Old 01-02-2003, 04:16 PM   #1
skibum989's Avatar
Default Boiling plastic parts....
Will boiling the body posts on my car make them more flexible so they are less prone to snapping in a crash? If so, how long should I boil them? Thanks for the help!
skibum989 is offline   Reply With Quote
Old 01-02-2003, 04:35 PM   #2
10 min should do fine still subject to brakage in cold weather cold just makes plastic britle
bubbaicm is offline   Reply With Quote
Old 01-02-2003, 08:42 PM   #3
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
be careful! if you boil them in oil over 500 degrees, they may melt.
seaball is offline   Reply With Quote
Old 01-02-2003, 08:47 PM   #4
popsracer's Avatar
Seaball;
What's he gonna do boil them in molten lava?
I think that most oils would be on FIRE at 500 F degrees.
popsracer is offline   Reply With Quote
Old 01-03-2003, 09:09 AM   #5
hey, were talking use some common sense if dont have water wait till it rains seams to be doing that a lot lately??????????????
Make sure u ask Mom to use the stove ,for those who have them
Old 01-03-2003, 12:23 PM   #6
seaball's Avatar
no, 500 kelvin! c'mon, really.
Old 01-03-2003, 12:42 PM   #7
popsracer's Avatar
Default I knew there was a reason I liked you.
seaball;
You have a warped sense of humor like me !
Old 01-03-2003, 12:48 PM   #8
popsracer's Avatar
Default My thoughts on boiling nylon parts
Guys;
Here's what I've found about boiling Plastic (nylon) parts. The
Plastic absorbs some of the water and this makes the plastic less brittle (more flexible).
I used this method to fix a problem with the nylon gears stripping in the Original Radio that's in my 1968 Plymouth Road Runner. Worked like a charm.
Old 01-03-2003, 02:45 PM   #9
skibum989's Avatar
Post
Thanks guys, I boiled them in WATER for 10 minutes and they are a little more flexible, so it should help. And yes, most oils DO catch FIRE at 500 degrees
Ryan Robison
SeattleRCRacers.com - come race with us!
Old 01-03-2003, 08:42 PM   #10
popsracer's Avatar
Default skibum989;
So will carpeting if your batteries catch fire when plugged directly into the wall socket for quick charging. Just move the furniture around to hide the burned spot from your parents.
Old 01-04-2003, 02:32 AM   #11
stoopidbstrd's Avatar
Send a message via AIM to stoopidbstrd
im surprised the stuff didn't melt, period. boiling plastic parts, eh? sounds like a plan.
stoopidbstrd is offline   Reply With Quote
Old 01-04-2003, 11:47 PM   #12
skibum989's Avatar
Wow stoopidbstrd, you must really be a "stoopidbstrd" Plastic parts don't melt if you boil them Unless of course you put them in the hot pan that popsracer aka "BoneHead" charges his batteries in
Ryan Robison
Old 01-05-2003, 12:20 AM   #13
Talking
isn't that why my name's there. stoopidbstrd the perfect name for me.
Old 01-05-2003, 12:04 PM   #14
popsracer's Avatar
Default "BoneHead" charges his batteries in
skibum989;
I don't charge my batteries in a HOT pan. The pan is to keep the HOT batteries from igniting the Carpet on Fire (again) when they are quick charging plugged DIRECTLY into the 120v wall socket. Just rip the cord out of a lamp and tape the wires to your battery wires. WORKS GREAT, really, really fast charge. My Matched GP3300's charge in about 30 seconds instead of 30 minutes.
Old 01-05-2003, 12:25 PM   #15
Do you have any problems with those penny battery bars when you charge directly from the wall socket?? I also heard you use high power electric line for all of your connections... how does that 2" cable work in your sedan, and does it add too much weight??? How about soldering or do you have a portable mig welder???????
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
boiling parts? cm367700 Electric Off-Road 6 11-17-2007 11:18 PM
Boiling MBX5R Parts, need info Cain Nitro Off-Road 15 11-09-2007 03:19 PM
boiling plastic parts so they wont break?? drew840 Electric Off-Road 13 08-16-2006 07:56 AM
Associated TC4 Plastic Components Parts 190mph R/C Items: For Sale/Trade 1 12-02-2004 10:16 PM
Boiling XXX-S Graphite Parts? ElectroNut Electric On-Road 4 01-28-2002 05:38 AM
