Old 05-10-2006, 04:37 AM   #16
TRF415boy's Avatar
Originally Posted by robk
Interestingly enough, I was told by a pro driver that there is no need for a cap in any on road stock motor racing, and not much in 1/12 mod. Touring car mod is the only clas where you are off the gas long enough to take advantage of the cap. Has anyone had any experience with this?
Well he should then review his ESC basics. As long as you're not to full throttle you wil always have a moment when your motor is off power and sending a back emf to the speedo. Anyway power caps are not here to provide power, but to smooth out the gate opening when the fets get warm bu the end of the run.
TRF415boy is offline   Reply With Quote
Old 05-10-2006, 09:00 AM   #17
pucho's Avatar
Send a message via AIM to pucho
I don't use one on my Twister 2.1 for stock and some 19t racing with no problems with fade/spkes or anything of the sort.
pucho is offline   Reply With Quote
Old 05-10-2006, 10:16 AM   #18
Send a message via ICQ to rcnewb2004
A capacitor will give the vehicle more punch and a smoother acceleration for sure. Its not a requirement, your equipment will function 99% well most of the time because the quality of ESCs today are far better. But if your driving style/track requires you to accelerate and brake constantly, it maybe benefical for you to add a cap.
I have a twister 2.1 and run 19T, adding the cap has definately helped me exit corners a bit quicker. Suits my style of driving (I jam the throttle too much). Infact I have 2x 4700uF caps on mine linked in parallel. Does wonders for acceleration.
rcnewb2004 is offline   Reply With Quote
Old 05-10-2006, 10:34 AM   #19
TRF415boy's Avatar
Get back to earth mate, caps aren't capable of providing high amps, and the energy they stock will only make the motor turn slightly as has been said earlier. As an example, your 4700 µF caps are capable of stocking 0.12 Joules, this is completely useless to provide power for more than a nanosecond to a motor.
Old 05-10-2006, 11:09 AM   #20
They are not able to provide higher amp draws, but they are capable of providing voltage during the off cycles on the esc.
I am interested to know where you get your numbers. 0.12J and 1 ns.
Can you elaborate on that a bit more?
Old 05-10-2006, 11:13 AM   #21
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
where we can get this capacitor? it should be very costly
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 05-10-2006, 11:52 AM   #22
TRF415boy's Avatar
W= 1/2*C*V˛ for any capacitor. nanosecond is an estimation, it just means a time so short you won't notice it.
How can they provide voltage if they don't provide energy ? As soon as they're discharged they're not providing any energy anymore. During a ESC off cycle the batt voltage goes back up and that's when the cap gets charged, it can't provide voltage at that moment.
Old 05-10-2006, 12:13 PM   #23
I am not sure if all the energy in the capacitor is drained through one off cycle of the esc. if it can last more than 1/9300s (the lowest frequency on the hara twister is 9300hz) there may be energy left in the capacitor such that it can provide voltage through the off cycle...?
Can they provide voltage during the moments while battery voltage is going back up but it is still below the voltage in the capacitor?
I am sure it charges while the vehicle is free rolling. Therefore after a couple seconds of free rolling... the capacitor should be full again...
I have troubles believing that what I am seeing w/ additional capacitors on my ESC is some kind of illusion.
Old 05-10-2006, 04:51 PM   #24
robk's Avatar
Trader Rating: 22 (100%+)
Doesn't the shottky control back emf? I thought the cap went to the battery?
Old 05-10-2006, 10:13 PM   #25
XrayFK's Avatar
You are correct, a capacitor helps smooth out voltage spikes (dips, actually) from the motor.
XrayFK is offline   Reply With Quote
Old 05-11-2006, 07:30 AM   #26
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
i put one of these on my car last night. i had to go from aluminum dog bones to STEEL. and this is with a stock motor.
yeah, oddly enough, the capacitor has made more people exhibit the placebo effect than any other product ever created. it's truly absurd.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 05-11-2006, 08:05 AM   #27
where can i get one seaball? i am interested in testing it out.
if it doesn't speed me up, don't matter to me, it certainly hasn't slowed me down.
Old 05-11-2006, 07:53 PM   #28
Z.Hallett's Avatar
Send a message via AIM to Z.Hallett
a website to show and explain the true science behind these claims would be welcome. i as well as an electrical engineer would like to examine the scientific background to see if this is truly plauseble to get such a high charge/current into a very minute package. this seems highly unlikely (no matter how low a voltage you go) to have 3F in a package less than 40mm X 20mm. a capacitor for car audio can hardly keep a 1 1/2 F cap from being less than a foot long and approx. 4-5 in in dia. and still keep it under 20 - 30 lbs.
so for the sake of us all:
please elaborate on your truly spectacular (if true) claims.
Z.Hallett is offline   Reply With Quote
Old 05-12-2006, 12:08 PM   #29
Originally Posted by Soviet
It's a picture from the assembly line. Most likely a test stand to test / cycle / condition , etc. the capacitors.
Nope, that's the matcher.....
Team BSR
Team Power Push
Protoform Race Bodies
KSKT Racing - #1 in SK Racing Chassis
Darkside Motorsports - "WE ARE WHAT'S NEXT." - www.darksidems.com
THE DARKSIDE is offline   Reply With Quote
Old 05-12-2006, 06:17 PM   #30
http://en.wikipedia.org/wiki/Supercapacitor
AustinTX is offline   Reply With Quote
LRP QC2 ESC, EA 19T Komodo & SpeedPassion Capacitor Still Bill R/C Items: For Sale/Trade 2 03-31-2007 10:19 PM
LRP QC2 ESC w/EA C027 & SpeedPassion Capacitor Still Bill R/C Items: For Sale/Trade 12 03-25-2007 07:35 AM
diode & super capacitor question nikkiesteban Electric On-Road 2 01-30-2007 11:56 PM
Super Capacitor coming soon! rcKenon.com Electric Off-Road 0 05-09-2006 01:37 AM
Super Capacitor (1 Farad) Yuchol Electric On-Road 63 05-09-2003 11:51 AM
