balance. I still think turning down you end point adjustment (EPA) is your problem. If you still are having problems, check your set-up to what the instructions say.
Old 05-21-2006, 04:00 PM   #9
kylehirano's Avatar
Ditch the spool and drop the one-way back in. Some people are believers in the spool but theres a reason manufactures like Tamiya and Yokomo dont sell spools there hard on your drivetrain, and really are only needed in certain types of tracks. Personally I prefer the one-way or a regular diff.
Old 05-21-2006, 04:40 PM   #10
JayL's Avatar
first make sure nothing else is wrong like bent dogdone etc..
If you really need a spool, my track does, then try turning down steering but you mnight find you have to live with it alittle to get full steering..chatter is just a fact of life with spools..
Old 05-26-2006, 05:49 AM   #11
Smile
Vibration Gone...... i stripped down rear dif cleaned and regreased and vibration has gone.
Putnam excessive force mod motors slufoot78 R/C Items: For Sale/Trade 3 01-06-2007 08:18 PM
414 M2 excessive steering play TRFTIM Electric On-Road 2 12-10-2006 03:02 PM
Wheel and tire vibration MK_Arbiter Electric On-Road 5 05-26-2006 02:36 PM
RC10T w/ bad rear vibration and slop Thumper Electric Off-Road 1 02-06-2006 07:52 PM
