trickle charger....
Old 05-09-2006, 04:03 PM
aquito's Avatar
Default trickle charger....
can someone explain me what it this trickle thing??? I have a 30min charger, when its chaged it goes to trickle...what is trickle?
sorry im a newb lol
aquito is offline
Old 05-09-2006, 08:34 PM
PlainOleDave's Avatar
Trader Rating: 14 (100%+)
"Trickle" is simply a small amount of charge. When the Charger finishes it's cycle, the Charger continues to charge the battery but at a much decreased rate. Most will advise not to allow this trickle charge to occur as it may be good for certain applications but not usually for racing.
I have seen it used extensively in oval racing but that was years ago and I do not know wut the current critiria is.
PlainOleDave is offline
Old 05-09-2006, 09:29 PM
Joel Lagace's Avatar
Never mind worrying about trickle or not to trickle, worry about using that dangerous timer charger. You can not get todays Nihm or Nicad packs charged in 30 minutes at the low amp rate they run at. So your forced to keep cranking the timer and then you enter the danger zone of no peak detection!! 1 or 2 minutes to long and pooof your pack is toast.
Do your self a favour:Get a peak chargers before you spend another dime on this hobby, you will get better runtime,voltage out of your packs and you will protect your health and safety knowing your pack will stop charging when it should, not to mention the safety of your home..
I really think the RC industry and hobby shops should ban the sale and use of those chargers. ITs only a step above pluggin the packs directly to a 12volt car battery.
Sorry for the rant..
Turn off trickle charge if you can, its only usefull on transmitter batteries that require low charge rates
Joel Lagace is offline
Old 05-09-2006, 09:37 PM
aquito's Avatar
dawm nice to know that man...im gonna buy another charger then...do u recommend any?
aquito is offline
Old 05-09-2006, 10:03 PM
aquito's Avatar
can u recommend a charger/discharger??? up to $ 50.00 ??
aquito is offline
Old 05-09-2006, 10:10 PM
pinggoy's Avatar
Trader Rating: 24 (96%+)
duratrax ice charger.... it would actually display how many mah is in your battery.... for ex.. i got a 3800 battery but it doesnt mean it really has the exact 3800 in it... so when i charge it up sometimes it will say it has 3940 in it...it shows you...
pinggoy is offline
Old 05-09-2006, 10:34 PM
aquito's Avatar
how about this....is this a good one?? Duratrax Intellipeak
http://www2.towerhobbies.com/cgi-bin...?&I=LXUF43&P=0
aquito is offline
