Old 05-13-2006, 05:31 AM   #1
uniquexme's Avatar
Send a message via MSN to uniquexme Send a message via Yahoo to uniquexme Send a message via Skype™ to uniquexme
Default car not responding on acceleration
was drifting as usual this noon, but suddenly when i push the triggle just a little bit, the car is not running, but u can hear the ESC beeping, then when u nail the triggle, it runs again. after few mins, it doesnt want to move anymore. i suspect that the motor brush might be worn out, but still not enough time to check it out. so any comments on this pls? dun tell me i fried my ESC again.
uniquexme is offline   Reply With Quote
Old 05-13-2006, 06:18 AM   #2
brownpants's Avatar
I know some esc's have a cut off when they get too hot, and then when cooled a bit they work again. I had this happen to me and this is what I was told. The esc I used was a cheaper one and I think I pushed it too hard.
HTH
Darren
brownpants is offline   Reply With Quote
Old 05-13-2006, 06:48 AM   #3
uniquexme's Avatar
it can't be coz i have fried my cheaper Futaba ESC as well. m using Novak GTS now, and since the day i use it, there isn't any cut yet. do u think it might be due to the motor brushess?
Old 05-13-2006, 08:52 AM   #4
brownpants's Avatar
Sorry did'nt realise what ESC you are using.
As you said its probably the brushes then. The brush could be broken? I suggest you take the motor apart and have a look and try putting new brushes in.
Darren
Old 05-13-2006, 10:04 AM   #5
thedudeaturdoor's Avatar
Send a message via AIM to thedudeaturdoor
kick it, that works for me
thedudeaturdoor is offline   Reply With Quote
Old 05-13-2006, 09:09 PM   #6
Have a motor overhaul, clean everything, check motor brushes, they might be worn out, and also the brush springs, they might have lost tension. Be careful when you put them back. Be aware of the timing. Put a drop of oil on the motor bearings/bushings.
macgyver1432000 is offline   Reply With Quote
Old 05-13-2006, 09:16 PM   #7
Jimmy Morris's Avatar
You probably have a hung brush. Pull on the shunts and let the brush snap back in to place. Kind of rigging it but it should make it work. Spray it out with motor cleaner or break cleaner and re lube. But the best thing to do would be to rebuild it like macgyver said.
www.superiorhobbies.com
Jimmy Morris is offline   Reply With Quote
Old 05-14-2006, 06:11 AM   #8
uniquexme's Avatar
m using tamiya Super stock motor TZ (23T). Opened it up just now, was surprised to find many dust and some other rusty small metal pieces inside the motor. well, cleaned everything up, lubricated the bearings, problem still the same. so i checked on the brushes, wierd that one side is shorter than another, the shorter one is about 20mm in lenght. i guess it must be due to this worn out brushess. coz the motor will run a few times, then it stop, and when u give it a slight push, it will move again, so i think shall get my brushess replaced. btw, do i have to buy from LHS or can get those equivalent carbon brushess (black color) from electronic shops or do i have to buy back the Tamiya original brushess(gold color). TQ
Old 05-14-2006, 12:12 PM   #9
Ike
Ike's Avatar
I just want to know what a triggle is...
Ike is offline   Reply With Quote
Old 05-15-2006, 05:22 AM   #10
uniquexme's Avatar
just DIY the cheap carbon brush to be fitted inside the motor slot. However, it doesnt want to move, then later after few pushes, it starts to run like snail. so i guess carbon brush is not suitable for our motor, have to buy back the Tamiya gold plated brush. From wat i ask the shop owner, he told me that gold plated ones like tamiya is the hardest and most lasting brush, and those that he sell me is normal type. He even ask wah, such a good brush must have lasted u 1-2 yrs, but i said, no lah, just 1 month. he laughed at me saying i will be visiting his shop more often, but since it cannot use, i will not go back to him.
Old 05-15-2006, 07:03 AM   #11
Yeti35's Avatar
How long have you had this motor and how many runs are on it? If you have been running it non stop since you got it the comm probably needs cut and that it probably another reason it does not run right. I would suspect who ever cuts it for you will be doing many passes on it to get it back to spec,
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 05-15-2006, 06:28 PM   #12
uniquexme's Avatar
had this car for only 1 mth+, but have been running it everyday with 2-3 battery packs almost every weekend. btw, may i ask what is the comm? the motor has been in its state since i bought it, so only now then i opened it up to check.
here is another question :
upon opening up the motor, the top part of the motor came off (where the brushess are), so i got mixed up with it, there are 2 washers, and 1 orange color plastic pc, and a copper bushing at the very top part of it. so do i place them in this order? copper bushing -> 2pcs of washer -> orange color plastic -> motor -> (bottom part) 2pcs washer -> copper bushing
Old 05-15-2006, 08:35 PM   #13
Yeti35's Avatar
I am thinking at this point you should just buy another motor. Sounds like you got more issues then just needing a cut. Are you just into this drifting thing or do you have friends that race? If you have race friends ask them to take care of your motor and show you how to as well. The Comm is the copper part the brushes ride against. If it has been run that much in a month it needs cut and new brushes, but the bushing should not have falling out when you took it apart.
22 3.0SR
Old 05-15-2006, 09:31 PM   #14
jarrodh's Avatar
the comm is the brass paret that the brushes run on. check it and see how deep the grove is from the brushes, (there will be one) if u think that theres enough material left to make it smooth again then have someone with a comm lathe to cut the com, then put some new brushes in and re oil. if there isnt enough material then go buy either another armeture, (the part that spins inside the motor) or buy a complete new motor. i saw that you said that one brush it longer than another? check the springs that hold the brushes in. see what colors they are and stick to one color for both sides.
this should help, and clear things up for you
www.irocc.ca
jarrodh is offline   Reply With Quote
Old 05-15-2006, 09:36 PM   #15
Lana's Avatar
Smack it with an f'n hammer.
Lana is offline   Reply With Quote
Radio Not responding buggyrac3r Nitro On-Road 5 10-11-2006 11:19 PM
whats the fastest responding reciever? any one? downunder23 Rookie Zone 2 09-29-2006 06:42 AM
3PK not responding in PPM mode? Accord Nitro On-Road 10 06-20-2003 04:00 PM
3PK not responding in PPM mode? Accord Electric On-Road 3 06-19-2003 08:29 PM
Quantum.. not responding Carbon_Fibre3 Electric On-Road 1 02-21-2003 10:00 PM
