Old 01-22-2008, 10:27 AM   #361
JamesArluck's Avatar
Trader Rating: 52 (100%+)
Send a message via AIM to JamesArluck
Sorry for the OT, but where are you guys buying the Hot Bodies shocks? I've been looking for the parts for one for a while and the only online retailer (Stormer) has been out of stock on the Body and the shaft. If you could tell me where to get ahold of those parts i'd appriciate it.
-James
JamesArluck is offline   Reply With Quote
Old 01-23-2008, 07:09 AM   #362
That would be nice to know. Also, any source for rear axle spacers around 1-2mm thick? The CRC spacers are not perfectly flat when you stack 12 of them together.
Larry Brown is offline   Reply With Quote
Old 01-23-2008, 09:42 AM   #363
Hey Larry!
How was the trip home from Cleveland?
What is this hype about the HB shock? Is there a distinct advantage over a duroshock? Seems like guys a switching to it in all makes of cars lately...
It is cold as %$&$ in D-town right now... below 0 windchill and snow... I'm sure you don't miss that...
Jeremy
Jeremy Otis is offline   Reply With Quote
Old 01-23-2008, 09:59 AM   #364
Hey Everyone.... Glad to see the great support for the Corally sp12x on here..
I will be building mine and running it for the first time at the snowbirds.. Look forward to running this car.. When i get back from the snowbirds i will check in here from time to time and try and help out with questions etc...
Mike Blackstock
TEAM ASSOCIATED, SMC BATTERIES, REEDY MOTORS, JACO TIRES, RADIOPOST RADIOS, LRP ELECTRONICS, PROTOFORM BODIES, MAKITA POWER TOOLS, KICKER PEFORMANCE AUDIO, KOLORS BY KROPY, MUCH-, RSD
Mike Blackstock is offline   Reply With Quote
Old 01-23-2008, 10:25 AM   #365
Ferrarimk13's Avatar
Send a message via AIM to Ferrarimk13
mike- what have you been running before the corally, a speedmerchant? i cant remember.
Press Alt+F4 for a good time.
Ferrarimk13 is offline   Reply With Quote
Old 01-23-2008, 11:25 AM   #366
Hey Larry!
Hiya Jeremy. Trip was fine, if you like 700 miles of rainy weather. We use the IRS VCS shock, not sure if that is the same as a durashock. The VCS is great, very smooth and consistent, but can develop air in the chamber over a day or 2 of racing. So maintenance is required. Interested in the HB just because its new and maybe? requires less maintenance. Hehe, don't miss the cold even a little.
Ferrarimk13- I'll answer for Mike since he may not see your question. He was running a CEFX, and did very well with it.
Old 01-24-2008, 11:29 PM   #367
Switch Blade's Avatar
Send a message via AIM to Switch Blade
Im getting my sp12x ready and just want to make sure Ive caught everything. I can use flanged bearings to stop the bearings from getting pushed through the plastic holders, and it will increase the width, and to adjust the width i need 7mm shims from crc? Or I can use a 7x14x2mm shim in the back of the spacer to keep the bearings from being pushed through? Are the flanged bearings still the same size (1/4x3/8)?
Lastly, im running the crc pro-strut front end on my car and was wondering what is the correct size bearings needed for flanged bearing rims?
thanks
College
Switch Blade is offline   Reply With Quote
Old 01-25-2008, 06:28 AM   #368
The flanged bearings are a good idea, but they are 7mm I.D., not 1/4". The CRC 7mm shims are then used to widen from that point. You can use a shim behind the bearing holder, as described on page 11 of this thread. It takes some cutting of the washer to get it the right size.
Not sure on the pro-strut, but CRC has a good website that should have the answer somewhere. www.teamcrc.com
Old 01-25-2008, 10:09 AM   #369
[...] modern large rims wheels such as Parma Pro Cut, CRC, Jaco Prism, you will need 1/8 x 5/16 flanged ball bearings.
Arn0 is offline   Reply With Quote
Old 01-25-2008, 10:13 AM   #370
oh, thanks. That car has been doing well lately, i like the green on the CEFX too.
Old 01-25-2008, 10:28 AM   #371
Trader Rating: 8 (90%+)
For the CRC front end, you need 3/16x5/16 flanged.
Johnny Carey is offline   Reply With Quote
Old 01-25-2008, 11:25 AM   #372
excellent, thanks a lot.
So for flanged bearings in the rear i need 7mmx3/8?
College
Old 01-25-2008, 11:41 AM   #373
No, the outside diameter will be metric as well as the inside (7mm) diameter. I don't happen to know what the standard size is. Perhaps your local hobby shop or some other 12x racers on this forum can help.
Old 01-25-2008, 11:43 AM   #374
Korey Harbke's Avatar
7x11mm Boca Bearing makes some flanged versions if you cant find any.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 01-25-2008, 01:47 PM   #375
ya, pardon my ignorance, im an idiot. It doesnt make sense to have a metric/imperial bearing.
thanks, Ill see if my LHS has some.
College
Corally SP12x DavidAlford R/C Items: For Sale/Trade 21 06-18-2008 06:19 PM
New Corally SP12X Eirik Electric On-Road 325 10-31-2007 10:13 AM
CORALLY SP12X WC Sigearhead R/C Items: For Sale/Trade 12 10-26-2007 11:30 AM
Corally SP12X F/S jrxsracer R/C Items: For Sale/Trade 10 04-06-2007 02:43 PM
Corally SP12X fastzach R/C Items: For Sale/Trade 8 02-17-2007 12:20 PM
