Old 04-09-2007, 01:27 PM   #196
Vicko's Avatar
Trader Rating: 14 (100%+)
I;LL BE COOL WITH THAT PRICE, WELL U BE TAKING PAYPAL?
AND WHEN DO U THINKS THIS WELL HAPPEN
Vicko is offline   Reply With Quote
Old 04-09-2007, 10:20 PM   #197
hkboy's Avatar
Originally Posted by Bob-Stormer
Which 19t? You're rolled out 44.2mm and about 50 is good on a large US carpet track. How big is track? When was the last time you rebuilt the motor, or last time you fully cycled your pack on some equipment?
I am using the Trinity stock 19T. The track is medium size. Just like the CEFX track, but a little smaller. I rebuild the motor after every run, so I don't think it is the motor's problem. Also, I use the battery pretty much every week, so I am really not sure what is wrong with it.
If you can suggest me something, that will be great. Thanks in advance
hkboy is offline   Reply With Quote
Old 04-10-2007, 12:29 AM   #198
Bob-Stormer's Avatar
Just this one particular pack, or every pack you have?
www.stormerhobbies.com "Where the world shops for radio control."
www.facebook.com/stormerhobbies
www.twitter.com/stormerhobbies
looking for....vintage 1/10-1/12 pan, need Schumacher 1/12th cars and parts.
Bob-Stormer is offline   Reply With Quote
Old 04-10-2007, 09:25 AM   #199
hkboy's Avatar
Is every pack I have. That is why I am wondering if I am doing something wrong with the gearing. I talked to a few people and they suggest me to go with 31/88 just to try it out. Wil you suggest the same?
Old 04-10-2007, 01:04 PM   #200
Assuming that your car is okay and the motor is okay, I'd say it's time to run your packs on some equipment and see what you have. I've seen many packs that people thought they had well cared for, drop 1000 mAh, easy.
Old 04-10-2007, 04:00 PM   #201
hkboy's Avatar
Thanks. I will do that and check out them out as well. Except the packs, do you have any other suggestions for me?
Old 04-10-2007, 04:24 PM   #202
Short of building a crummy motor or having your drivetrain full of fuzz and not rotating, even if you used a pliers to rotate the spur gear, about all you could blame, with that rollout, would be the packs.
Old 04-11-2007, 10:32 AM   #203
hkboy's Avatar
Thanks very much for your help. I will try it out tomorrow and see what is going on. I hope is just the packs, like you say, but still, which means I will have to get new packs!!!
Oh well, I guess this is racing and this is what we need to do to compete!!
But in a way, this will set me back some $$
Thanks again
Old 05-17-2007, 11:17 AM   #204
Mach10_shooter's Avatar
Trader Rating: 37 (100%+)
Originally Posted by Mach10_shooter
I just received my 12X the other day and Wed. ran it for the first time. I already need different adjusters than what comes in the kit. I am a CAD designer and work in a tool shop. I have already designed and manufactured custom parts for other cars. I am thinking about doing a set of adjusters that would fill the void from the kit pieces. They would be made from delrin and CNC machined. If there is interest in these pieces please let me know as it is almost as easy to make 5 set rather than one. Probably do the 1/2 mm steps too.
Pic of 2.5mm added.
Chris
Ok, I finally got them done. I ended up doing a 0,.5,1.0,1.5,2.0,2.5, and 3.0. At first I thought of doing a 3.5 but the axle would have hit the inside of the axle tube and a 3.25 was just too small of a jump from the 3.0. I have 4 full sets to sell and I'm not sure if I will do any more. This ended up takeing more time and being more trouble than I thought it would. I have attached an actual picture of the 1.0. If you are interested send me a PM or better yet an email and put in the Sub. Corally. [email protected] the cost will be $40.00 plus shipping. I know this is a little more than I originally said but I feel the are worth it. Paypal Payment.
Mach10_shooter is offline   Reply With Quote
Old 05-18-2007, 08:35 AM   #205
3 set sold, only 1 set left.
Chris
Old 05-18-2007, 06:00 PM   #206
Default lipo
Thanks again
sooner they let us use lipo the better, i am fed up with high priced dud cells
flyspray is offline   Reply With Quote
Old 05-20-2007, 08:14 AM   #207
mha
From http://international.corally.com/def...ernational.htm
"The new front end for Corally SP12X, compatible for US Spec (#00067) and Original (#00066).
Since Daivd Spashett has become 1:12 IFMAR World Champion 2006 with Corally SP12X US Spec with a special front end of which brand we all know about, and the demand from end-consumers never seemed to cease, we have finally decided to offer them in our repertoire....
Seems like Corally has given up on their own front end. Sounds like a full blown declaration of bankruptcy to me. Imagine Ferrari giving up on their engines and offering Chrysler parts instead.
mha is offline   Reply With Quote
Old 05-20-2007, 08:02 PM   #208
wingman2's Avatar
Gotta say guys, a LOT of people run the AE front without giving the Corally a fair go. A couple of the guys at our local club are National A final standard, and they use the Corally front end with great results. I know that a lot of the people that run the AE front end only do so because that was what the world champ did when winning the worlds so it MUST be better. Might be for him, not so for everyone else though, don't you think?
On a side line, I know the original 12x had really short wishbones (if you look at some of the pics in the booklet that comes with the kit, the original had the cells the other way across the chassis) and the team members had loads of problems trying to get the chassis set up well. That idea was re designed to have longer wishbones which is what you get in the kit now. Do you think that the team guys went to the AE frontend when the only other choice the original, which they knew was not a fast ticket?
Cheers all.
wingman2 is offline   Reply With Quote
Old 05-21-2007, 01:06 PM   #209
Chris
Anyone want this last set. Let me know.
Old 05-29-2007, 09:53 AM   #210
All sets are sold.... Thanks!
Corally SP12x DavidAlford R/C Items: For Sale/Trade 21 06-18-2008 06:19 PM
New Corally SP12X Eirik Electric On-Road 325 10-31-2007 10:13 AM
CORALLY SP12X WC Sigearhead R/C Items: For Sale/Trade 12 10-26-2007 11:30 AM
Corally SP12X F/S jrxsracer R/C Items: For Sale/Trade 10 04-06-2007 02:43 PM
Corally SP12X fastzach R/C Items: For Sale/Trade 8 02-17-2007 12:20 PM
