Old 05-11-2006, 08:16 PM   #31
JayL's Avatar
I get the mega spool 60/40 rosin core from Radio Shack.
Bill: you'd be suprised how the 908 handle isn't that 'large' you might want to look at one ,if you haven't, before you buy both.
tinning before and after every solder is one key..another is when you are done soldering add solder to the every part of the tip and let it sit on each part until it doesn't bubble anymore, then wipe tip tin and move to another part till the whole tip doesn't bubble. Then turn iron off and keep adding a bubble of solder to the tip until is too cool. The nice bubble will protect the tip and come right off next time all clean and shiny.
JayL is offline   Reply With Quote
Old 05-11-2006, 08:55 PM   #32
Nexus Racing's Avatar
907 and 908 are the same handle with different metal pieces to accomodate different size tips. The big chisel tip (that fits in the 908 iron only) is perfect for pretty much all RC-related soldering IMO.
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 05-11-2006, 10:28 PM   #33
jas
jas's Avatar
My soldering tools and stuff. The iron has a fairly large (5mm) round slanted tip, I figured that gives plenty of contact area on the battery bar. And I am also getting a chisel type tip. Not sure which type will work better.
jas is offline   Reply With Quote
Old 05-12-2006, 07:07 AM   #34
the absolute best iron is the JBC Iron from howard electronics. very small yet very powerful. we use those in the rework station at Fusion. Ask anyone who has seen it work and you will know what I mean. Big problem is the cost.... about 450 tips last forever as they are only hot while you work. as soon as you put it in the cradle it cools to 200 degrees. As soon as you pick it up it is 750 within two seconds.
John Malin is offline   Reply With Quote
Old 05-12-2006, 11:52 AM   #35
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
where can i get this stuff?
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Soldering irons Cougar R/C Tech Site Forum 11 11-30-2005 04:38 PM
Soldering irons Cougar Chat Lounge 0 10-26-2005 01:26 PM
What soldering irons are best..... Stevietd14 Electric On-Road 12 03-08-2005 05:56 PM
soldering irons John Q Electric On-Road 41 02-07-2005 02:26 PM
Soldering Irons GASKET98 R/C Items: Wanted to Buy 3 11-04-2004 10:03 PM
