Old 01-14-2008, 06:39 AM   #331
hey guy's looking for some insight on gearing. I know how figure out my roll out and and all. problem is that with my previous cars I used to run a 88 spur gear. with the sp12x 88's won't fit , (meaning the pinion and spur won't align up due to the moter is blocked by the rear axle tube. i don't feel like gringing it down. I race on a very technical track. I would say medium size carpet is lay out. we use almost the whole lenth of a gym and we roll out three rolls. we run stock only. we also only run 6' lane. yes 6' lanes not the reg 12 feet for touring. as we only run 12 scale during the winter months.
I run a co27 motor and sometimes a monter based handout the one with the purple top. could some one give right now my tire are new prism(48mm) pink and up front there pro cut purples. I can change will problably try yellow and magenta this weekend. but first I need to get my gearing done. what size spur should I go with, I like to roll out around 42mm for the co27, I you guy's think I'm overgearing then give me a a sudjestion to what to try.
heck will i'm at it, what tube lube should I be going for I'm using blue corally and 40 in the shock for oil. not sure which spring. and sudjestion's on this would be appreciated too.
thanks in advance.
cyrrus is offline   Reply With Quote
Old 01-14-2008, 08:45 AM   #332
cyrrus-
We have found that a 94T spur gear gives a nice range of gearing for stock motors for the 12x motor mount location. 42mm for the CO27 definitely does not sound overgeared. On flowing tracks we gear as high as 46-47mm.
In Cleveland (med to hi bite) we used Corally red lube in the dampener tubes and 30 wt. shock oil with Jaco double pink fronts and yellow rears. Obviously these will be dictated by your traction conditions.
Larry Brown is offline   Reply With Quote
Old 01-14-2008, 11:12 AM   #333
Larry thanks
Old 01-15-2008, 10:13 PM   #334
oze
Default Tweak setup
I studied a few setup sheets from Corally site and others, e.g. this one: http://international.corally.com/xls..._Nationals.xls
In hte Rear Setup section you see Tweak: 3 mm. What does this mean? Does this mean that you keep the distance between the tweak screw of the T bar and the chassais 3 mm?
oze is offline   Reply With Quote
Old 01-16-2008, 08:53 PM   #335
oze- I think it may mean that the rear pod droop is 3mm when lifted, but I don't know for sure. I don't think the tweak screws were off the chassis for high traction carpet. I believe they would only be set that way on low traction asphalt. The track at Snowbirds last year was a little bumpy, so the rear pod droop could have been set more than normal (0.5-1 mm for med-high traction) to handle better over bumps, or perhaps for more forward traction, or both.
Old 01-16-2008, 11:06 PM   #336
oze
Larry, thanks for the idea. i will look at my droop, I have no idea how big it is now.
Old 01-17-2008, 08:24 AM   #337
oze-
Don't know if you saw them, but pages 8 and 9 of this thread have some setups for carpet.
Old 01-17-2008, 09:26 AM   #338
oze
No, I haven't seen them. Thanks.
Old 01-17-2008, 11:03 AM   #339
Speaking about SP12X setups: http://www.petitrc.com/reglages/cora...rallySP12X.htm
Those documents are quite difficult to find so, that may help!
Arn0 is offline   Reply With Quote
Old 01-17-2008, 04:11 PM   #340
Korey Harbke's Avatar
Wow... they put my old setup on there. I MUST be cool or something Just kiddin.
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 01-17-2008, 08:51 PM   #341
That's means you have a new one!!
Is that possible to see it?
Old 01-17-2008, 11:22 PM   #342
Yea, I dont exactly remember what I had though, I will post it soon!
-Korey
Old 01-20-2008, 09:36 PM   #343
Who is going to Snowbirds with their 12x? Going to be some new faces there running Corally 1/12!
Korey- How soon is "soon"? lol
Old 01-21-2008, 01:46 AM   #344
Alrighty.... I looked at the setup again, but I remembered I had a few more things to try. I'll report back with my findings later this week
-Korey
Old 01-21-2008, 04:16 AM   #345
chicky03's Avatar
Send a message via AIM to chicky03
Hey Larry,
Looks like, Me, Jeff, Brad Johnson, Jeff Cufs, Jarrod Langlois, Steve Boice, Joe Trandell, Mike Blackstock, Chris Tosolini, Marc Fischer, Simmo Ahoemini.
Paul
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Corally SP12x DavidAlford R/C Items: For Sale/Trade 21 06-18-2008 06:19 PM
New Corally SP12X Eirik Electric On-Road 325 10-31-2007 10:13 AM
CORALLY SP12X WC Sigearhead R/C Items: For Sale/Trade 12 10-26-2007 11:30 AM
Corally SP12X F/S jrxsracer R/C Items: For Sale/Trade 10 04-06-2007 02:43 PM
Corally SP12X fastzach R/C Items: For Sale/Trade 8 02-17-2007 12:20 PM
