Old 05-15-2006, 10:45 PM   #16
Trader Rating: 17 (100%+)
you may try this the novak 36a module
http://www2.towerhobbies.com/cgi-bin...?&I=LXJJF4&P=7
Tamiya TB Evo 5
Spektrum DX3R 2.4Ghz, Sanwa ERG-VX, VFS-1
EngTat is offline   Reply With Quote
Old 05-16-2006, 04:41 AM   #17
Tpg racer's Avatar
Thanks but no thanks Eng Tat. I want a diode that is available at all elctronic stores not the ones from RC manufacturers.
I think the one from electronic stores is rather cheaper so I would be able to get more diodes and solder them together in parallel.
So my question now is, would the 1N5821/1N5822 diodes be suitable for the use with the KO Propo ESC????
I need HELP!!!!!
Tpg racer is offline   Reply With Quote
Old 05-16-2006, 05:49 AM   #18
Capelracer's Avatar
I started with a schottky diode from radioshack on my motor (27t stock, Novak Cyclone TC2 speedy), then put a Peak schottky diode on my 2nd motor (got sick of resoldering it every time I changed motors) - braking with the peak was insane, with the RS diode my tc3 would pull up in about 10 feet, the peak cut that down to about 2 - spend the extra if you want the best braking performance!!
Capelracer is offline   Reply With Quote
Old 05-16-2006, 09:31 AM   #19
Tpg racer's Avatar
Come on guys I need to know whether the 1N5821/1N5822 diodes can be used with the KO Propo ESC????
I don need to know about any other diodes from RC manufacturers.
BTW capelracer, what diode( i mean model number) did u get from radioshack and the one from peak???
I really need HELP guys!!!!! I dont wish to fry my ESC anytime soon cause this KO Propo ESC had already cost me a fortune!!!! I am just a low-budget racer!!!!
Old 05-17-2006, 12:51 AM   #20
yeh im with tpg racer lol come on guys what diode can we buy from radio shack and use? with a forward only esc just that it was a normal diode not a fancy novak or even a ko i just want to stop the reverse voltage from killing my esc as i am stil paying of my novak smart tray?
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 05-18-2006, 12:00 AM   #21
Tpg racer's Avatar
Hey doesn't anyone now bout this???
Or some of u guys just doesn't wanna share????
Help man!!!!!!!!!!!!!!!!!!!!
Old 05-18-2006, 12:07 AM   #22
bender's Avatar
A fairly standard schottky diode is 31DQ04. Just search for that number.
Jason W
FIR#2 - "You can't buy this much talent"
Durango Dex410 - Schumacher Cougar SV - Top Photon
bender is offline   Reply With Quote
Old 05-18-2006, 01:16 AM   #23
Tpg racer's Avatar
Thanks man!!!!
But I wanna know whether 1N5822 diodes can be used or not???
I think the diodes u mention is not available in Malaysia.
Old 05-18-2006, 04:16 AM   #24
bender's Avatar
Originally Posted by Tpg racer
Thanks man!!!!
I just checked the specs, yes the 1N5822 diode will work fine
Jason W
Old 05-18-2006, 04:53 AM   #25
Tpg racer's Avatar
Thanks man!!!!!!!!!!
So should I solder three of those 1N5822/1N5821 diodes together in parallel???
Some say that this would increase the amp for the current to flow, is it true???
Old 05-18-2006, 08:27 AM   #26
Iceracer's Avatar
Yes, you can solder them in parallel to increase their current carrying capability. I wouldn't do this in any other application (as diodes are not matched perfectly and one will carry more current than the others), but for this purpose it should be fine.
Iceracer is offline   Reply With Quote
Old 05-23-2006, 12:36 PM   #27
Default Speed Passion Super Schottky Diodes for Motor Type (36A)
Advance Micro Series power by Speed Passion
Level 1 - Super Schottky Diodes for Motor Type (36A)
For High Performance Stock & Modified 8T to 29T motor.
More than 15 year of Micro Chip, Digital Product production and
over 100 digital electronics design engineers.
Certify ISO 9002 and QS9000
The Super Schottky Diodes provides higher motor RPM, cooler ESC
operation for non-reversible brushed motor, longer run times and protect
your Electronic Speed Controller (ESC) against voltage spikes which
could damage the ESC thus protecting braking and acceleration tape.
To install module on motor:
Solder the red wire to the (+) Positive Motor tab.
Solder the black wire to the (-) Negative Motor tab.
Mount the Super Schottky Diodes in a suitable place in the car using the double side tape.
rcKenon.com is offline   Reply With Quote
Old 05-23-2006, 05:06 PM   #28
rckenon, what the price for this module. thanks
Tamiya TB Evo 5
Old 05-23-2006, 05:09 PM   #29
nvm, saw it 13.88
Tamiya TB Evo 5
Old 05-24-2006, 12:39 AM   #30
Tpg racer's Avatar
Wow cool!!!!!
But can't we just build one ourself using electronic stores available diodes?????
You see guys the amp rating is so high as high as 35 amps. How can we reach this kind of amps by just using rectifier diodes????
Can't we use bridge diodes instead??? It seems that bridge diodes have a high current rating even up to 35 amps. Can we use them????
schottky diode tamiyaboy Rookie Zone 4 02-02-2006 04:46 AM
schottky diode help JL Electric On-Road 3 08-27-2005 10:36 AM
Schottky diode for ESC danjoy25 Australian Racing 13 07-14-2005 12:12 AM
Schottky Diode YAHOO!!! Electric On-Road 2 03-04-2005 02:41 PM
schottky diode ????? drx Rookie Zone 2 04-29-2004 04:17 PM
