Old 05-24-2006, 08:38 AM   #31
Iceracer's Avatar
Originally Posted by Tpg racer
Wow cool!!!!!
But can't we just build one ourself using electronic stores available diodes?????
You see guys the amp rating is so high as high as 35 amps. How can we reach this kind of amps by just using rectifier diodes????
Can't we use bridge diodes instead??? It seems that bridge diodes have a high current rating even up to 35 amps. Can we use them????
Diodes used in bridge rectifiers don't have the same low threshold as schotkys. They don't need to. They are made for rectifying AC into DC. A premade bridge is just that, four diodes wired into a bridge, and that is useless for this purpose. All you need is diode(s) pointing from + to - accross your motor, not a bridge of four wired into a circle.
Iceracer is offline   Reply With Quote
Old 05-24-2006, 09:00 AM   #32
Tpg racer's Avatar
How can we get high amps diodes like the Novak motor module????
Isn't there anyway to do so????
The ones used in Novak motor module looks like square diodes, what diodes is that????
Tpg racer is offline   Reply With Quote
Old 05-25-2006, 04:24 AM   #33
hey was having a look at team much a more 35 amp diode and it is just 7 diodes in parralel i think can any one confirm or deny this??
it look to be but i wanna be sure
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 06-03-2006, 07:09 PM   #34
Default Building a discharger
ok ive decided i want to build a 30amp individual cells discharger very simmilar to the integy 0-30,
i worked out that i need .1 ohm round wire resistors but i cannot find them in australia so if any one knows were i can buy them please let me know also
wht should i use to connect to the batteries can u buy tabs like those on the novak smart tray or it a screw in pin idea like on the integy 6s a better design? thanks in advance
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
Old 06-03-2006, 07:21 PM   #35
pvtysux's Avatar
here is a good place to order diodes from
www.digikey.com
This site will give more info about diodes and specs.
www.diodes.com
Hope this helps.
Mark
pvtysux is offline   Reply With Quote
Old 06-25-2006, 12:39 AM   #36
POOKYT's Avatar
I have the Novak 36amp super diode. Does it need to be soldered to the + and - motor terminals with the wires or can it be soldered onto the opposite side terminals? Thanks guys! Please reply ASAP. I have a race in 12 hours! LOL
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 06-25-2006, 12:55 AM   #37
Trader Rating: 17 (100%+)
positive to positive, negative to negative
Tamiya TB Evo 5
Spektrum DX3R 2.4Ghz, Sanwa ERG-VX, VFS-1
EngTat is offline   Reply With Quote
Old 06-30-2006, 12:25 AM   #38
Originally Posted by EngTat
rckenon, what the price for this module. thanks
$13.88
rcKenon.com is offline   Reply With Quote
Old 06-30-2006, 03:14 AM   #39
Originally Posted by rcKenon.com
$13.88
thanks, EngTat
Tamiya TB Evo 5
schottky diode tamiyaboy Rookie Zone 4 02-02-2006 04:46 AM
schottky diode help JL Electric On-Road 3 08-27-2005 10:36 AM
Schottky diode for ESC danjoy25 Australian Racing 13 07-14-2005 12:12 AM
Schottky Diode YAHOO!!! Electric On-Road 2 03-04-2005 02:41 PM
schottky diode ????? drx Rookie Zone 2 04-29-2004 04:17 PM
