Old 01-01-2003, 05:41 PM   #1
Default Need some help with charger settings...
I need to set the following...
1. Charger Current
2. Discharge Current
3. Trickle Current
4. Peak AD. NiMH
This is for charging a 5 cell micro battery.
Thanks.
d2create is offline   Reply With Quote
Old 01-01-2003, 06:10 PM   #2
popsracer's Avatar
Default Need more info to help
d2create;
You need to provide some more information before we can offer a recommendation.
Battery type; NiCd or NiMh?
Mah of the pack?
What type of charger do you have?
Lastly what do the charger instructions say?
popsracer is offline   Reply With Quote
Old 01-01-2003, 06:33 PM   #3
NiMH
1100mah
Quasar Pro Charger
The instructions just say to set these settings.
That's why I'm asking you guys.
Old 01-01-2003, 06:56 PM   #4
Send a message via AIM to ZER01
Charge Amperage: 2A
Discharge Amperage: I wouldn't discharge NiMH's unless you plan on cycling them. If so, 5A.
Trickle Charge Amperage: I wouldn't recommend this either as NiMH's can be damaged very easily due to over charging.
Peak Detect: .02-.03V
ZER01 is offline   Reply With Quote
Old 01-01-2003, 07:36 PM   #5
popsracer's Avatar
Default proudwinner;
Charge Amperage: 2A
Isn't 2 amps a little steep for AA batts?
I always charge my AA TX packs at 1 amp and get flack whenever I mention the fact.
Somewhere there is a formula to calculate charge rate based on cell capacity, but I never bothered to write it down.
Old 01-01-2003, 07:55 PM   #6
popsracer, 2A's is too high for charging AA's. I charge my 1800mA NiMH AA's at .4-.5A with a peak detect of .02-.03V. For Micro packs I would charge at 2A with a peak detect of .02-.03V.
Old 01-01-2003, 11:27 PM   #7
popsracer, I'm just going by what Pro-match says for charging 5 cell 1100mAH micro packs, isn't that what d2create said.
http://www.promatchracing.com/micro.htm
ICE CHARGER SETTINGS FOR M11 TRANSMITTER WITH 2400'S trebor Electric Off-Road 20 02-28-2007 01:59 PM
ICE CHARGER SETTINGS FOR M11 TRANSMITTER WITH 2400'S trebor Electric On-Road 6 02-22-2007 04:33 PM
Battery Charger settings Interceptor Electric On-Road 0 11-10-2006 07:11 AM
Brand new ICE charger, HELP W/ SETTINGS Crazybry79 Rookie Zone 2 11-01-2006 12:53 PM
Duratrax ICE Charger Settings DoH Australian Racing 4 07-10-2005 10:14 PM
