Old 01-26-2008, 04:35 AM   #376
3rd-dan's Avatar
Hi,
you need 7x11x3 flanged bearings.
3rd-dan is offline   Reply With Quote
Old 01-26-2008, 09:45 AM   #377
Switch Blade's Avatar
Send a message via AIM to Switch Blade
thanks for the help guys. Very much appreciated.
One last thing, for now:
can someone explain what the 1.0mm graphite spacers and the 1.3mm or 3.0mm t-bar pivot clips do?
Im really excited to run the corally. I havent been racing for a few months and this has sparked my interest.
cheers
College
Switch Blade is offline   Reply With Quote
Old 01-28-2008, 06:21 AM   #378
Rick Pfeilstick's Avatar
were can i get a 78 spur gear that fits the us spec axle?
Rick Pfeilstick is offline   Reply With Quote
Old 01-28-2008, 01:49 PM   #379
Korey Harbke's Avatar
cheers
I know the 1.0mm graphite spacers are for when you use a 1.6mm t-bar. it basically just takes up the slack that is left in the pivots when you use a 1.6mm t-bar.
The clips... I think they take the place of the big orings... I'm not entirely sure. I still use the big orings to keep everything together. But the clips come in a thinner and a thicker version depending on what t-bar you choose.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 01-28-2008, 01:49 PM   #380
Pretty sure the ones RW or even PRS will work.
-Korey
Old 01-28-2008, 01:56 PM   #381
bigbutstupid's Avatar
just wondering, does GRP tires fit both the US-spec and std spec?
bigbutstupid is offline   Reply With Quote
Old 01-28-2008, 01:59 PM   #382
They will only fit the US spec. The Euro/std spec will only work with Corally's black 1/12 wheels.
-Korey
Old 01-28-2008, 02:27 PM   #383
Originally Posted by Korey Harbke View Post
Alrighty.... I looked at the setup again, but I remembered I had a few more things to try. I'll report back with my findings later this week
-Korey
Korey, what about this new setup? Is it so good that it must be keep hidden?
Arn0 is offline   Reply With Quote
Old 01-29-2008, 12:31 AM   #384
Allllrighty. Here it is.
Front:
-Associated Front end
-Servo layed down flat, bump steer taken out
-.018 springs w 15K on pins
-5 deg reactive
-Medium caster (shims on each side)
-Camber: about 1.5 deg
-Ride height: 3.5mm
-Tires: Parma Magenta 1.65in
Rear:
-TBar: prototype .063, use middle tweak screw holes, 2 screws
-Hot Bodies shock
-Center spring: Olive (silver is the track is smooth)
-Oil: 40wt
-Tires: Parma Magenta rears 1.73in
4.0mm ride height
Parma speed 8 HD body
So far... this has been really good for me on a bumpy carpet track with some decent grip. If you need to free up the car a bit, try running some grey rear tires. I just use the magenta rears since they seem to hold traction throughout the run.
The new T bar is an item that people running the car at snowbirds will be running. I'm sure there will be pics of it soon.
-Korey
Old 01-29-2008, 02:54 AM   #385
anyone know where i can source a sp12x Euro spec online for a good price?
Old 01-29-2008, 08:56 AM   #386
Ferrarimk13's Avatar
Send a message via AIM to Ferrarimk13
www.stormerhobbies.com
Press Alt+F4 for a good time.
Ferrarimk13 is offline   Reply With Quote
Old 01-29-2008, 09:43 AM   #387
Blue Screw's Avatar
Send a message via AIM to Blue Screw
im running pretty much the same setup... except im using double pink fronts and yellow rears... and the irs shock with 30 wt and the silver spring.. i also add a .030 shim under the front t bar screw...def the thin t bar seems to be better..
Angelo DAlessandro
AE~REEDY~LRP~JCONCEPTS~NOVAROSSI~HUDY~IRS~KALGUARD ~ABSOULUTE HOBBYZ~GRAVITY-RC~TnT CUSTOM GRAPHICS
NITRO ONROAD
XRAY~RCAMERICA~HUDY~SRC~MURNAN MODS
Blue Screw is offline   Reply With Quote
Old 01-29-2008, 10:35 AM   #388
oze
Hi Korey, what is this "15K on pins"?
oze is offline   Reply With Quote
Old 01-29-2008, 10:37 AM   #389
JamesArluck's Avatar
Trader Rating: 52 (100%+)
Send a message via AIM to JamesArluck
The kingpins are coated with 15,000wt. diff oil/grease from 8th scale cars.
JamesArluck is offline   Reply With Quote
Old 01-29-2008, 12:31 PM   #390
oze
thx
Corally SP12x DavidAlford R/C Items: For Sale/Trade 21 06-18-2008 06:19 PM
New Corally SP12X Eirik Electric On-Road 325 10-31-2007 10:13 AM
CORALLY SP12X WC Sigearhead R/C Items: For Sale/Trade 12 10-26-2007 11:30 AM
Corally SP12X F/S jrxsracer R/C Items: For Sale/Trade 10 04-06-2007 02:43 PM
Corally SP12X fastzach R/C Items: For Sale/Trade 8 02-17-2007 12:20 PM
