Old 12-27-2008, 03:36 PM   #556
C van der Hagen's Avatar
Is there a way to mount Jaco wheels on the SP12X?
http://www.facebook.com/SepesRacingProducts
C van der Hagen is offline   Reply With Quote
Old 12-27-2008, 03:38 PM   #557
Trader Rating: 8 (90%+)
You have to use the 12x US wheel adapters and they will fit.
Johnny Carey is offline   Reply With Quote
Old 12-27-2008, 03:56 PM   #558
Because of the offset of the jaco wheels, the wheel will clash with the spur gear. And the rear will be too narrow.
Old 12-27-2008, 04:29 PM   #559
bs6ef's Avatar
you need to use Fibrelyte wheel spacers you can get them from www.actionmodelcentre.com in the uk
You have to watch the TechnoViking http://www.youtube.com/watch?v=_1nzEFMjkI4
bs6ef is offline   Reply With Quote
Old 12-27-2008, 04:33 PM   #560
edit.
Bimdapogs is offline   Reply With Quote
Old 12-28-2008, 03:51 AM   #561
thanks!
Old 12-28-2008, 01:22 PM   #562
Send a message via ICQ to MattW
92 spur gear is fine, and doesn't rub. 94 is ok if you remove a little from the wheel. I then shim the axle to get the correct width.
MattW is offline   Reply With Quote
Old 01-01-2009, 09:16 AM   #563
T-ROY22's Avatar
Budman
Budman's Avatar
Tracy City TN
722 Posts Since Nov 2003
Old 04-23-2008, 12:31 PM Default View Budman's Profile Send Budman a Private Message Reply With Quote Multi-Quote This Message
Report | Post #508
This is the setup I've been using. Smooth med. to high traction.
Front:
springs 20 or 18 (start the day on 18's and change to 20's by the 3rd round)
split caster
10 deg blocks
crc extra heavy lub on king pins
1.5 camber
4 mm ride height
servo flat
Double pink tires
Rear:
1.6 T-bar
30 wt shock oil
green spring
1.5 droop
crc heavy lub on side dampers (white cap)
4mm ride height
Double Pink rears
This is a stock motor setup and works well. I will be testing more next week. Hope this helps.
Hey Cooper is this the set up you were using at Nexus? what size track & traction level would you consider Nexus?
T-ROY!
Mugen Seiki USA,Enneti Tyres, Murnan Modifieds, Airtronics USA
T-ROY22 is offline   Reply With Quote
Old 01-01-2009, 09:39 AM   #564
Budman's Avatar
Trader Rating: 22 (100%+)
No, That is my outdoor setup.
I would consider Nexus a medium bite small track.
Cooper Motorsports, Team Trinity, T-Rex Racing, GFRP, MSA, VBC Racing, Track Attack, Tekin and Frost-bite Graphics
Budman is offline   Reply With Quote
Old 01-01-2009, 09:59 AM   #565
Budman's Avatar
Here is a good setup for nexus:
Front:
springs 20
split caster
10 deg blocks
1.5 camber
3.5 mm ride height
servo flat
black tires
Rear:
2.0 T-bar
30 wt shock oil
green spring
1.5 droop
3.5mm ride height
yellow tires
Old 01-01-2009, 01:29 PM   #566
Default WC Edition vs U.S. Spec kit
Does the WC Edition chassis have the holes drilled for servo mounting with the Associated front? Is the only advantage of the WC kit over the U.S. Spec kit the Assoc. front, or is there another reason to buy it? Is Corally working on any 1/12 stuff?
oldrcer is offline   Reply With Quote
Old 01-25-2009, 07:57 PM   #567
mickrcarver's Avatar
Trader Rating: 98 (99%+)
can someone give me a starting point on gearing for 17.5 brushless for my corally sp12x us ed. spur and pinion?? have to use the corally long pinions which i have 29 thru 35
www.ovrccc.com
www.speedybillsrc.com
mickrcarver is offline   Reply With Quote
Old 02-01-2009, 03:23 PM   #568
Recoiled Revo's Avatar
Send a message via Yahoo to Recoiled Revo
You don't need to use the corally long pinions any pinion will work. Anyway the best start is to get your gear ratio aroung 2.0 and ajust from there. I am running a 87/40 whauch puts me around a 2.175.
Recoiled Revo is offline   Reply With Quote
Old 02-01-2009, 09:34 PM   #569
how do you not use the long pinion? my reg pinions barley tighten onto the shaft of the motor and hang more than halfway off the spur?
www.ovrccc.com
Old 02-04-2009, 08:06 PM   #570
I have been useing short pinions since I switched over to Brushless and I have have never had a problem. My pinion and spur are centered. want rear axle are you useing US or EURO with the EURO the short ones work fine. If you are useing the Us how do you have your axle spaced out. Make sure you don't have spacers behind the spur side that would cause a problem.
Corally SP12x DavidAlford R/C Items: For Sale/Trade 21 06-18-2008 06:19 PM
New Corally SP12X Eirik Electric On-Road 325 10-31-2007 10:13 AM
CORALLY SP12X WC Sigearhead R/C Items: For Sale/Trade 12 10-26-2007 11:30 AM
Corally SP12X F/S jrxsracer R/C Items: For Sale/Trade 10 04-06-2007 02:43 PM
Corally SP12X fastzach R/C Items: For Sale/Trade 8 02-17-2007 12:20 PM
