Old 05-20-2006, 04:18 AM   #1
nikkiesteban's Avatar
Send a message via Yahoo to nikkiesteban
Default linear or burp charging??
which charging is for competition??
i know that linear charging mehod is used for competition
and burp charging is good for old packs to regenerate some power..
but as of charging which method is much powerful??
which delivers much punch??
nikkiesteban is offline   Reply With Quote
Old 05-20-2006, 10:46 AM   #2
XrayFK's Avatar
Depends what kind of cells you are charging. Newer cells like the IBs, stick with a linear charge.
XrayFK is offline   Reply With Quote
Old 05-20-2006, 12:09 PM   #3
Linear charging for NiMH cells like the IB and GP cells for sure.
By "burp" do you mean reflex or negative pulse? if so that was designed for Nicad and should not be used with NiMH.
If your charger has step charge function like the I.C.E. you can try that as an option as well for competition.
jeffb is offline   Reply With Quote
Old 05-20-2006, 03:40 PM   #4
what i mean is flex or linear... ahehehehe
which is much better??? now for new cells...
Old 05-20-2006, 03:51 PM   #5
Superkarter's Avatar
Linear
Superkarter is offline   Reply With Quote
Old 05-20-2006, 03:53 PM   #6
PitCrew's Avatar
For ANY NiMh cell, use ONLY linear charge. DO NOT use flex.
Flex is for NiCd ONLY.
PitCrew is offline   Reply With Quote
Old 05-20-2006, 03:59 PM   #7
oh ok... thanx..
OS Speed Piston/Linear uniquexme Onroad Nitro Engine Zone 50 03-06-2007 06:06 AM
linear or pulsed charging tn350z Rookie Zone 17 01-07-2006 07:41 AM
Step charging or Linear? dmayhew25 Electric On-Road 0 09-28-2005 10:34 PM
Linear Or Step Charge DIMO Electric On-Road 14 06-26-2005 12:24 PM
Linear/ Pulse charging Crashmaster Electric On-Road 10 05-04-2004 03:09 AM
