TC4 oneway
Old 05-17-2006, 09:13 AM
Default TC4 oneway
does the tc3 oneway fit the tc4 ? #3978
do i have to change the outdrives ??
baih is offline
Old 05-17-2006, 09:59 AM
Kevin Boyle's Avatar
Baih,
The tranny case has not changes at all, so yes it will work on the TC4. They have improved the tranny case but not a full change. I would get the NTC3 Heavy Duty One Way it is the same price and little bit stronger.
Just make sure you are running the same color gears. They changed the material of the gears but not the pitch.
Hope that Helps
Kevin Boyle
Kevin Boyle is offline
Old 05-17-2006, 10:02 AM
thanks
baih is offline
Old 05-17-2006, 10:32 AM
Doesn't the NTC3 one-way have much longer outdrives?
ralph_c is offline
Old 05-17-2006, 11:07 AM
Ralph C,
Good Point I forgot that I had swapped them (out drive) out from my orignal one way when the hevay duty one way came out. .
Sorry Baih, Long day at work.... Ralph is correct on that.
Later
Kevin Boyle
