Old 05-11-2006, 02:47 PM   #1
tim fry's Avatar
Default How to know when to choose a spool
What are the factors that would make you choose a spool over a normal diff?
I know when to use a one way as thats on open and flowing tracks where the brakes aren't needed much.
tim fry is offline   Reply With Quote
Old 05-11-2006, 03:24 PM   #2
Phil C's Avatar
To be honest if the tracks not suited to 1ways I use a spool. Its almost always quicker than a diff. What surface are you talking about? Thats also a factor when I make a choice.
| Team XRAY UK | HUDY | RC DisCo| LRP | Sanwa | SMD | Moorespeed | MB Models | Gingapaint | McLaren Racing |
Phil C is offline   Reply With Quote
Old 05-11-2006, 04:08 PM   #3
TRF415boy's Avatar
I back that up, over a diff a spool all the time
TRF415boy is offline   Reply With Quote
Old 05-11-2006, 04:11 PM   #4
tim fry's Avatar
Basically its low grip tarmac and reasonably tight.
I ask as I've got a spool in my Cyclone at the moment and have a diff built ready if I need it. From past experiences from other peoples cars they seem to loose a lot of mid corner when its a tight track.
Old 05-11-2006, 09:00 PM   #5
drew85's Avatar
To use a spool you get your steering from getting on the gas and it pulls the car kinda, so in low grip I don;t think it would work to well. Just try it and see, no matter what anyone says on here you still have to try it to see if it works.
drew85 is offline   Reply With Quote
Old 05-16-2006, 10:00 AM   #6
waltuo's Avatar
For me, a diff on carpet and a spool everywhere else.
011011110111010101110100011011000110000101110111
a waltuo production
http://vimeo.com/iamwaltuo - http://youtube.com/iamwaltuo
waltuo is offline   Reply With Quote
Old 05-16-2006, 10:16 AM   #7
Aurra Sing's Avatar
I go by the track layout.
If it's tight and small, spool is the only way to go.
If its large and flowing, I want maximum corner speed so I use a one-way.
There are some instances where I choose a spool over a one-way because it is easier to drive. It may be a tenth or two slower but way more consitent, which is sometiems more important than sheer lap time speed.
If i have to run stock (27t) it's always a one-way.
Aurra Sing is offline   Reply With Quote
Old 05-16-2006, 10:24 AM   #8
Send a message via AIM to Bobby Flack
If the track requires that your going to be all over the brakes, then a spool is your best choice. If the track is open enough to use little or no brake at all then a one-way will be better suited. Both a one way and a spool have a major advantage over a diff simply because both are solid on-power, whereas a diff could potentially slip and that could result in a small loss of power. A diff will almost always be easier to drive over either a one-way or a spool, but, chances are it will be a lot slower on the stopwatch.
Bobby Flack is offline   Reply With Quote
Old 05-16-2006, 11:07 AM   #9
peter_robinson's Avatar
Trader Rating: 21 (100%+)
Q: how to know when to choose a spool?
A: when the entry form reads "Reedy Race of Champions"
For orders or inquiries, email [email protected] Follow RC-Trim on Twitter and Facebook
RC-Trim | Serpent USA | On-Point | Trinity | Revtech | ORCA | BSR | KO Propo | PT RC Racing Oil | WTRC | rcpitwhores.com
peter_robinson is offline   Reply With Quote
Old 05-16-2006, 11:15 AM   #10
Korey Harbke's Avatar
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
What would you choose BJM Australian Racing 6 05-16-2007 06:12 AM
wat should i choose ben23smits Rookie Zone 6 01-05-2007 11:28 AM
help me choose please vintage Nitro On-Road 16 10-09-2005 06:02 PM
